I just installed Presenter on my PC. I'm running Windows 7 with Office 2007.
When I go to publish my presentation - it freezes when it starts creating the .swf - I have to force close the program and when I relaunch PowerPoint, I get a message that says "Powerpoint experienced a serious problem with the Adobe Presenter Powerpoint com addin. If you have seen this message multiple times you should disable this add-in and check to see if an update is available" And asks if I want to disable it.
I dont want to disable it, I want to use it and have it work
I've updated Presenter to 7.0.1 and Flash to 10.1
Anyway, I can't find a way around this. Suggestions/Solutions?
Please update to the latest version of Presenter which is 7.0.6 and then try the same
You can go to Adobe Presenter>Help>Updates
It will offer you to install 7.0.2
You need to install the same and repeat the process untill you get 7.0.6
Please try post that and update the thread
Thanks! That seemed to have worked. I ran the first update I saw, and the Regular Adobe Updater didn't catch that Presenter needed to be updated. Doing it directly from Powerpoint did the trick.
