Cairngorm3 - Insync module exmaple does not work ?
Sep 29, 2010 12:16 AM
I've DL the module exampe; from the repository (eg. http://opensource.adobe.com/svn/opensource/cairngorm3/trunk/samples/in sync/) and add the "missing libraries in order to make them compiling.
These are compiling, but when I launch them (the shell application or the sub-module application one by one) I've got an empty blank page.
The libs I'm using are :
- integration-0.14.swc
- integrationParsley-0.14.swc
- module-0.12.swc
- observer-1.11.swc
- parsley-flex4-2.3.0.swc
- spicelib-flex-2.3.0.swc
- navigationParsley-1.1.swc
Maybe I've done something bad in the configuration (or some files are missing... )
I've also created another simple project from scratch. The project is compiling and working ok. I tried to create a module from this project and call it from a new "shell" project but then I've got the following error while the "shell" appliction is loading the project :
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.adobe.cairngorm.module::ParsleyFlexModuleFactory/create()[C:\work spaces\flex4.0betadrop17feb10\Cairngorm 3 trunk\target\checkout\libraries\Module\src\com\adobe\cairngorm\module \ParsleyFlexModuleFactory.as:96]
at com.adobe.cairngorm.module::ModuleViewLoader/addLoadedModuleToStage() [C:\workspaces\flex4.0betadrop17feb10\Cairngorm 3 trunk\target\checkout\libraries\Module\src\com\adobe\cairngorm\module \ModuleViewLoader.as:283]
at Function/http://adobe.com/AS3/2006/builtin::apply()
at mx.core::UIComponent/callLaterDispatcher2()[E:\dev\4.x\frameworks\pro jects\framework\src\mx\core\UIComponent.as:11614]
at mx.core::UIComponent/callLaterDispatcher()[E:\dev\4.x\frameworks\proj ects\framework\src\mx\core\UIComponent.as:11552]
Could you please help me to see what's wrong ?
Thx
    Oct 1, 2010 2:37 AM   in reply to MrKoinkoin
    Good to know that you are able to run the Insync sample App. We'll have a look into your second issue to see whats going on.
    Could you post your sample project so that we can narrow down the problem?
    Many thanks
