I have the Drive 2 prerelease 2, with the CMIS connector. The drive is set up and connected properly. The files are there on the server. I can see them when I browse to it in Windows Explorer, as well as when I browse to them using the alfresco administration. But, when I open the same folder in Bridge, it says "No items to display"
Not sure why this is happening..... any ideas?
Hi Ross,
Please check the following things:
1. You used Drive 2 prerelease 2, with the CMIS connector. Could you please use the Adobe Drive 2.0 GM build for your testing? You can download it @ http://labs.adobe.com/technologies/drive2/
2. If you meet the issue again in Bridge, you can try to press "F5" in Bridge to refresh the content panel, then you can check if the files can be displayed in Bridge.
Any other questions, please let me know.
Zhiqiang
We have tested Drive+CMIS connector with Alfresco Community Edition 3.3g (Jun 2 1010 nightly build). Older version may not work.
Now latest Alfresco version is 3.4a.
http://wiki.alfresco.com/wiki/Download_Community_Edition
If you are using old version of Alfresco server, please try latest version.
My Alfresco is the most current version, as of about a month ago.
I did discover that, if I type the address to a folder inside of that folder, the contents are found, and Bridge starts to recognize that there are folders in there. So, the problem seems to have resolved itself, but it looks like I may have found a slight glitch in the software.
