lightroom spontaneously changing backup site for lightroom catalog
Oct 2, 2010 8:18 PM
when i close lightroom i ALWAYS backup my catalog to an external hard drive,
lightroom seems to write the backup to my internal hard drive at odd times, perhaps 1 of every ten backups, despite the fact that i have always selected the same external drive for this purpose. i depend on my previous selection to indicate the correct path, but this seems to change by itself at odd times.
i often don't check the backup path shown in the shutdown dialog box (because i never change it). however the dialog box does indicate the path that was used, regardless of the disk to which it wrote the file.
fortunately, i nearly always check my external drive to be certain that the backup catalog was written.
This odd and unpredictable behavior is aggravating. my external drive may sleep at times but this is normal for this la cie drive and it always seems to wake as needed.
i should note that the name of my external drive, to which i want the backups written, is "PICTURES BACK-25MAY2010'"  is it possible that because this name is similar the default folder to which it will write on the internal disk ("backup")?
in explaining this i think i may be less than clear!
i use imac i7 27" with os 10.6.4 and lightroom 3.2
thanks to anyone and all.
vince
    Oct 3, 2010 4:48 AM   in reply to vinsolo-TR1ZPE
    Same here. I back up on my Drobo, but sometime it still backsup in the Pictures folder. Also on a Mac.
    Oct 3, 2010 10:12 AM   in reply to vinsolo-TR1ZPE
    If we are talking about the automatic backup on shutdown, it is my understanding that you cannot change this location.  It will make a dated backup file in the backups directory under the directory where the catalogue resides.  Certainly, there is no interface I can see in the catalog prefs for changing this.
    Oct 3, 2010 10:19 AM   in reply to clvrmnky
    clvrmnky,
    You can change it in the dialog that comes up when backing up:
    Beat Gossweiler
    Switzerland
    Oct 3, 2010 10:23 AM   in reply to clvrmnky
    When exiting Lightroom the Backup catalog dialog box will popup. You can choose the location from there. It will remain the same untill you change it.
    Oct 4, 2010 6:53 AM   in reply to b_gossweiler
    Huh. How about that.
    That is terrible usability.
    Oct 4, 2010 2:01 PM   in reply to vinsolo-TR1ZPE
    The time on which back ups are made is set in catalog settings. There are several settings to chose from.
    The location can be chosen at the time the back up is made and can be anywhere you like. If you don't select a location LR will default to the location last chosen.
    In LR 2 the back up was performed on starting LR, in LR 3 (by popular requests, I voted against the change and preferred LR 2's behaviour but seemed to be in a minority on this, pity there isn't a choice as this always ensured the option of a very recent back up if anything goes wrong, very useful on catalogs used by more than one person where the other person may skip the back up on closure)) it is performed on closure.
    Oct 5, 2010 12:37 AM   in reply to vinsolo-TR1ZPE
    Whilst you can never rule out some weird behaviour in a computers OS that makes a random change to a setting, the only reason I can think of for seeing a different location for your backups in LR other than the one set by yourself is that you have inadvertently perhaps created a new catalog and this will default to whatever the default backup location built in by Adobe (I assume My Pictures or whatever on windows)
    Oct 5, 2010 4:58 AM   in reply to vinsolo-TR1ZPE
    I'm having exactly the same problem (OS X 10.6.4).
    Lighroom 'forgets' the back-up location that I have chosen if OS X is shutdown. Each time I exit LR, I have to manually select the path to my external hard-drive again... and again... and again!
    AAARRRRGHHHH!!!!!!!!!
    Oct 6, 2010 4:02 AM   in reply to vinsolo-TR1ZPE
    Here's another thread: http://forums.adobe.com/message/3187733#3187733
    Looks like there's something with the way Mac OS X deals with USB drives.
    Do you backup to and USB or FireWire drive? eSATA?
