I've had CS5 since around when it first came out and this is the second time I've gotten a project requiring me to get deep into Photoshop. It has been quite frustrating this time as I am finding bugs (in InDesign too but I already posted about that).
What I am finding now is that Undo is not working. Almost everything I do it either won't Undo when I choose undo from the menu or press command-x OR the menu simply says "can't undo". Now, I can go into the History palette but the quick way of command-x is my routine and is much faster.
Things I have tried to undo but can't:
- crop an image
- add a type layer
- fill with a pattern
- add an adjustment layer
...to name a few off the top of my head.
GRRRRRR
Mac OS 10.6.4
4 GB RAM
Photoshop 12.0.1 running in x32
Cmd-x was a typo, I meant cmd-z.
I just restarted Photoshop to see if that will fix it. Here's what I tried...
1. filled the document will the foreground color - undo worked
2. added a new layer - undo did not work
3. added a layer style - undo worked
4. added an adjustment layer, changed the saturation - undo did not work
5. added a type layer and typed in some text - undo did not work
6. changed the text color - undo worked
I'm beginning to wonder if they actually changed what Photoshop is able to undo now. It's becoming quite frustrating because things you could undo before you can't anymore (I upgraded from CS3).
Resetting prefs made no difference.
I could not reproduce that, I don't expect they would change such a fundamental and important function.
I know how it was possible to mess it up in CS4 and earlier, by stepping back in history palette and using cmd-z at the same time or interchangeably it used to get out of synch. eg: add a layer, click on previous step in history, then cmd-z would not work until more changes were made.
You're not mixing these actions are you?
Since resetting prefs didn't work, you could (for laughs) clean the font caches and repair permissions. (some may laugh, but these actions have cured strange effects in the past, however illogical it seems to me)
The problem plugin is the FontAgentPro auto-activation plugin.
With the plugin removed, I create an adjustment layer, then press command-Z to undo and the adjustment layer goes away.
When I put the plugin back into the plugins folder, restart Photoshop, and try to do the above, the only way to undo the adjustment layer is to use the History palette.
I will file a report with Insider Software.
I spoke too soon. Even with the FontAgent plugin gone, I just used the clone stamp tool and undo would not work. Restarting Photoshop make it work again.
UPDATE: NO GO. Even without any third party plugins Undo is not always working. Now I can't undo layer resizing as well as clone stamp, brush tool and who knows what else.
I'm getting another glitch now too... when I click the adjustment layer icon in the layer panel, no menu pops up, it takes me to the Finder as if I click onto the desktop. If I click on the FX button I get the menu, then go back to Adjustment Layer and that menu now shows up.
Are you manually changing the zoom level at any point? In particular, are you entering a new zoom value in the lower left corner of the image window? One person reported this as a way to trigger the problem, and I am able to reproduce this myself. Let me know if this is the case for you as well.
Hi, yes using the zoom options in the menu etc is ok. Although if I want to go to a specific amount I need that box.
Well now that I know how to recreate the problem I can either try to avoid it or "clear" the problem by closing and reopening my document.
I sincerely hope this bug and several others I've documented in InDesign and Illustrator are fixed for CS5 and not left for CS5.5 - I don't plan on paying for an upgrade just for bug fixes. Thanks!
I had just noticed this myself, but wasn't sure if I was imagining things since I was opening and closing documents in rapid succession.
But I have a bit better temporary solution than closing the file. Cmd-Option-Z still works, though since it doesn't toggle the last change you may also have to resort to Shft-Cmd-Z.
I agree that this needs to be fixed, and unfortunately we weren't able to include it in this update.
As for not being able to use CS5 in print production, is there a reason why the current workaround isn't feasible for your particular workflow? Any information that I can add to the bug report is helpful, so that we understand the impact.
Hi, I reported several bugs in Photoshop and InDesign. The only reply I got when submitting Adobe Cases is for a bug in InDesign that causes a crash. Their reply has been "upgrade to CS5.5" and that it is fixed in CS5.5. I got no reply for the other bugs I reported other than in these forums and the only reply from someone actually from Adobe has been you. I believe somebody wrote further back in this thread that the "Undo" bug is fixed in Photoshop CS5.5.
There is no Photoshop CS5.5: http://phtshp.us/5_5_Faq
The version of Photoshop CS5 that comes with CS5.5 is identical to the version of Photoshop CS5 that comes with CS5 in terms of included bug fixes.
Jeff beat me to it, but that's why I was asking -- you should have the same bug fixes in Photoshop 12.0.4 and 12.1.
Like Jeff, I can only speak for Photoshop. Since this is the Photoshop forum, you might try asking questions about the other products in those forums (if you haven't already).
