4
printing a pdf file prints to prn instead of printer
Oct 11, 2010 Oct 11, 2010
Hello,
When I open a PDF file and try to print, it prints to prn file and saves the file to desktop. Even though the correct printer is selected. If I right-click on the file and say print, it goes to the printer, but then i can't chose pages, it prints the whole document.
This only happened recently and until then it was printing fine, nothing that I know of changed.
any help?
thank you.
Print , Windows
208.2K
Community Expert , Oct 11, 2010 Oct 11, 2010
In the print dialog disable the entry 'Print to file'.
Oct 26, 2011 Oct 26, 2011
That did it!  Thanks!
Nov 18, 2014 Nov 18, 2014
Thanks!  I was having the same problem.  That fixed it.
May 06, 2016 May 06, 2016
Had to go to the 'Advanced' tab to find the appropriate check box
thanks
Apr 21, 2021 Apr 21, 2021
This is the key part of the help! Thanks
Apr 02, 2024 Apr 02, 2024
Thank you so much for the step by step!!!
Nov 26, 2022 Nov 26, 2022
Thank you sooo much, Bernard and taldree,.  After much searching and trial and error, I found this.
In Adobe Acrobat Pro:
  1. open the pdf file
  2. select print
  3. with your printer name in the Printer box, select Advanced
  4. Uncheck the Pint to File box
  5. Select OK
  6. Print
Sep 29, 2023 Sep 29, 2023
Thank you so much.  Very specific instructions are much, much appreciated!!!
Dec 31, 2022 Dec 31, 2022
Thanks and happy new year!
Jul 19, 2017 Jul 19, 2017
Oh my gosh!  Thank you so much!  I have just been about to SCREAM!!!  This just started happening recently!
Sep 28, 2017 Sep 28, 2017
please do help me, i have my hp printer and i could not print pdf file. every time i tried to print it automatically save as to desktop, please do give me a solution.thanks
A solution was given earlier in this thread... In case you missed it: Go to the printer properties and tick-off the "Print to file" box.
Jul 20, 2018 Jul 20, 2018
I have a canon and it's automatically printing to file, even when checkbox is unchecked.
I removed the printer, reinstalled - and it keeps happening.
Any ideas?
Which checkbox do you turn off, exactly?
Jul 21, 2018 Jul 21, 2018
In Advanced Print Setup print to file is unchecked. I don't see any other place with a print to file option. When pressing "print" - it will still open a window to save the file.
Aug 20, 2021 Aug 20, 2021
Worked for me too, thanks for the guidence!
Jan 17, 2016 Jan 17, 2016
That solution does not work for me.  There is not print to file in my HP print dialog file
nevermind I found it it works..........
Aug 16, 2019 Aug 16, 2019
If "print to file" is unchecked and it's still printing to a PRN file, and even other programs are doing it, then check your printer port. The printer I was using was set to use a FILE port. Changing it back to the original WSD or TCPIP or USB port will fix it.
Mar 08, 2020 Mar 08, 2020
This did it for me. Printers and scanners >click your printer > Manage > Printer properties > ports tab > wsd
Jun 21, 2020 Jun 21, 2020
Worked for me as well.  I didn't have the manage option but after going into advanced, ports, I was able to change it from Print to File to wsd, thanks again1
Oct 23, 2020 Oct 23, 2020
Thanks for sharing how to find the port. That did it for me too!
Dec 28, 2020 Dec 28, 2020
Thank you so much!! Worked for me after trying about 10 other things.
Mar 10, 2020 Mar 10, 2020
This helped me too. No other solution worked.
