I am making a question form - which has multiple questions - which would then
insert multiple answers (yes/no/na) and notes into a table.
I'm at a loss on how to do it - and having a brain fart...
Here is the loop to create the questions... Radio button for answer...
<cfloop query=Q StartRow=1 EndROW="#Column1NumRows#">
<tr>
<td valign=top>
<cfoutput>
#qid#.
</cfoutput>
</td>
<td width=300 valign=top>
<cfoutput>
#question#
<cfif len(notes1)><br>#notes1#: <cfinput type="text" name="notes1" value="" size=10></cfif>
<cfif len(notes2)><br>#notes2#: <cfinput type="text" name="notes2" value="" size=10></cfif>
</cfoutput>
</td>
<td align=center> Yes<br><cfinput type="Radio" name="answer#qid#" value="Yes"> </td>
<td align=center> No<br><cfinput type="Radio" name="answer#qid#" value="No"> </td>
<td align=center> N/A<br><cfinput type="Radio" name="answer#qid#" value="N/A"> </td>
</tr>
<tr height=2 bgcolor=grey><td colspan=5></td></tr>
</cfloop>
But I am having trouble inserting into the answer table..
I'm assuming I need to loop thru things...
I also need to attribute this to a single user...
Any help is appreciated...
Put underscores into your form field names on the radio buttons. Once you've submitted your form, you'll have a whole load of form fields named something like this:
answer_1 = Y
answer_2 = N
answer_3 = Y
answer_4 = N/A
etc
So, you need to loop through all your form fields and do an insert.
<cfloop collection="#form#" item="key">
<cfif find("answer_", key)>
<cfset ThisQuestion = listLast(key, '_') />
<cfset ThisAnswer = form[key] />
<cfquery...>
INSERT INTO answers (....)
VALUES ( <cfqueryparam ThisQuestion />, <cfqueryparam ThisAnswer />) etc
</cfquery>
</cfif>
</cfloop>
Not the most efficient, but that's probably not the major concern here
Not sure that will work...
As the answer is associate with a question ID called QID...
Not associated to Answer_ID...
As with Answer ID - I think I'd have to add that field into the database repetitively...
So form has:
ie: Name: Bob
ie: Question1 (QID): Are u home? Answer: Yes
Question2 (QID) Are u using a computer? Answer: Yes
Question3 (QID) Are u from TimbukToo? Answer: No Note3 - USA
And also be able to associate a note to it as well...
etc...
So the QID is a table field, as is the answer...
QID Answer Note
1 Yes
2 Yes
3 No USA
Thanx for any help...
I'll continue looking around...
What is tripping me up - is naming the radio buttons - as they have to be named differently - so not to get the same answer for each question...
Here is my coding so far...
<cfquery name="Q" datasource="FPB">
select * from Question
</cfquery>
<cfform action="form.cfm?src=ins">
<table border=0 bordercolor=black>
<cfloop query=Q StartRow=1 EndROW="3">
<tr>
<td valign=top>
<cfoutput>
#qid#.
</cfoutput>
</td>
<cfoutput>
#question#
</cfoutput>
</td>
<td align=center> Yes<br><cfinput type="Radio" name="answer_#qid#" value="Yes"> </td>
<td align=center> No<br><cfinput type="Radio" name="answer_#qid#" value="No"> </td>
<td align=center> N/A<br><cfinput type="Radio" name="answer_#qid#" value="N/A"> </td>
</tr>
</cfloop>
</table>
<input type="submit" value="Complete">
<input type="hidden" name="inspid" value="12">
</cfform>
<cfif src is "ins">
<cfloop from="1" to="3" index="n">
<cfoutput>
<cfset qid = "#variables.n#"> #qid# (test output)
<cfset answer = "#answer_#&#variables.n#"> #answer# (test output)
(Just trying simple insert for now)
<cfinsert tablename="answer" datasource="fpb">
</cfoutput>
</cfloop>
</cfif>
Progress...
This is inserting correctly for now...
Time to amp it up a bit with notes etc...
<cfif src is "ins">
<cfoutput>
<!--- first we set up field names to match what the form should be passing. --->
<cfset newqid = "#variables.n#"> #newqid# (test output)
<cfset newanswer = "answer_"&#variables.n#> #newanswer# (test output)
<br>
<!--- then we get whatever values are in those field names and set them as vars --->
<cfset qid = "#Evaluate(variables.newqid)#"> #qid# (test output)
<cfset answer = "#Evaluate(variables.newanswer)#"> #answer#
<cfquery name="insert" datasource="fpb">
INSERT INTO answer (qid, answer)
VALUES (#qid#, '#answer#');
</cfquery>
</cfoutput>
</cfloop>
</cfif>
The general idea will work. However, the most important part, as usual, is making sure that your database schema is optimal for what you are trying to accomplish.
