Audio losing input device in Captivate 5
Aug 11, 2010 5:30 PM
Has anybody else been seeing problems with the audio in Captivate 5?  I will record a number of slides, then the audio stops working and reports that there is no audio device.  I have to close Captivate and restart it, and then when I auto-calibrate, it comes up with a completely different volume.
I'm using it on a 64-bit machine with Windows 7.  I'm wondering if the 64-bit is the issue.
Replies 1 2 3 Previous Next
    Aug 11, 2010 6:45 PM   in reply to MarionJD
    Hi there
    I'm very doubtful that 64 bits is the issue. But I would encourage you to report it to Adobe as a bug. (Link is in my sig)
    Cheers... Rick
    Helpful and Handy Links
    Begin learning Captivate 5 moments from now! $29.95
    Captivate Wish Form/Bug Reporting Form
    Adobe Certified Captivate Training
    SorcererStone Blog
    Captivate eBooks
    Aug 26, 2010 9:36 AM   in reply to MarionJD
    Any update on this issue?  I recently upgraded from Captivate 4 to 5 and am having the same frustrating experience.  I can only record 4-5 slides at a time before this happens to me and with a large project ahead of me I am considering returning to Captivate 4.
    On a separate but related note, I have also had several situations where using the record audio option crashes my entire computer, forcing me to reboot.  Anyone else have this problem?
    Oct 13, 2010 9:08 AM   in reply to MarionJD
    Hi all,
    What is the Audio device you are using ? Is it a USB or pin type ?
    Do you have Captivate 4 ? If yes, Does the same device work with no issues.
    Let us know the make and some details about the audio device.
    -Ashwin Bharghav B
    Dec 1, 2010 9:17 AM   in reply to MarionJD
    This is a big time waster!   I am also experiencing this problem, working a Windows 7 64-bit environment.
    I had been saving and closing and re-opening Captivate, but will try your suggestion of re-calibrating.
    I hope Adobe will patch this soon.
    Dec 1, 2010 1:43 PM   in reply to LPWebb
    More input...
    Recalibrating doesn't seem to prevent the error for me.
    Captivate seems to lose its place with the counter that is tracking the audio recordings.
    When the error occurs, the  message is "unnamed audio clip", whereas when things are working well, the clips are numbered sequentially.
    I thought maybe saving might be triggering the audio crashes, but apparently that has nothing to do with the problem.  Even if I don't save, the issue comes up every 6 or 7 recordings.
    I figure I'm losing almost 5 minutes every time I have to save, exit, re-launch and re-calibrate the mic.   What a disappointment!
    I am using an older Andrea headset, non-USB, and it worked fine with Captivate 4; no audio "crashes".
    --Linda
    Dec 1, 2010 6:06 PM   in reply to LPWebb
    I have also experienced some issues with Cp5 losing the connection to my USB microphone  (a Rode Podcaster).
    I suspect that the audio drivers are not detecting Captivate, or vice versa.  Either way, this is definitely a bug.
    Dec 29, 2010 10:45 AM   in reply to MarionJD
    Thanks for the update.
    I will pass this on to the developers:
    "Every now and then, when I've been recording audio for a few slides, the Captivate settings switch the Audio Input Device from the Microphone setting to the Wave setting, and Captivate 5 "loses" the microphone.  I switch it back, and continue as usual.
    This may be what's been happening all along, but I can't check it now.  Maybe the Audio Input Device lost its setting.  It would fit with the symptoms."
    Glad you are enjoying your new sound card.
    Regarding sound cards, a question:  Since I'm working on a laptop with only a sound chip on the motherboard, would you or any other forum member be willing to recommend a microphone that might "defeat" some of the hissing I get in my recordings?
    I'd spend as much as $200 if I felt confident of better sound results.
    --Linda
    Dec 29, 2010 10:54 AM   in reply to LPWebb
    Hi Linda
    I'm sure others will chime in on this. But it is my own understanding that you want anything USB connected. If it's USB connected, I understand that the sound card is bypassed as USB devices are totally digital and have their own way of dealing with the audio.
    Cheers... Rick
    SorcererStone Blog
    Captivate eBooks
    Dec 29, 2010 10:58 AM   in reply to Captiv8r
    Ahh, good point.
    I was kinda thinking of the old IBM DSP mic days, but was worried about dating myself.
    Dec 29, 2010 11:02 AM   in reply to LPWebb
    LPWebb wrote:
    ...but was worried about dating myself...
    That's a valid concern! Of all the people I dated. I liked myself the least!
    Cheers... Rick
    SorcererStone Blog
    Captivate eBooks
    Jan 7, 2011 3:01 AM   in reply to LPWebb
    Hi There,
    It would be really nice if you could send us a bug report stating your issue and relevant info comprehensively. This would help us investigate the issue since we are not able to see this issue on our systems.
    -Manish
    blogs.adobe.com/captivate
    Jan 7, 2011 3:18 AM   in reply to M_Anand
    Manish,
    I just logged a bug report on this issue a moment ago. I've been having the same issue with any of the USB microphones I have too.
    Jan 17, 2011 4:31 PM   in reply to MarionJD
    I have been having the same problem. I have an external sound card that I use when recording narration. When I record narration, after a few successful slides, Captivate will start switching to "wave/midi/cd" as the sound device. I change it back under settings to my sound card and sometimes it works, but most times it will look like it changed, but when I record it will not work. I will go back to settings and see that it switched it back to the wave setting. I keep switching it back to my sound card and it will usually eventually work, but it continues happening. It is taking me three times as long to complete my project as it should. I will also get a message about a sound error when it cannot find any device. I usually end of shutting down and rebooting, but it repeats itself again.
    I am using Windows Vista. I had previously had some different sound problems with Captivate 4, and had such high hopes for Captivate 5 . . .
    Jan 17, 2011 7:48 PM   in reply to Scooterpdx
    I applied a recent Captivate patch a few weeks ago, but experienced no changes in the sound issues we've been reporting here.
    I have sent the Captivate 5 development team a sample of a file where two things have been occurring:
    • Captivate "loses" the audio device every few slides.
    • On long files, more than a couple of my sound clips have been dropping audio, mostly at the end.
    Upon analysis, the team did see the issue, and think that the problem was occurring with very large files.   Is that perhaps the case with those of you who are experiencing sound problems?
    They also suggested a workaround for the dropped audio, but it did not correct my issue.  It only caused drops at the beginning of the affected clips instead.
    To fix the problem for the current deadline-driven project,, I re-created around affected 20 slides and then, hoping to avoid re-recording the audio,  imported the audio from the problem slide.  That corrected the clipping issue, suggesting that perhaps the cause of the problem is somehow in the code and/or the slide -- and not directly in the MP3 file.
    I have a large project coming up, and regrettably, I'm going to use Captivate 4 so I don't risk adding uncompensated troubleshooting time to my work.
    The developers are aware of all the sound issues.  I encourage you to continue to report bug issues at their site, and to post any insights here.
    I'm very impressed with some of the new UI features and efficiencies in CA 5, but feel that it is critical that the audio be corrected and thoroughly tested on all user hardware platforms.
    --Linda
    Jan 17, 2011 8:23 PM   in reply to MarionJD
    Ditto here.  Exactly the same issue.
    It works fine for 20-30 slides then loses the microphone.  I reset it back but find the microphone list has now shortened.  It goes fine for a few more slides and then does the same thing.  Eventually there are no microphones to choose from and the only way to get back to square one is to reboot.
    I'd like to blame something other than Captivate 5 but this issue doesn't occur with Cp4 or any other recording software.
    I've already filed a bug report about it.
    A patch would be most welcome.
    Jan 17, 2011 8:24 PM   in reply to MarionJD
    Sorry to hear that you are also continuing to experience driver loss, especially if I remember correctly that you invested in a new sound card and/or mic.
    I hope that the development team is making the whole audio module tops on the list of things to fix.
    Apr 16, 2011 12:57 PM   in reply to Captiv8r
    Having same problem on Window 7, 32 bit, with Captivate 5....But WORSE.... sometimes the program totally freezes right after it loses the mic, and then Captivate forces a shut down losing all of my unsaved work... I'm NOT a happy camper right now. My headset mic is not usb either.
    Apr 16, 2011 1:00 PM   in reply to MarionJD
    As long as this bug has been around, why haven't they fixed it yet??? Not only does it lose the mic, then the program freezes up and forces a shut down, losing all of my work.
    Apr 16, 2011 1:09 PM   in reply to klward129
    I worked some months back with the developers.
    They had me try a workaround in some test files and also took a look at a file I sent them in which I was experiencing the lockup and clipping problem.
    Their suggestions for workarounds did not address enough of the audio issues.
    Especially with large files, I was still getting clipped endings on some audio, and was also experiencing the lockups and need to re-boot.
    Sadly, I've reverted to V4 for my production work because I was losing too many hours to workarounds for a software problem.
    Then I noticed that even in V4, I experienced some similiar issues with clipped audio, although not as much as in v5.  The lockups do not exist for me in v4.
    I did learn over time that if I add silent time at the end of a recording in order to compensate for Captivate potentially clipping the end of a sound recording, I set focus earlier in the track by clicking.  That seems to eliminate much of the clipping issues.  Sometimes I just record a few seconds or two without speaking, and then of course make that section silent.
    I'm not a developer, but my sense is that if any of the code from v4 was used as part of the v5 audio code development, the problem was potentially migrated over.
    I know the developers are aware of and workingn on these issues, but I'm not privvy to any specific patch schedule that addresses this further.
    Apr 16, 2011 8:43 PM   in reply to LPWebb
    Thanks for the input.... I was thinking it seems to be happening much more with larger files also. I'm really losing a lot of time
    with this... After your comment, I'm considering trying version4 to see if it's any better.
    Apr 16, 2011 8:59 PM   in reply to klward129
    How long is it since you updated audio and other drivers on your PC?
    If it's been a while, this might be worth doing.  I still have the occasional issue with my Win7 64bit PC and Captivate 5 losing the connection with the microphone, but at least it doesn't lock up on me.
    Apr 17, 2011 11:39 AM   in reply to MarionJD
    It's a fairly new laptop, and everything is up to date. The laptop is usually very quick to process things when using other programs. I have run updates, done disk cleans, defrags, etc... and it doesn't stop the problems with Captivate.
    I just got Captivate about 1 month ago, and have loaded all updates, and I check for new ones every day.  I have used it quite a bit since that time, and have noticed that the larger my file gets (over 100 slides) the worse the performance gets. Like taking forever just to update a change on one slide.
    I am resorting to doing the audio recording outside of captivate, as I can't afford to lose anymore time on my projects.
    Apr 22, 2011 1:45 PM   in reply to MarionJD
    Yes, we have expereinced this also. We can tell Captivate is not recording becasue there is no VU meter output. I don;t know why this happens, but I now expect it to happen a handful of times when developing 90 slides or so. We go into AUDIO, SETTINGS and check the input device, pre amp levels and reset them. Can Adobe tell us WHY this is occurring? It feels like Captivate is not stable. JR
    Apr 23, 2011 8:47 AM   in reply to JimRichmond
    I totally agree... Captivate is not stable at all!  I have resorted to recording audio on a Blank Project, with just one slide. Then I save it as a podcast, instead of adding it right to a slide. Later I'll go back and import the audio to the proper slides.
    I thought this might help, however, it does not! Even on a blank project, with NOTHING saved to the project, Captivate CRASHES after 3 or 4 recordings... This is ridiculous... How can Adobe even pretend to say this is ready for Market, and actually charge money for it!  It doesn't do what it is supposed to do! Don't they have a Quality Assurance Department??
    Captivate could be an Awesome Product, IF it actually worked correctly... but it doesn't. I would not recommend Captivate to anyone until they get it repaired... too much time is wasted dealing with these errors.
    May 13, 2011 10:08 PM   in reply to MarionJD
    Hiya I have just purchased Adobe 5 (May 2011) and very disappointed that mine is behaving like others have described. I have to deliver a project and no device error messages are being displayed and crashing is occurring. I have reported the problem and the response is to try another mic at this stage! Has anyone else had a resolution?
    May 14, 2011 2:12 PM   in reply to MarionJD
    Thanks for sharing. With enough of our input, Adobe may come up with updates. Best regards.
    Jim Richmond
    Right Management
    May 14, 2011 8:11 PM   in reply to MarionJD
    I have also found, closing down Captivate, and reopening the project, "resets" the software to again recognize the M-Audio interface we are using with our condenser microphone and to accept the channel and pre-amp values that we originally preset. Thanks for sharing and continue luck on your project. Work arounds rock!
    Jim Richmond
    e-Learning/Career Management Services
    Right Management
    4000 Piedmont Parkway
    High Point NC 27265
    United States
    Phone +1 919 403 5615
    Mobile +1 336 259 9524
    jim.richmond@right.com
    www.right.com
    May 14, 2011 8:20 PM   in reply to MikeyPraxis42
    Try this: If you are using a condenser microphone and an A/D interface, look up the speaker/microphone source under the "Control Panel" and "Sound/Audio Settings" and select the device you want to use. You should see it in the menu. If you have done that, and Captivate messes with your settings while you are midstream into your project, save what you have, exit Captivate and reopen it, then check all your settings, and reset as necessary. This is what we have to do EVERYtime we work on a new project. It isn't pretty but it works for us at this time. Good luck
    Jim Richmond
    Right Management
    High Point NC 27265
    United States
    www.right.com
    May 15, 2011 7:13 AM   in reply to MarionJD
    This also happens with built-in sound, not just sound cards.  It happens all the time on my DELL laptops.  As soon as I see the audio has stopped recording my voiceover, I just save my project, close and reopen Captivate, and carry on.  Annoying, but life is never perfect.
    May 15, 2011 10:33 AM   in reply to RodWard
    Looks like bright minds think alike. Now if we can some of those bright minds at Adobe to fix it, that will be terrific.
    Jim Richmond
    Right Management
    May 15, 2011 5:41 PM   in reply to JimRichmond
    Not sure if this will help or not, but I actually received a call from Adobe the other day, regarding my download of the trial version of Captivate 5. My boss purchased it for work, and I downloaded the trial version at home to practice. So I was happy to explain all of my problems with the program to the girl on the other end. I also told her that myself and many others had been posting on the forums about these problems. She told me that she would pass along my comments to their "engineers" and that they had seen the postings on the forum, so they were aware of the problems and were working on it.  I halfway believe that is just what she says to anyone with concerns. I do believe that if enough our our complaints are on here, Adobe has to realize it will hurt their sales of Captivate. As much time as Captivate has cost me in production, we would have been better off to buy a more expensive program to start with! We'll see if they actually do something about it now.
1 2 3 Previous Next
Actions
