dan7055
What video format is best to work with in Adobe Premiere Pro?
Oct 2, 2010 8:14 PM
I have some 720p videos I would like to edit in Premiere but they are in .mov and premiere does't accept that format. What is the best format to convert them to and how/what site can I go to to convert them for free?
    Oct 2, 2010 8:22 PM   in reply to dan7055
    I'm not sure you are correct - check out formats that work in PP:
    http://help.adobe.com/en_US/PremierePro/4.0/WSf52ca809ac8f6c7135876f96 1243120b72d-8000.html
    Oct 2, 2010 8:30 PM   in reply to dan7055
    Which version of Premiere are you using?
    Oct 2, 2010 8:32 PM   in reply to kwompus
    Also - check this out - it may help.
    http://forums.creativecow.net/thread/3/901866
    Oct 2, 2010 9:10 PM   in reply to dan7055
    Well, there are MOV and then there are MOV. That format is but a wrapper. This ARTICLE will give you some background.
    Though I am doing SD Projects, many of my suppliers, especially 3D animators, are on the Mac, and provide me with MOV files in the Animation CODEC. These work perfectly in PrPro, on my PC.
    Good luck,
    Hunt
    Oct 2, 2010 9:12 PM   in reply to dan7055
    For conversion of MOV (and MP4) files, I like Apple's QuickTime Pro, which is a US$29 upgrade/unlock.
    Good luck,
    Hunt
    Oct 3, 2010 7:59 AM   in reply to dan7055
    >Version 7.0
    As far as I know, that is actually Premiere Pro version 1.0 - there was some name changing going on way back then, when Premiere 6.5 was rewritten into Premiere Pro, Adobe called it version 7 when it was bundled with computers and version 1 when it was sold by itself... later, the next version, was just called Premiere Pro 2 (actually CS2, I think)
    If you have an old Apple Quicktime installed, a version that is compatible with that old version of PPro, you might be able to directly use a MOV file... at least if the MOV file "insides" consists of a codec that v1 can edit at all (I'm not sure if v1 will edit any or many of the more modern HD codecs)
    But, converting to DV AVI type 2 with 16bit 48khz sound is likely to work better, since AVI is the "native" format for PPro
    Oct 3, 2010 8:31 AM   in reply to John T Smith
    Yes, that version is a bit of an odd beast. It seems that it was released with three names, Pr 7.0 (most often seen in an OEM situation), PrPro 7.0 (there have been photographs of boxes and media, with the "Pro" clearly shown) and then PrPro 1.0. Were there any differences? I do not know, especially as few have ever seen the PrPro 7.0 version.
    I do agree that DV-AVI Type II w/ 48KHz 16-bit PCM/WAV is as good as it gets.
    Hunt
    Oct 3, 2010 8:41 AM   in reply to dan7055
    Well, WMV is a highly compressed format (the degree depends on the exact CODEC inside the WMV wrapper), so just on a guess, I'd say that the compression is messing up the Audio. I only use WMV as a final, delivery format, where required.
    Good luck,
    Hunt
    Oct 3, 2010 9:19 AM   in reply to dan7055
    >converted to AVI and for some reason it would not accept that format either
    Again, MOV and AVI are file "names" that can contain may different flavors of codecs
    Use the FREE http://www.headbands.com/gspot/ to find out what is inside a file
    Oct 3, 2010 9:24 AM   in reply to John T Smith
    Back in Reply #7, there is a link. In it, will be directions on using G-Spot to determine the full nature of an AV file.
    Good luck,
    Hunt
    Oct 3, 2010 2:16 PM   in reply to dan7055
    Dan,
    Glad that you found a workflow that is working for you.
    Good luck,
    Hunt
    Oct 3, 2010 2:26 PM   in reply to dan7055
    Dan,
    The reason for that quality hit with the WMV is its extreme compression. By skipping that, you will get better quality.
    Good luck,
    Hunt
