Good morning
We write this email because we have problems relating to 'LiveCycleES2 integration with Sharepoint.
Both applications were installed on a 'single virtual machine running Windows Server 2008.
As a basis for the installation we have followed the following pdf
http://www.scribd.com/doc/38462381/Adobe-Connector-Forms-Share-Point-I nstall-Config
(view link)
in all its configurations, the problem arose
during the creation of services through the workbench as shown in this video: http://vimeo.com/9378807.
The process created is to fill out a form and then stored as a document. Pdf sharepoint static.
In creating the service, we stopped in the part for sharepoint or in connection with the component CreateDocument.
All 'component's internal process described above is the card properties in the document library and information site where in site URL should load the various sites created on sharepoint and all sub-sites which you can not see.
Thanks for the 'attention, waiting for reply.
We'll need some more information from you in this regard like where exactly are you stuck at. What is the exception are you getting?
Can you elaborate a little on the statement:-
"All 'component's internal process described above is the card properties in the document library and information site where in site URL should load the various sites created on sharepoint and all sub-sites which you can not see.
Thanks for the 'attention, waiting for reply."
Some more queries on the behavior:-
1 I can see you specified some Document Library in the field. Is this a case that earlier things were working but stopped in between?
I created a site in sharepoint, I can not see through the workbench
2. What you can try out is specify the SiteURL by yourself, in the format as http://serverName/SiteName (something similar that you use to access Sharepoint server through browser). Once done with that, invoke the process and let us know the error you get.
2010-09-30 16:17:35,765 ERROR [com.adobe.livecycle.crc.sharepoint.utils.Transliterator] org.apache.axis2.AxisFault: Transport error: 401 Error: Unauthorized
at org.apache.axis2.transport.http.HTTPSender.handleResponse(HTTPSender. java:296)
at org.apache.axis2.transport.http.HTTPSender.sendViaPost(HTTPSender.jav a:190)
at org.apache.axis2.transport.http.HTTPSender.send(HTTPSender.java:75)
at org.apache.axis2.transport.http.CommonsHTTPTransportSender.writeMessa geWithCommons(CommonsHTTPTransportSender.java:371)
at org.apache.axis2.transport.http.CommonsHTTPTransportSender.invoke(Com monsHTTPTransportSender.java:209)
at org.apache.axis2.engine.AxisEngine.send(AxisEngine.java:448)
at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisO peration.java:401)
at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(Out InAxisOperation.java:228)
at org.apache.axis2.client.OperationClient.execute(OperationClient.java: 163)
at com.microsoft.schemas.sharepoint.soap.AuthenticationStub.Mode(Authent icationStub.java:317)
at com.adobe.livecycle.crc.sharepoint.session.SessionProvider.isAuthenti cationModeForms(SessionProvider.java:121)
at com.adobe.livecycle.crc.sharepoint.session.SessionProvider.authentica teStub(SessionProvider.java:68)
at com.adobe.livecycle.crc.sharepoint.utils.SharePointInteractionUtils20 07.getImmediateDocumentLibrariesWithinASite(SharePointInteractionUtils 2007.java:122)
at com.adobe.livecycle.crc.sharepoint.utils.SharePointInteractionUtils20 07.getImmediateDocumentLibrariesWithinASite(SharePointInteractionUtils 2007.java:61)
at com.adobe.livecycle.crc.sharepoint.utils.SharePointHelperUtils2007.up dateDocumentLibraryDataCache(SharePointHelperUtils2007.java:504)
at com.adobe.livecycle.crc.sharepoint.MSSharePointCRCServiceImpl.getAllD ocumentLibrariesList(MSSharePointCRCServiceImpl.java:1645)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(Defaul tPOJOInvokerImpl.java:118)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(In vocationInterceptor.java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.procee d(RequestInterceptorChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.int ercept(DocumentPassivationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.do InTransaction(TransactionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.execute(EjbTransactionCMTAdapterBean.java:357)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.doSupports(EjbTransactionCMTAdapterBean.java:227)
at sun.reflect.GeneratedMethodAccessor777.invoke(Unknown Source)
at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(S tatelessSessionContainer.java:237)
at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invo ke(CachedConnectionInterceptor.java:158)
at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(Stat elessSessionInstanceInterceptor.java:169)
at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidation Interceptor.java:63)
at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInte rceptor.java:121)
at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxIntercep torCMT.java:378)
at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:1 81)
at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor. java:168)
at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFacto ryFinderInterceptor.java:138)
at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:6 48)
at org.jboss.ejb.Container.invoke(Container.java:960)
at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalPro xyFactory.java:430)
at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSes sionProxy.java:103)
at $Proxy384.doSupports(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute (EjbTransactionProvider.java:104)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.inte rcept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.inte rcept(InvocationStrategyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept( InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept (AuthorizationInterceptor.java:188)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterc eptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineI mpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(A bstractMessageReceiver.java:329)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeC all(SoapSdkEndpoint.java:139)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke( SoapSdkEndpoint.java:81)
at sun.reflect.GeneratedMethodAccessor887.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.j ava:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider .java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java: 323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrateg y.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454 )
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:69 9)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBas e.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl icationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF ilterChain.java:206)
at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(I nvocationFilter.java:43)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl icationFilterChain.java:235)
at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFi lter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV alve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV alve.java:175)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(Securit yAssociationValve.java:179)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValv e.java:84)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j ava:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j ava:104)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedC onnectionValve.java:157)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal ve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav a:241)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java :844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.proce ss(Http11Protocol.java:580)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:44 7)
at java.lang.Thread.run(Unknown Source)
from what I understand is a permission problem, but I am the administrator I have all the permissions to work
3. You are trying out things with SharePoint 2007 or Sharepoint 2010??
SharePoint 2007
4. What is the IIS Authentication mode selected? That setting is available at Central Administration > Application Management > Authentication Providers > Edit Authentication in Sharepoint 2007. Can you attach a snapshot of LoginSettings in workbench along with the Authentication mode selected in Sharepoint for the website you are trying to access.
I did not understand
5. Also, can you please attach the server and workbench logs? Are you using Jboss turnkey? Default server logs directory in that case is <jboss\server\lc_turnkey\log> and that for workbench is C:\Documents and Settings\<Profile>\Workbench ES2\.metadata
yes, using Jboss turnkey
log workbench today:
!SESSION 2010-09-30 10:01:42.703 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_07
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: #Product Runtime Configuration File
Command-line arguments: -os win32 -ws win32 -arch x86 #Product Runtime Configuration File
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 10:01:45.279
!MESSAGE LiveCycle Workbench ES version '9.0.0'
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 10:02:15.252
!MESSAGE User 's.administrator' logged in to server '192.168.12.101' (hostname: '192.168.12.101')
!SESSION 2010-09-30 14:21:17.188 -----------------------------------------------
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 14:21:19.832
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 14:21:36.734
!SESSION 2010-09-30 16:16:29.818 -----------------------------------------------
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 16:16:32.559
!ENTRY com.adobe.ide.singlesignon 1 1 2010-09-30 16:16:51.761
!ENTRY org.eclipse.ui 4 0 2010-09-30 16:17:35.905
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
at org.eclipse.jface.viewers.StructuredViewer.assertElementsNotNull(Stru cturedViewer.java:578)
at org.eclipse.jface.viewers.StructuredViewer.getRawChildren(StructuredV iewer.java:938)
at org.eclipse.jface.viewers.ColumnViewer.getRawChildren(ColumnViewer.ja va:703)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractT reeViewer.java:1330)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:3 85)
at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(Abst ractTreeViewer.java:636)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(Abstra ctTreeViewer.java:602)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer .java:799)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractT reeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:6 34)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(A bstractTreeViewer.java:1490)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewe r.java:823)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer .java:1474)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(Struct uredViewer.java:1365)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.j ava:397)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(Struct uredViewer.java:1328)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTre eViewer.java:1467)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:2 51)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer. java:1603)
at com.adobe.livecycle.crc.sharepoint.editor.type.MSSharePointDocumentLi braryPickerDialog.createRepositoryComposite(MSSharePointDocumentLibrar yPickerDialog.java:93)
at com.adobe.livecycle.crc.sharepoint.editor.type.common.MSSharePointIte mPickerDialog.createDialogArea(MSSharePointItemPickerDialog.java:124)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:760)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at com.adobe.livecycle.crc.sharepoint.editor.type.common.MSSharePointIte mPickerDialog.open(MSSharePointItemPickerDialog.java:98)
at com.adobe.livecycle.crc.sharepoint.editor.common.MSSharePointItemPath EditorEclipseUIComponent$2.widgetSelected(MSSharePointItemPathEditorEc lipseUIComponent.java:207)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java: 228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:488)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.lcide.rcp.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Error indicates an authentication failure which actually makes my 4th point very valid.
1.
In SharePoint Configuration Manager, you can configure the Authentication type and Authentication mode SharePoint site should use. These could be either of Forms, Windows or Web Single Sign on and Windows Authentication or Basic Authentication. See snapshot for details:-
2. Also I would ask you to double check the hint section of Username field in workbench. Specifically are you following this:-
User name to be used to connect with Microsoft SharePoint Server. In case of Windows local users or users configured using Forms Authentication on Sharepoint site only username needs to be provided. However, in case of domain users for Windows Authentication enabled sites, both domain name of the user and login name needs to be provided e.g. domainName\LoginName. Note: This field is only used when the Login Mode is set to 'Use User Credentials'
3. What is the site that you trying to connect to ? Is it on the default 80 port or some other? Also can you paste in your hostname/username/domain settings here?
