Nested Menus Not Appearing in a Custom Panel Fly-out Menu
Sep 28, 2010 7:36 AM
I tried to create a menu for a custom panel, using the example which David Clark graciously pointed out to me:
http://cssdk.host.adobe.com/sdk/1.0/docs/WebHelp/programmers_guide/cus tomizing_the_ui.htm
However, the nested menu items do not appear. I only see Item 1 and Item 2 (and the separator and Item 3), but not Item 2-1. I was expecting to see Item 2-1 nested under Item 2.
I used the menu structure provided in the example (note that there is an error in the example - one of the closing tags is incorrectly specified as "<MenuItem/>" instead of "</MenuItem>"). Below is the corrected XML and my code:
protected function createMenu():void
   var xmlMenu:XML =
    <Menu>
      <MenuItem Id="item_1" Label="Item 1"/>
      <MenuItem Label="Item 2">
        <MenuItem Label="Item 2-1"/>
      </MenuItem>
      <MenuItem Label="---"/>
      <MenuItem Label="Item 3"/>
     </Menu>;
    CSXSInterface.instance.addEventListener(MenuClickEvent.FLYOUT_MENU_CL ICK, menuClickHandler);
    var menuAdded:SyncRequestResult = CSXSInterface.getInstance().setPanelMenu(xmlMenu);
    if (SyncRequestResult.COMPLETE != menuAdded.status)
     trace("Unable to add menu");
   public function menuClickHandler(event:MenuClickEvent):void
       switch (event.menuName) //you can also use the menuId
    case "Item 1":
    trace("Item 1 has been clicked");
    break;
    default:
    trace("clicked " + event.menuName);
I'd appreciate it if somebody could tell me what I'm doing wrong.
TIA,
mlavie
    Sep 28, 2010 12:59 PM   in reply to mlavie
    At the moment, it appears to be a bug. I'm still researching, though.
    Bob
    Oct 5, 2010 9:46 AM   in reply to mlavie
    Not really, I am filing a bug on it.
    Jan 12, 2012 12:52 AM   in reply to Bob Stucky
    I am also facing this problem that nested menu do not appear.Actually i have used CSXSLibrary-2.0-SDK-3.4 so can any one suggest solution?
    Jan 12, 2012 6:00 AM   in reply to nam1490
    Unless I'm mistaken I believe this is a bug in the documentation, and that nested menus are not in fact supported at all.
    Jan 12, 2012 10:07 PM   in reply to lomorgan
    Thnx a lot
