Locked
Can't install Adobe Air on Mac 10.6.4 - Other threads don't help on topic
Oct 15, 2010 Oct 15, 2010
I just purchased my MacBook Pro and trying to install Adobe Air to run Market Samurai. Each time I try to install it tells me there was an error and to ask my Administrator. Very frustrating. I called Adobe support and tried to pay $39 to get the on phone support but the entire process took 15 minutes before they even set up my account. I opted not to go that route.
I have Adobe CS2 on my machine and not sure if that is conflicting but I need to get this installed today.
Installation
9.1K
Adobe Employee ,
Hello,
Sorry you're running into problems installing AIR.  Here are a few things to try (if you haven't already):
1. Install the AIR runtime directly at http://get.adobe.com/air
2. Once the runtime is installed, try installing Market Samurai
If either of these fail, which I assume they will, please post the AIR installer log.  On the Mac, you can open "Console" to view logging details.  Just select system.log under FILES and then filter on "air".  In the past, there was a version of Market Samurai out that required a beta version of AIR.  I'd like to make sure that this isn't what you're running into.
We did have a conflict with some CS5 installers were a couple of folders that AIR writes to had their permissions changed incorrectly.  Could you check the following directories and set them to be owned by your User Id and not root:
/User/[your username]/Library/Application Support/Adobe
/User/[your username]/Library/Application Support/Adobe/AIR
Chris
I am running CS2 and those instructions are like greek to me. Sorry.
Ok, I think I figured out how to get in there and this is what I see:
Oct  6 00:32:57 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 992 ms
Oct  6 21:56:00 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 144 ms
Oct  7 11:11:31 MacBook-Pro Bluetooth Setup Assistant[4702]: starting pairing
Oct  7 11:12:17 MacBook-Pro Bluetooth Setup Assistant[4702]: starting pairing
Oct  7 12:02:40 MacBook-Pro sudo[5030]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.17Hlnc/tmp ; USER=danieltodd ; COMMAND=/Volumes/Air Display Installer/Air Display Installer.pkg/Contents/Resources/LoginItems
Oct  7 12:02:53 MacBook-Pro com.apple.launchd.peruser.501[98] (com.apple.AirPortBaseStationAgent[123]): Exited: Killed
Oct  7 12:05:47 MacBook-Pro AirDisplayStatusItem[127]: kCGErrorIllegalArgument: CGSShapeWindow
Oct  7 12:05:47 MacBook-Pro AirDisplayStatusItem[127]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Oct  7 12:05:47 MacBook-Pro [0x0-0xa00a].com.avatron.AirDisplayMenuExtra[127]: Thu Oct  7 12:05:47 MacBook-Pro.local AirDisplayStatusItem[127] <Error>: kCGErrorIllegalArgument: CGSShapeWindow
Oct  7 12:05:47 MacBook-Pro [0x0-0xa00a].com.avatron.AirDisplayMenuExtra[127]: Thu Oct  7 12:05:47 MacBook-Pro.local AirDisplayStatusItem[127] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Oct  7 12:05:47 MacBook-Pro ScreenCapture[133]: Screen: Air Display - bounds (0.000000, 0.000000) - (768.000000, 800.000000)
Oct  7 12:05:47 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:07:04 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:07:14 MacBook-Pro [0x0-0xa00a].com.avatron.AirDisplayMenuExtra[127]: Thu Oct  7 12:07:14 MacBook-Pro.local AirDisplayStatusItem[127] <Error>: kCGErrorIllegalArgument: CGSShapeWindow
Oct  7 12:07:14 MacBook-Pro AirDisplayStatusItem[127]: kCGErrorIllegalArgument: CGSShapeWindow
Oct  7 12:08:10 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:08:14 MacBook-Pro ScreenCapture[133]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct  7 12:08:14 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:08:40 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:08:43 MacBook-Pro ScreenCapture[133]: Screen: Air Display - bounds (-1024.000000, 0.000000) - (1024.000000, 768.000000)
Oct  7 12:08:43 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:08:43 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:08:46 MacBook-Pro ScreenCapture[133]: Screen: Air Display - bounds (-1024.000000, 0.000000) - (1024.000000, 768.000000)
Oct  7 12:08:46 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:21:01 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:21:01 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct  7 12:21:40 MacBook-Pro ScreenCapture[133]: Screen: Air Display - bounds (-1024.000000, 0.000000) - (1024.000000, 768.000000)
Oct  7 12:21:40 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 12:22:03 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:51:08 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 132 ms
Oct  7 13:51:12 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:51:23 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:51:45 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:52:28 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:52:42 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct  7 13:52:43 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:52:57 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 13:53:53 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (-1024.000000, 0.000000) - (1024.000000, 768.000000)
Oct  7 13:53:54 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 18:46:39 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 745 ms
Oct  7 18:46:42 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  7 18:46:42 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct  8 08:30:40 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct  8 08:30:52 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct  8 08:30:52 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  8 09:45:22 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  8 09:45:22 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct  8 09:58:51 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct  8 09:58:51 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  8 16:37:00 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  8 16:37:04 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (768.000000, 1024.000000)
Oct  8 16:37:04 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  8 17:04:42 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct  8 17:04:42 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct  9 14:57:33 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 198 ms
Oct  9 21:23:58 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 776 ms
Oct 10 13:42:48 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 896 ms
Oct 10 17:12:51 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 199 ms
Oct 11 06:55:42 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 1882 ms
Oct 11 08:36:28 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 08:36:28 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 09:29:34 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 932 ms
Oct 11 09:29:35 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 09:29:35 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 11 09:29:45 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 09:29:45 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 11:28:44 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 11:28:44 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 11 11:29:31 MacBook-Pro AirDisplayStatusItem[127]: HIToolbox: ignoring exception '*** -[NSCFDictionary initWithObjects:forKeys:count:]: attempt to insert nil value at objects[0] (key: connectToHostName)' that raised inside Carbon event dispatch\n(\n 0   CoreFoundation                      0x00007fff867f3cc4 __exceptionPreprocess + 180\n 1   libobjc.A.dylib                     0x00007fff812a20f3 objc_exception_throw + 45\n 2   CoreFoundation                      0x00007fff8679b112 -[__NSPlaceholderDictionary initWithObjects:forKeys:count:] + 530\n 3   CoreFoundation                      0x00007fff8679d74a +[NSDictionary dictionaryWithObject:forKey:] + 58\n 4   AirDisplayStatusItem                0x0000000100001e01 -[ADEMenuExtra takeVirtualScreenFrom:] + 458\n 5   AppKit                              0x00007fff815c1152 -[NSApplication sendAction:to:from:] + 95\n 6   AppKit                              0x00007fff815e56be -[NSMenuItem _corePerformAction] + 365\n 7   AppKit                              0x00007fff815e5428 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 121\n 8   AppKit                              0x00007fff8186941d -[NSMenu _internalPerformActionForItemAtIndex:] + 35\n 9   AppKit                              0x00007fff8171b217 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 136\n 10  AppKit                              0x00007fff815c7c14 NSSLMMenuEventHandler + 321\n 11  HIToolbox                           0x00007fff843be997 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1002\n 12  HIToolbox                           0x00007fff843bdee6 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 395\n 13  HIToolbox                           0x00007fff843dbba9 SendEventToEventTarget + 45\n 14  HIToolbox                           0x00007fff8440acd1 _ZL18SendHICommandEventjPK9HICommandjjhPKvP20OpaqueEventTargetRefS5_PP14OpaqueEventRef + 387\n 15  HIToolbox                           0x00007fff84437b06 SendMenuCommandWithContextAndModifiers + 56\n 16  HIToolbox                           0x00007fff84437abe SendMenuItemSelectedEvent + 101\n 17  HIToolbox                           0x00007fff844379be _ZL19FinishMenuSelectionP13SelectionDataP10MenuResultS2_ + 150\n 18  HIToolbox                           0x00007fff84540a75 _ZL19PopUpMenuSelectCoreP8MenuData5PointdS1_tjPK4RecttjS4_S4_PK10__CFStringPP13OpaqueMenuRefPt + 1618\n 19  HIToolbox                           0x00007fff84540dce _HandlePopUpMenuSelection7 + 665\n 20  AppKit                              0x00007fff817181c9 _NSSLMPopUpCarbonMenu3 + 3710\n 21  AppKit                              0x00007fff81947e71 -[NSStatusBarButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 162\n 22  AppKit                              0x00007fff8164b4b5 -[NSControl mouseDown:] + 624\n 23  AppKit                              0x00007fff81565763 -[NSWindow sendEvent:] + 5409\n 24  AppKit                              0x00007fff81948c10 -[NSStatusBarWindow sendEvent:] + 68\n 25  AppKit                              0x00007fff8149aee2 -[NSApplication sendEvent:] + 4719\n 26  AppKit                              0x00007fff81431922 -[NSApplication run] + 474\n 27  AppKit                              0x00007fff8142a5f8 NSApplicationMain + 364\n 28  AirDisplayStatusItem                0x00000001000012e4 start + 52\n)
Oct 11 11:29:41 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct 11 11:29:50 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 11:29:50 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 11:30:58 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 11:30:58 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 11 11:31:14 MacBook-Pro ScreenCapture[320]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 11:31:14 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 11:32:08 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct 11 11:32:22 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 11:32:22 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 14:18:21 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 14:18:21 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 11 14:27:27 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 14:27:27 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 17:51:45 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 17:51:45 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 11 17:52:02 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 11 17:52:02 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 19:25:40 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 759 ms
Oct 11 19:25:41 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 11 19:25:41 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 08:48:57 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 214 ms
Oct 12 09:08:07 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 3400 ms
Oct 12 09:22:16 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 12 09:22:16 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 10:05:23 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 10:05:23 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 10:05:43 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 12 10:05:43 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 10:58:08 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 10:58:08 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 10:58:21 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 12 10:58:21 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 11:44:58 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 11:44:58 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 11:45:14 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 12 11:45:14 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 12:30:54 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 12:30:54 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 13:21:08 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 12 13:21:08 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 15:41:30 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 15:41:30 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 15:45:25 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 12 15:45:25 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 17:01:01 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 12 17:01:01 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 12 18:58:20 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 796 ms
Oct 13 07:31:42 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 873 ms
Oct 13 09:01:13 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 687 ms
Oct 13 09:03:05 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 09:03:05 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:44:03 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:44:03 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 13 11:44:14 MacBook-Pro AirDisplayStatusItem[127]: HIToolbox: ignoring exception '*** -[NSCFDictionary initWithObjects:forKeys:count:]: attempt to insert nil value at objects[0] (key: connectToHostName)' that raised inside Carbon event dispatch\n(\n 0   CoreFoundation                      0x00007fff867f3cc4 __exceptionPreprocess + 180\n 1   libobjc.A.dylib                     0x00007fff812a20f3 objc_exception_throw + 45\n 2   CoreFoundation                      0x00007fff8679b112 -[__NSPlaceholderDictionary initWithObjects:forKeys:count:] + 530\n 3   CoreFoundation                      0x00007fff8679d74a +[NSDictionary dictionaryWithObject:forKey:] + 58\n 4   AirDisplayStatusItem                0x0000000100001e01 -[ADEMenuExtra takeVirtualScreenFrom:] + 458\n 5   AppKit                              0x00007fff815c1152 -[NSApplication sendAction:to:from:] + 95\n 6   AppKit                              0x00007fff815e56be -[NSMenuItem _corePerformAction] + 365\n 7   AppKit                              0x00007fff815e5428 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 121\n 8   AppKit                              0x00007fff8186941d -[NSMenu _internalPerformActionForItemAtIndex:] + 35\n 9   AppKit                              0x00007fff8171b217 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 136\n 10  AppKit                              0x00007fff815c7c14 NSSLMMenuEventHandler + 321\n 11  HIToolbox                           0x00007fff843be997 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1002\n 12  HIToolbox                           0x00007fff843bdee6 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 395\n 13  HIToolbox                           0x00007fff843dbba9 SendEventToEventTarget + 45\n 14  HIToolbox                           0x00007fff8440acd1 _ZL18SendHICommandEventjPK9HICommandjjhPKvP20OpaqueEventTargetRefS5_PP14OpaqueEventRef + 387\n 15  HIToolbox                           0x00007fff84437b06 SendMenuCommandWithContextAndModifiers + 56\n 16  HIToolbox                           0x00007fff84437abe SendMenuItemSelectedEvent + 101\n 17  HIToolbox                           0x00007fff844379be _ZL19FinishMenuSelectionP13SelectionDataP10MenuResultS2_ + 150\n 18  HIToolbox                           0x00007fff84540a75 _ZL19PopUpMenuSelectCoreP8MenuData5PointdS1_tjPK4RecttjS4_S4_PK10__CFStringPP13OpaqueMenuRefPt + 1618\n 19  HIToolbox                           0x00007fff84540dce _HandlePopUpMenuSelection7 + 665\n 20  AppKit                              0x00007fff817181c9 _NSSLMPopUpCarbonMenu3 + 3710\n 21  AppKit                              0x00007fff81947e71 -[NSStatusBarButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 162\n 22  AppKit                              0x00007fff8164b4b5 -[NSControl mouseDown:] + 624\n 23  AppKit                              0x00007fff81565763 -[NSWindow sendEvent:] + 5409\n 24  AppKit                              0x00007fff81948c10 -[NSStatusBarWindow sendEvent:] + 68\n 25  AppKit                              0x00007fff8149aee2 -[NSApplication sendEvent:] + 4719\n 26  AppKit                              0x00007fff81431922 -[NSApplication run] + 474\n 27  AppKit                              0x00007fff8142a5f8 NSApplicationMain + 364\n 28  AirDisplayStatusItem                0x00000001000012e4 start + 52\n)
Oct 13 11:44:24 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct 13 11:44:32 MacBook-Pro ScreenCapture[8387]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 11:44:32 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:45:05 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct 13 11:45:12 MacBook-Pro ScreenCapture[14397]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 11:45:12 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:48:01 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:48:01 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 13 11:48:31 MacBook-Pro ScreenCapture[14397]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 11:48:31 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:49:43 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct 13 11:49:54 MacBook-Pro ScreenCapture[14447]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 11:49:54 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:52:08 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 11:52:08 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 13 11:52:45 MacBook-Pro ScreenCapture[14447]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 11:52:45 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 12:11:14 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 12:11:14 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 13 13:17:39 MacBook-Pro AirDisplayStatusItem[127]: Launch pref pane status: 0
Oct 13 13:17:48 MacBook-Pro ScreenCapture[14447]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 13:17:48 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 13:36:25 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 13:36:25 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 13 13:36:44 MacBook-Pro ScreenCapture[14447]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 13 13:36:44 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 17:09:30 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 13 17:09:30 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 13 17:32:26 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 760 ms
Oct 13 20:24:16 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 924 ms
Oct 13 21:48:10 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 840 ms
Oct 14 08:48:04 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 652 ms
Oct 14 08:48:37 MacBook-Pro ScreenCapture[14447]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 14 08:48:37 MacBook-Pro AirDisplayStatusItem[127]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 14 17:56:10 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 699 ms
Oct 14 17:56:12 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 14 17:56:12 MacBook-Pro AirDisplayStatusItem[127]: serverDisconnectedFromDeviceNotification: {\n}
Oct 15 08:09:37 MacBook-Pro configd[13]: PMConnection AirPort configd plug-in com.apple.powermanagement.applicationresponse.slowresponse 309 ms
Oct 15 08:10:51 MacBook-Pro ScreenCapture[125]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 15 08:10:51 MacBook-Pro AirDisplayStatusItem[124]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 15 08:10:59 MacBook-Pro AirDisplayStatusItem[124]: Launch pref pane status: 0
Oct 15 08:11:01 MacBook-Pro AirDisplayStatusItem[124]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 15 08:25:11 MacBook-Pro System Preferences[302]: Pairing device failed with:5
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: UI SWF load is complete
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: stateRunningAppInstaller: appinstaller -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,1,85,3 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://download.marketsamurai.com/MarketSamurai.0.87.3.air -- "installed from web"
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Starting app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: UI SWF load is complete
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: UI initialized
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: beginning UI styling
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: UI styling complete
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Unpackaging to /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp0
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: unpackaging/validation is complete
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: application is bound to this version of the runtime
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: app id MarketSamurai
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Application not located
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Waiting for user confirmation
Oct 15 11:55:01 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: User confirmed action: install
Oct 15 11:55:01 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: creating native installer in: /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp1
Oct 15 11:55:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: native installer creation complete
Oct 15 11:55:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: stateInstallingWithElevation: enter install
Oct 15 11:55:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: stateInstallingWithElevation: /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks" -silent -logToStdout -withRuntime -url -location /Applications -desktopShortcut -programMenu http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:05 MacBook-Pro authexec[1084]: executing /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: UI SWF load is complete
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: UI SWF load is complete
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: UI initialized
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: UI initialized
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: unpackaging/validation is complete
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: unpackaging/validation is complete
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: application is bound to this version of the runtime
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: app id MarketSamurai
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: application is bound to this version of the runtime
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: app id MarketSamurai
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Application not located
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Application not located
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: native installer creation complete
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: native installer creation complete
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Starting install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Starting install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Destination for installed application is /Applications
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Destination for installed application is /Applications
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Beginning install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Beginning install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:55:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 11:55:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 11:55:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:55:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Rollback due to error complete
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Rollback due to error complete
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: starting cleanup of temporary files
Oct 15 11:55:27 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: application installer exiting
Oct 15 11:55:47 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: starting cleanup of temporary files
Oct 15 11:55:48 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: application installer exiting
Oct 15 11:55:48 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: App installer failed; exit code -1
Oct 15 11:55:48 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: begin quitting
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: UI SWF load is complete
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: stateRunningAppInstaller: appinstaller -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,1,85,3 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://download.marketsamurai.com/MarketSamurai.0.87.3.air -- "installed from web"
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Starting app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: UI SWF load is complete
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: UI initialized
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: beginning UI styling
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: UI styling complete
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Unpackaging to /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp0
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: unpackaging/validation is complete
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: application is bound to this version of the runtime
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: app id MarketSamurai
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Application not located
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Waiting for user confirmation
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: User confirmed action: install
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: creating native installer in: /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp1
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: native installer creation complete
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: stateInstallingWithElevation: enter install
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: stateInstallingWithElevation: /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks" -silent -logToStdout -withRuntime -url -location /Applications -desktopShortcut -programMenu http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:56:08 MacBook-Pro authexec[1100]: executing /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: UI SWF load is complete
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: UI SWF load is complete
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: UI initialized
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: UI initialized
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: unpackaging/validation is complete
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: unpackaging/validation is complete
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: application is bound to this version of the runtime
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: app id MarketSamurai
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: application is bound to this version of the runtime
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: app id MarketSamurai
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Application not located
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Application not located
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: native installer creation complete
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: native installer creation complete
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Starting install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Starting install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Destination for installed application is /Applications
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Destination for installed application is /Applications
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Beginning install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Beginning install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:56:15 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:15 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 11:56:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Rollback due to error complete
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Rollback due to error complete
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: starting cleanup of temporary files
Oct 15 11:56:30 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: application installer exiting
Oct 15 11:56:35 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: starting cleanup of temporary files
Oct 15 11:56:36 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: application installer exiting
Oct 15 11:56:36 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: App installer failed; exit code 7
Oct 15 11:56:36 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: begin quitting
Oct 15 11:59:51 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: UI SWF load is complete
Oct 15 11:59:51 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: stateRunningAppInstaller: appinstaller -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,1,85,3 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://download.marketsamurai.com/MarketSamurai.0.87.3.air -- "installed from web"
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Starting app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: UI SWF load is complete
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: UI initialized
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: beginning UI styling
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: UI styling complete
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Unpackaging to /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp0
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: unpackaging/validation is complete
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: application is bound to this version of the runtime
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: app id MarketSamurai
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Application not located
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Waiting for user confirmation
Oct 15 12:00:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: User confirmed action: install
Oct 15 12:00:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: creating native installer in: /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp1
Oct 15 12:00:03 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: native installer creation complete
Oct 15 12:00:03 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: stateInstallingWithElevation: enter install
Oct 15 12:00:03 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: stateInstallingWithElevation: /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks" -silent -logToStdout -withRuntime -url -location /Applications -desktopShortcut -programMenu http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 12:00:07 MacBook-Pro authexec[1135]: executing /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: UI SWF load is complete
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: UI SWF load is complete
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: UI initialized
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: UI initialized
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: unpackaging/validation is complete
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: unpackaging/validation is complete
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: application is bound to this version of the runtime
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: app id MarketSamurai
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: application is bound to this version of the runtime
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: app id MarketSamurai
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Application not located
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Application not located
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: native installer creation complete
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: native installer creation complete
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Starting install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Starting install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Destination for installed application is /Applications
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Destination for installed application is /Applications
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Beginning install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Beginning install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:00:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:25 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:25 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Rollback due to error complete
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Rollback due to error complete
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: starting cleanup of temporary files
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: application installer exiting
Oct 15 12:00:31 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: starting cleanup of temporary files
Oct 15 12:00:32 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: application installer exiting
Oct 15 12:00:32 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: App installer failed; exit code 7
Oct 15 12:00:32 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: begin quitting
Oct 15 12:01:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Performing runtime install
Oct 15 12:01:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: UI SWF load is complete
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: UI initialized
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: starting user confirmation
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Version of this installer: 2.0.4.13090
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Installation type: new
Oct 15 12:01:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: starting elevated install
Oct 15 12:01:32 MacBook-Pro authexec[1176]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: performing an elevated runtime install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: UI SWF load is complete
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: starting install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Scheduling runtime installation operations
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: starting install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Scheduling runtime installation operations
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Beginning runtime installation
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Beginning runtime installation
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Beginning install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Beginning install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:36 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:36 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:42 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:01:42 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:45 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:45 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Rollback due to error complete
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Rollback due to error complete
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: begin quitting
Oct 15 12:02:07 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: begin quitting
Oct 15 12:02:07 MacBook-Pro com.apple.launchd.peruser.501[93] ([0x0-0xa20a2].com.adobe.air.Installer[1170]): Exited with exit code: 7
Oct 15 12:02:14 MacBook-Pro com.apple.launchd.peruser.501[93] (com.apple.AirPortBaseStationAgent[120]): Exited: Killed
Oct 15 12:03:30 MacBook-Pro AirDisplayStatusItem[125]: Launch pref pane status: 0
Oct 15 12:03:44 MacBook-Pro ScreenCapture[126]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 15 12:03:44 MacBook-Pro AirDisplayStatusItem[125]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 15 12:03:58 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Performing runtime install
Oct 15 12:03:59 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: UI SWF load is complete
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: UI initialized
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: starting user confirmation
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Version of this installer: 2.0.4.13090
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Installation type: new
Oct 15 12:04:03 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: starting elevated install
Oct 15 12:04:09 MacBook-Pro authexec[178]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: performing an elevated runtime install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: UI SWF load is complete
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: starting install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Scheduling runtime installation operations
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: starting install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Scheduling runtime installation operations
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Beginning runtime installation
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Beginning runtime installation
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Beginning install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Beginning install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:04:13 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:13 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:21 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:04:21 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Rollback due to error complete
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Rollback due to error complete
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: begin quitting
Oct 15 12:04:37 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: begin quitting
Oct 15 12:04:37 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x13013].com.adobe.air.Installer[170]): Exited with exit code: 7
Oct 15 12:06:51 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Performing runtime install
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: UI SWF load is complete
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: UI initialized
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: starting user confirmation
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Version of this installer: 2.0.4.13090
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Installation type: new
Oct 15 12:06:54 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: starting elevated install
Oct 15 12:07:01 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Launching elevated sub-installer failed
Oct 15 12:07:01 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
Oct 15 12:07:03 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: begin quitting
Oct 15 12:07:03 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x1d01d].com.adobe.air.Installer[206]): Exited with exit code: 7
Oct 15 12:07:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Performing runtime install
Oct 15 12:07:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: UI SWF load is complete
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: UI initialized
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: starting user confirmation
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Version of this installer: 2.0.4.13090
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Installation type: new
Oct 15 12:07:34 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: starting elevated install
Oct 15 12:07:49 MacBook-Pro authexec[221]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: performing an elevated runtime install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: UI SWF load is complete
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: starting install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Scheduling runtime installation operations
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: starting install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Scheduling runtime installation operations
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Beginning runtime installation
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Beginning runtime installation
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Beginning install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Beginning install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:07:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:07:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:08:04 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 12:08:04 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 12:08:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:08:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:08:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Rollback due to error complete
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Rollback due to error complete
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: begin quitting
Oct 15 12:08:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: begin quitting
Oct 15 12:08:23 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x1f01f].com.adobe.air.Installer[217]): Exited with exit code: 7
Oct 15 12:10:04 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Performing runtime install
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: UI SWF load is complete
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: UI initialized
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: starting user confirmation
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Version of this installer: 2.0.4.13090
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Installation type: new
Oct 15 12:10:11 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: starting elevated install
Oct 15 12:10:15 MacBook-Pro authexec[242]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: performing an elevated runtime install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: UI SWF load is complete
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: starting install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Scheduling runtime installation operations
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: starting install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Scheduling runtime installation operations
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Beginning runtime installation
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Beginning runtime installation
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Beginning install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Beginning install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 12:10:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:37 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:37 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Rollback due to error complete
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Rollback due to error complete
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: begin quitting
Oct 15 12:10:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: begin quitting
Oct 15 12:10:49 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x25025].com.adobe.air.Installer[239]): Exited with exit code: 7
Oct 15 12:11:18 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Performing runtime install
Oct 15 12:11:18 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: UI SWF load is complete
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: UI initialized
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: starting user confirmation
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Version of this installer: 2.0.4.13090
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Installation type: new
Oct 15 12:11:21 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: starting elevated install
Oct 15 12:11:27 MacBook-Pro authexec[264]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: performing an elevated runtime install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: UI SWF load is complete
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: starting install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Scheduling runtime installation operations
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: starting install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Scheduling runtime installation operations
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Beginning runtime installation
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Beginning runtime installation
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Beginning install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Beginning install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:11:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:11:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:41 MacBook-Pro SystemUIServer[99]: Invalid kMDItemPath for Adobe AIR Application Installer
Oct 15 12:11:41 MacBook-Pro SystemUIServer[99]: problem with path Adobe AIR Application Installer
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Rollback due to error complete
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Rollback due to error complete
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: begin quitting
Oct 15 12:11:58 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: begin quitting
Oct 15 12:11:58 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x28028].com.adobe.air.Installer[260]): Exited with exit code: 7
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Performing runtime install
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: UI SWF load is complete
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: UI initialized
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: starting user confirmation
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Version of this installer: 2.0.4.13090
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Installation type: new
Oct 15 12:17:22 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: starting elevated install
Oct 15 12:17:25 MacBook-Pro authexec[309]: executing /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: performing an elevated runtime install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: UI SWF load is complete
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: starting install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Scheduling runtime installation operations
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: starting install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Scheduling runtime installation operations
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Beginning runtime installation
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Beginning runtime installation
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Beginning install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Beginning install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp12/temp
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp12/temp
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:36 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp13/temp
Oct 15 12:17:36 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp13/temp
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp14/temp
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp14/temp
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:50 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:50 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Rollback due to error complete
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Rollback due to error complete
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: begin quitting
Oct 15 12:17:54 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: begin quitting
Oct 15 12:17:54 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x2f02f].com.adobe.air.Installer[304]): Exited with exit code: 7
Oct 15 12:18:39 MacBook-Pro com.apple.launchd.peruser.501[94] (com.apple.AirPortBaseStationAgent[118]): Exited: Killed
Oct 15 12:20:04 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Performing runtime install
Oct 15 12:20:04 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: UI SWF load is complete
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: UI initialized
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: starting user confirmation
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Version of this installer: 2.0.4.13090
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Installation type: new
Oct 15 12:20:11 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: starting elevated install
Oct 15 12:20:17 MacBook-Pro authexec[138]: executing /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: performing an elevated runtime install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: UI SWF load is complete
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: starting install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Scheduling runtime installation operations
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: starting install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Scheduling runtime installation operations
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Beginning runtime installation
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Beginning runtime installation
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Beginning install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Beginning install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:25 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:20:25 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:45 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:45 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Rollback due to error complete
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Rollback due to error complete
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: begin quitting
Oct 15 12:21:01 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: begin quitting
Oct 15 12:21:01 MacBook-Pro com.apple.launchd.peruser.501[89] ([0x0-0xe00e].com.adobe.air.Installer[132]): Exited with exit code: 7
Oct 15 12:24:23 MacBook-Pro ScreenCapture[121]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 15 12:24:23 MacBook-Pro AirDisplayStatusItem[120]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 15 13:06:15 MacBook-Pro AirDisplayStatusItem[120]: serverDisconnectedFromDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 15 13:06:15 MacBook-Pro AirDisplayStatusItem[120]: serverDisconnectedFromDeviceNotification: {\n}
Oct 15 13:06:36 MacBook-Pro ScreenCapture[121]: Screen: Air Display - bounds (1280.000000, 0.000000) - (1024.000000, 768.000000)
Oct 15 13:06:36 MacBook-Pro AirDisplayStatusItem[120]: serverConnectedToDeviceNotification: {\n    DeviceName = "iPad.local.";\n}
Oct 15, 2010 Oct 15, 2010
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: UI SWF load is complete
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: stateRunningAppInstaller: appinstaller -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,1,85,3 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://download.marketsamurai.com/MarketSamurai.0.87.3.air -- "installed from web"
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Starting app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: UI SWF load is complete
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: UI initialized
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: beginning UI styling
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: UI styling complete
Oct 15 11:54:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Unpackaging to /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp0
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: unpackaging/validation is complete
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: application is bound to this version of the runtime
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: app id MarketSamurai
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Application not located
Oct 15 11:54:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Waiting for user confirmation
Oct 15 11:55:01 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: User confirmed action: install
Oct 15 11:55:01 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: creating native installer in: /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp1
Oct 15 11:55:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: native installer creation complete
Oct 15 11:55:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: stateInstallingWithElevation: enter install
Oct 15 11:55:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: stateInstallingWithElevation: /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks" -silent -logToStdout -withRuntime -url -location /Applications -desktopShortcut -programMenu http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:05 MacBook-Pro authexec[1084]: executing /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: UI SWF load is complete
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: UI SWF load is complete
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: UI initialized
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: UI initialized
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:55:06 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: unpackaging/validation is complete
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: unpackaging/validation is complete
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: application is bound to this version of the runtime
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: app id MarketSamurai
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: application is bound to this version of the runtime
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: app id MarketSamurai
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Application not located
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Application not located
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:55:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: native installer creation complete
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: native installer creation complete
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Starting install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Starting install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Destination for installed application is /Applications
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Destination for installed application is /Applications
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Beginning install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Beginning install
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:55:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:55:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 11:55:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 11:55:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:55:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: Rollback due to error complete
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: Rollback due to error complete
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: subinstaller: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 11:55:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: starting cleanup of temporary files
Oct 15 11:55:27 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1084]: application installer exiting
Oct 15 11:55:47 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: starting cleanup of temporary files
Oct 15 11:55:48 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1080]: application installer exiting
Oct 15 11:55:48 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: App installer failed; exit code -1
Oct 15 11:55:48 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airuQww5t/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1079]: begin quitting
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: UI SWF load is complete
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: stateRunningAppInstaller: appinstaller -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,1,85,3 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://download.marketsamurai.com/MarketSamurai.0.87.3.air -- "installed from web"
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Starting app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: UI SWF load is complete
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: UI initialized
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: beginning UI styling
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: UI styling complete
Oct 15 11:55:56 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Unpackaging to /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp0
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: unpackaging/validation is complete
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: application is bound to this version of the runtime
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: app id MarketSamurai
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Application not located
Oct 15 11:55:59 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Waiting for user confirmation
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: User confirmed action: install
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: creating native installer in: /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp1
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: native installer creation complete
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: stateInstallingWithElevation: enter install
Oct 15 11:56:05 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: stateInstallingWithElevation: /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks" -silent -logToStdout -withRuntime -url -location /Applications -desktopShortcut -programMenu http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:56:08 MacBook-Pro authexec[1100]: executing /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: UI SWF load is complete
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: UI SWF load is complete
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: UI initialized
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: UI initialized
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:56:09 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: unpackaging/validation is complete
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: unpackaging/validation is complete
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: application is bound to this version of the runtime
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: app id MarketSamurai
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: application is bound to this version of the runtime
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: app id MarketSamurai
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Application not located
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Application not located
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:56:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: native installer creation complete
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: native installer creation complete
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Starting install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Starting install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Destination for installed application is /Applications
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Destination for installed application is /Applications
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Beginning install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Beginning install
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:56:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 11:56:15 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:15 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 11:56:16 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 11:56:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:20 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: Rollback due to error complete
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: Rollback due to error complete
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: subinstaller: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 11:56:29 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: starting cleanup of temporary files
Oct 15 11:56:30 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1100]: application installer exiting
Oct 15 11:56:35 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: starting cleanup of temporary files
Oct 15 11:56:36 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1097]: application installer exiting
Oct 15 11:56:36 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: App installer failed; exit code 7
Oct 15 11:56:36 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/air6Ey9Tl/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1096]: begin quitting
Oct 15 11:59:51 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: UI SWF load is complete
Oct 15 11:59:51 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: stateRunningAppInstaller: appinstaller -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks" -playerVersion=10,1,85,3 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -withRuntime -url http://download.marketsamurai.com/MarketSamurai.0.87.3.air -- "installed from web"
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Starting app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: UI SWF load is complete
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: UI initialized
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: beginning UI styling
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: UI styling complete
Oct 15 11:59:52 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Unpackaging to /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp0
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: unpackaging/validation is complete
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: application is bound to this version of the runtime
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: app id MarketSamurai
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Application not located
Oct 15 11:59:55 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Waiting for user confirmation
Oct 15 12:00:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: User confirmed action: install
Oct 15 12:00:02 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: creating native installer in: /private/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/TemporaryItems/FlashTmp1
Oct 15 12:00:03 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: native installer creation complete
Oct 15 12:00:03 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: stateInstallingWithElevation: enter install
Oct 15 12:00:03 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: stateInstallingWithElevation: /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer -runtime "/var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks" -silent -logToStdout -withRuntime -url -location /Applications -desktopShortcut -programMenu http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 12:00:07 MacBook-Pro authexec[1135]: executing /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Starting silent app install of http://download.marketsamurai.com/MarketSamurai.0.87.3.air
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: UI SWF load is complete
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: UI SWF load is complete
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: UI initialized
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: UI initialized
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 12:00:07 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Unpackaging to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: unpackaging/validation is complete
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: unpackaging/validation is complete
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: application is bound to this version of the runtime
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: app id MarketSamurai
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: application is bound to this version of the runtime
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: app id MarketSamurai
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: pub id 6E37012E1CBD7F47B14488FCC715944F3EBDCEDC.1
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Application not located
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Application not located
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 12:00:10 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: creating native installer in: /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: native installer creation complete
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: native installer creation complete
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Starting install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Starting install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: using conversion output in /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/Template
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Destination for installed application is /Applications
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Destination for installed application is /Applications
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Beginning install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Beginning install
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:11 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:12 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:13 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:00:14 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:17 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:25 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:25 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: Rollback due to error complete
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: Rollback due to error complete
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: subinstaller: stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: starting cleanup of temporary files
Oct 15 12:00:26 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1135]: application installer exiting
Oct 15 12:00:31 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: starting cleanup of temporary files
Oct 15 12:00:32 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1130]: application installer exiting
Oct 15 12:00:32 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: App installer failed; exit code 7
Oct 15 12:00:32 MacBook-Pro /var/folders/jE/jE6XYvyIG40xxBwfh3I6VU+++TI/-Tmp-/airlc9YQO/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1128]: begin quitting
Oct 15 12:01:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Performing runtime install
Oct 15 12:01:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: UI SWF load is complete
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: UI initialized
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: starting user confirmation
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Version of this installer: 2.0.4.13090
Oct 15 12:01:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Installation type: new
Oct 15 12:01:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: starting elevated install
Oct 15 12:01:32 MacBook-Pro authexec[1176]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: performing an elevated runtime install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: UI SWF load is complete
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: starting install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Scheduling runtime installation operations
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: starting install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Scheduling runtime installation operations
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Beginning runtime installation
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Beginning runtime installation
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Beginning install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Beginning install
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:36 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:36 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:39 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:42 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:01:42 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:44 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:45 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:45 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:01:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: Rollback due to error complete
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: Rollback due to error complete
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:01:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1176]: begin quitting
Oct 15 12:02:07 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1170]: begin quitting
Oct 15 12:02:07 MacBook-Pro com.apple.launchd.peruser.501[93] ([0x0-0xa20a2].com.adobe.air.Installer[1170]): Exited with exit code: 7
Oct 15 12:03:58 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Performing runtime install
Oct 15 12:03:59 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: UI SWF load is complete
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: UI initialized
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: starting user confirmation
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Version of this installer: 2.0.4.13090
Oct 15 12:04:00 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Installation type: new
Oct 15 12:04:03 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: starting elevated install
Oct 15 12:04:09 MacBook-Pro authexec[178]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: performing an elevated runtime install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: UI SWF load is complete
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: starting install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Scheduling runtime installation operations
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: starting install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Scheduling runtime installation operations
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Beginning runtime installation
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Beginning runtime installation
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Beginning install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Beginning install
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:04:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:04:13 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:13 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:17 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:21 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:04:21 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:04:24 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:25 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: Rollback due to error complete
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: Rollback due to error complete
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:04:33 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[178]: begin quitting
Oct 15 12:04:37 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[170]: begin quitting
Oct 15 12:04:37 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x13013].com.adobe.air.Installer[170]): Exited with exit code: 7
Oct 15 12:06:51 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Performing runtime install
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: UI SWF load is complete
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: UI initialized
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: starting user confirmation
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Version of this installer: 2.0.4.13090
Oct 15 12:06:52 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Installation type: new
Oct 15 12:06:54 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: starting elevated install
Oct 15 12:07:01 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: Launching elevated sub-installer failed
Oct 15 12:07:01 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
Oct 15 12:07:03 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[206]: begin quitting
Oct 15 12:07:03 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x1d01d].com.adobe.air.Installer[206]): Exited with exit code: 7
Oct 15 12:07:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Performing runtime install
Oct 15 12:07:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: UI SWF load is complete
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: UI initialized
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: starting user confirmation
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Version of this installer: 2.0.4.13090
Oct 15 12:07:32 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Installation type: new
Oct 15 12:07:34 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: starting elevated install
Oct 15 12:07:49 MacBook-Pro authexec[221]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: performing an elevated runtime install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: UI SWF load is complete
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: starting install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Scheduling runtime installation operations
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: starting install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Scheduling runtime installation operations
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Beginning runtime installation
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Beginning runtime installation
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Beginning install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Beginning install
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:07:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:07:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:07:53 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:07:56 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:08:04 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 12:08:04 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
Oct 15 12:08:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:08:09 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:10 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:08:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: Rollback due to error complete
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: Rollback due to error complete
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:08:20 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[221]: begin quitting
Oct 15 12:08:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[217]: begin quitting
Oct 15 12:08:23 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x1f01f].com.adobe.air.Installer[217]): Exited with exit code: 7
Oct 15 12:10:04 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Performing runtime install
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: UI SWF load is complete
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: UI initialized
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: starting user confirmation
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Version of this installer: 2.0.4.13090
Oct 15 12:10:05 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Installation type: new
Oct 15 12:10:11 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: starting elevated install
Oct 15 12:10:15 MacBook-Pro authexec[242]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: performing an elevated runtime install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: UI SWF load is complete
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: starting install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Scheduling runtime installation operations
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: starting install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Scheduling runtime installation operations
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Beginning runtime installation
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Beginning runtime installation
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Beginning install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Beginning install
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:15 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp6/temp
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:23 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 12:10:26 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp7/temp
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp8/temp
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:29 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:37 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:37 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: Rollback due to error complete
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: Rollback due to error complete
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:10:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[242]: begin quitting
Oct 15 12:10:49 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[239]: begin quitting
Oct 15 12:10:49 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x25025].com.adobe.air.Installer[239]): Exited with exit code: 7
Oct 15 12:11:18 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Performing runtime install
Oct 15 12:11:18 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: UI SWF load is complete
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: UI initialized
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: starting user confirmation
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Version of this installer: 2.0.4.13090
Oct 15 12:11:19 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Installation type: new
Oct 15 12:11:21 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: starting elevated install
Oct 15 12:11:27 MacBook-Pro authexec[264]: executing /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: performing an elevated runtime install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: UI SWF load is complete
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: starting install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Scheduling runtime installation operations
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: starting install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Scheduling runtime installation operations
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Beginning runtime installation
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Beginning runtime installation
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Beginning install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Beginning install
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:11:27 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:11:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:31 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp9/temp
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:35 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:11:38 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp10/temp
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp11/temp
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:41 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:41 MacBook-Pro SystemUIServer[99]: Invalid kMDItemPath for Adobe AIR Application Installer
Oct 15 12:11:41 MacBook-Pro SystemUIServer[99]: problem with path Adobe AIR Application Installer
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: Rollback due to error complete
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: Rollback due to error complete
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:11:50 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[264]: begin quitting
Oct 15 12:11:58 MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[260]: begin quitting
Oct 15 12:11:58 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x28028].com.adobe.air.Installer[260]): Exited with exit code: 7
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Performing runtime install
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: UI SWF load is complete
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: UI initialized
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: starting user confirmation
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Version of this installer: 2.0.4.13090
Oct 15 12:17:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Installation type: new
Oct 15 12:17:22 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: starting elevated install
Oct 15 12:17:25 MacBook-Pro authexec[309]: executing /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: performing an elevated runtime install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: UI SWF load is complete
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: starting install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Scheduling runtime installation operations
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: starting install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Scheduling runtime installation operations
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Beginning runtime installation
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Beginning runtime installation
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Beginning install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Beginning install
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:26 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp12/temp
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp12/temp
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:34 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:36 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp13/temp
Oct 15 12:17:36 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp13/temp
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp14/temp
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp14/temp
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: chown of /Library/Frameworks/Adobe AIR.framework completed with status -1
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:39 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:50 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:50 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: Rollback due to error complete
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: Rollback due to error complete
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:17:51 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[309]: begin quitting
Oct 15 12:17:54 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[304]: begin quitting
Oct 15 12:17:54 MacBook-Pro com.apple.launchd.peruser.501[94] ([0x0-0x2f02f].com.adobe.air.Installer[304]): Exited with exit code: 7
Oct 15 12:20:04 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Performing runtime install
Oct 15 12:20:04 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: UI SWF load is complete
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: UI initialized
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: starting user confirmation
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Version of this installer: 2.0.4.13090
Oct 15 12:20:05 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Installation type: new
Oct 15 12:20:11 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: starting elevated install
Oct 15 12:20:17 MacBook-Pro authexec[138]: executing /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: performing an elevated runtime install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: UI SWF load is complete
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: starting install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Scheduling runtime installation operations
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: starting install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Scheduling runtime installation operations
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Beginning runtime installation
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Beginning runtime installation
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Beginning install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Beginning install
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:17 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:19 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:23 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:25 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:20:25 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status 0
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:28 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Error occurred; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:45 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:45 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: Rollback due to error complete
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: Rollback due to error complete
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: subinstaller: error during install: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: Failed during elevated install: error 3010 Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Could not create directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
Oct 15 12:20:46 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[138]: begin quitting
Oct 15 12:21:01 MacBook-Pro /Users/danieltodd/Desktop/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[132]: begin quitting
Oct 15 12:21:01 MacBook-Pro com.apple.launchd.peruser.501[89] ([0x0-0xe00e].com.adobe.air.Installer[132]): Exited with exit code: 7
Oct 15, 2010 Oct 15, 2010
Did you get an error if you install AIR runtime from here? http://get.adobe.com/air
Hitomi
Please take a look at this forum thread. You may find a way to solve the problem.
http://forums.adobe.com/thread/207833
It is suggestiong couple things throughout the thread and one thing I recommend is:
Took a peek at the log file from  the install. Interesting:
Jul   9 20:27:24  /Volumes/Adobe AIR 1/Adobe AIR   Installer.app/Contents/MacOS/Adobe AIR Installer[1088]: error during   install: [ErrorEvent type="error" bubbles=false cancelable=false   eventPhase=2 text="Unhandled exception Error: Could not create   directory /Applications/Adobe/Flash Player/AddIns/airappinstaller" errorID=3010]
So  I went to the directory Applications  and found there was an old text  file called "Adobe". I renamed that text  file, than ran the Adobe AIR  installer and it WORKED!!!
Hitomi
Adobe Employee ,
We've also had issues with the permissions on the \Applications\Adobe folder.  I'm attaching a small applescript that you should be able to double click and authenticate and it will change the folder permissions automatically.  Please let me know if it helps.
Chris
Message was edited by: chris.campbell  Version 3 of the script.  Deletes adobe.txt file if present and unlocks /Users/Shared/Library/Application Support/Adobe
Oct 17, 2010 Oct 17, 2010
I unzipped the file, opened the .app file, put in the authorization when prompted but nothing happened. I then tried to reinstall the program but it is still giving me an error.
I restarted my computer and tried to install again the same issue is occurring.
Adobe Employee ,
Oct 18, 2010 Oct 18, 2010
Thanks for trying, I just updated the script again.  Would you mind giving it another shot?  If this doesn't work we can try manually renaming a few folders.
Chris
I don't see a new link to the updated script. I just tried to run the script again and it didn't work.
tell application "Finder"
do shell script "chmod -R ug=rwx,o=rx /Applications/Adobe" with administrator privileges
do shell script "chmod ug=rwx,o=rx ~/Library/'Application Support/Adobe'" with administrator privileges
do shell script "chmod ug=rwx,o=rx ~/Library/'Application Support/Adobe/AIR'" with administrator privileges
do shell script "chmod ug=rwx,o=rx /Users/Shared/Library/'Application Support/Adobe'" with administrator privileges
do shell script "chflags -R nouchg /Users/Shared/Library/'Application Support/Adobe'" with administrator privileges
do shell script "rm -f /Applications/Adobe/adobe.txt" with administrator privileges
end tell
error "Finder got an error: chmod: /Users/Shared/Library/Application Support/Adobe: No such file or directory" number 1
Adobe Employee ,
Oct 19, 2010 Oct 19, 2010
Ugh, sorry the script hasn't helped.  Would you be willing to do a desktop sharing session with me so I can take a look at your system?  If so, please email me at ccampbel@adobe.com.
Chris
Oct 20, 2010 Oct 20, 2010
I just sent you an email as well as my IM. The sooner we can get this done the better. It has been too long since I have been able to use Market Samurai.
Adobe Employee ,
This issue was resolved via a connect session with hawaii5point0, it ended up being caused by a bogus "/Applications/Adobe" file.  The AIR installer needs to install files and folders into the "/Applications/Adobe" folder.  Once this file was renamed (or deleted) the AIR install was able to complete successfully.
Thanks for your patience and I'm glad we were able to get you up and running!
Chris
Nov 19, 2010 Nov 19, 2010
Hi Chris,
your reply helps me to find out, why I got #2038 Adobe Air 2.5.1 installation errors on an OSX 10.6.5 I'm running (main user doesn't have admin privileges).
The error in Log files was this one:
Nov 19 11:28:42 yb-x /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1890]: Elevated install failed: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2038" errorID=2038]
I have the german Adobe Creative Suite 5 Design Standard and Adobe Creative Suite 5 Web Premium installed. A couple of days ago I installed a demo of Adobe Captivate 5 for MacOS, installation language was german. I think it brings the error.
I looked at the permissions inside ~/Library/Application Support/Adobe and noticed that the AIR folder was owned by root:
yb-x:~ yb$ ls -la ~/Library/Application\ Support/Adobe/
total 24
drwxrwxr-x  31 yb    staff  1054 17 Nov 11:47 .
drwx------  52 yb    staff  1768 17 Nov 13:05 ..
-rw-r--r--@  1 yb    staff  6148 11 Nov 10:11 .DS_Store
drwxrwxr-x   3 yb    staff   102  8 Sep 09:17 AAMUpdater
drwxr-xr-x   4 root  staff   136 19 Nov 10:45 AIR
drwxr-xr-x   4 yb    staff   136  8 Sep 12:39 Acrobat
drwxr-xr-x   3 yb    staff   102  5 Okt 17:22 Adobe Contribute CS5
drwxrwxr-x   2 root  staff    68  8 Sep 09:02 Adobe Device Central CS5
drwxrwxr-x   3 root  staff   102  8 Sep 15:03 Adobe Illustrator CS5
drwxr-xr-x   3 yb    staff   102 17 Nov 11:47 Adobe Illustrator CS5 Library
drwxr-xr-x   3 yb    staff   102  5 Okt 17:22 Adobe InDesign CS5
drwxr-xr-x   3 yb    staff   102 26 Okt 12:28 Adobe Media Player
drwxr-xr-x   3 yb    staff   102  8 Sep 09:17 Adobe PDF
drwxr-xr-x   4 yb    staff   136  8 Sep 14:04 Adobe Photoshop CS5
drwxr-xr-x  12 yb    staff   408  9 Nov 11:22 Bridge CS5
drwxrwxr-x   8 yb    staff   272  8 Sep 09:02 CS5ServiceManager
drwxr-xr-x   7 yb    staff   238  4 Okt 13:29 CameraRaw
drwxr-xr-x   5 yb    staff   170  8 Sep 12:46 Color
drwxr-xr-x   3 yb    staff   102  5 Okt 17:22 Common
drwxrwxr-x   3 root  staff   102  5 Okt 17:22 Dreamweaver CS5
drwxrwxr-x   4 root  staff   136  5 Okt 17:22 Extension Manager CS5
drwxrwxr-x   3 root  staff   102  5 Okt 17:22 Flash CS5
drwxrwxr-x   5 root  staff   170  8 Sep 09:05 Flash Catalyst
drwxr-xr-x   2 yb    staff    68  8 Sep 15:03 Fonts
drwxr-xr-x  27 yb    staff   918 16 Aug 11:39 Lightroom
drwxr-xr-x   3 yb    staff   102  8 Sep 12:39 Linguistics
drwxrwxr-x   3 yb    staff   102 22 Okt 16:02 LogTransport
drwxrwxr-x   3 yb    staff   102  8 Sep 09:23 LogTransport2
-rw-r--r--@  1 yb    staff     1 17 Nov 11:45 QuickTime
drwxr-xr-x   3 yb    staff   102  8 Sep 15:03 SING
drwxr-xr-x   3 yb    staff   102  4 Okt 13:31 XMP
So I correct the permissions with:
yb-x:~ yb$ sudo chown -R yb:staff ~/Library/Application\ Support/Adobe/AIR
And now Air was able to be installed without any error like all .air apps which didn't start before.
Thanks and regards,
Yann
Message was edited by: Yann Borg to correct error number (from 2048 to 2038)
Adobe Employee ,
Nov 29, 2010 Nov 29, 2010
Thanks Yann! I was hoping that just adjusting the permission levels would take care of the owner issue but I've added a special case for that folder and I'll make sure we address that in the runtime installer.
Chris
Nov 04, 2010 Nov 04, 2010
I am having exactly the same problem!!! Can SOMEONE PLEASE tell me STEP by STEP how to fix it!!
Adobe Employee ,
Please start by running the attached "AIR Install Repair" AppleScript included at the bottom of my post.  You'll be prompted for you password, but no other UI will appear.  The script takes less than a second to execute.  Once you've run that, try installing AIR again and see what happens.
If it still fails, can you please post the contents of your AIR installer log.  You can get the log by following these steps:
1. Open "Console" from your Applications/Utilities folder
2. If the log list on the left side of the window is not visible, click the "Show Log List" icon
3. Select "system.log" from the log list
4. In the filter box at the top right of the window, type in "AIR"
5. You should now be seeing all AIR releated system messages, do a select all, then copy/paste into the forum post.
Chris
Message was edited by: chris.campbell  Updates to AppleScript:
Rename the bogus "/Applications/Adobe file" to "/Applications/Adobe-backup" (if it exists).
Added step to correct owner issue for folder ~/Library/Application Support/Adobe/AIR
Moved "do shell script" commands out of the "tell" block to fix permission issues some users were encountering.
Nov 05, 2010 Nov 05, 2010
Hi Chris
Thanks!! The script thing didn't work but renaming the Adobe file did!! yaaaay!! AIr loaded fine after that.
Cheers!!
Dec 07, 2010 Dec 07, 2010
The Install Repair file seems to have done the job for me too. I have been struggling with this for a very long time and having to avoid using some apps.
Mar 11, 2011 Mar 11, 2011
Hi Chris, I'm wondering if you can help my by looking at my log files after unsuccessful attempts to reinstall Adobe Air after an uninstall. I had managed to reinstall it but then had no luck installing TweetDeck (I got as far as accepting where it would be saved, then a blank dialog box). So I uninstalled Air to start the process again and it just crashes when I try to run the installer.
I'd appreciate any advice you can give. Here are the log files:
cess with commandline /usr/sbin/chown -hfRP root:wheel "/Applications/Utilities/Adobe AIR Application Installer.app"
Mar 11 14:51:40 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/./Adobe AIR Installer[1653]: Subprocess chown succeeded
Mar 11 14:51:40 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/./Adobe AIR Installer[1653]: Launching subprocess with commandline /usr/sbin/chown -hfRP root:wheel "/Applications/Utilities/Adobe AIR Uninstaller.app"
Mar 11 14:51:41 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/./Adobe AIR Installer[1653]: Runtime Installer end with exit code 0
Mar 11 14:51:41 Natalia-Reddys-MacBook-Pro ./Adobe AIR Installer[1648]: Elevated install completed
Mar 11 14:51:56 Natalia-Reddys-MacBook-Pro ./Adobe AIR Installer[1648]: Launching subprocess with commandline /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater -installupdatecheck
Mar 11 14:51:56 Natalia-Reddys-MacBook-Pro ./Adobe AIR Installer[1648]: Runtime Installer end with exit code 0
Mar 11 14:51:58 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 14:51:58 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Commandline is: -installupdatecheck
Mar 11 14:51:58 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 14:51:58 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[1627]: Runtime Installer end with exit code 6
Mar 11 14:51:59 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Performing pingback request
Mar 11 14:51:59 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Pingback request completed with HTTP status 200
Mar 11 14:51:59 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Starting runtime background update check
Mar 11 14:51:59 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Begin Background update download from http://airdownload.adobe.com/air/3/background/macos/x86/patch/2.5.1.17750/update
Mar 11 14:51:59 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Unpackaging http://airdownload.adobe.com/air/3/background/macos/x86/patch/2.5.1.17750/update to /var/root/Library/Application Support/Adobe/AIR/Updater/Background
Mar 11 14:52:00 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Runtime update not available
Mar 11 14:52:00 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Unpackaging cancelled
Mar 11 14:52:00 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[1674]: Runtime Installer end with exit code 0
Mar 11 14:52:04 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x5b05b].com.adobe.air.Installer[1627]): Job appears to have crashed: Bus error
Mar 11 14:52:04 Natalia-Reddys-MacBook-Pro ReportCrash[1676]: Saved crash report for Adobe AIR Installer[1627] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Installer_2011-03-11-145204_Natalia-Reddys-MacBook-Pro.crash
Mar 11 14:53:57 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Application Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 14:53:57 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Commandline is: -playerVersion=10,2,152,33 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://downloads.tweetdeck.com/TweetDeck_0_37.5.air
Mar 11 14:53:57 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 14:53:58 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Begin air file download from http://downloads.tweetdeck.com/TweetDeck_0_37.5.air
Mar 11 14:53:58 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Download destination is /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp0
Mar 11 14:53:58 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Received download status 200
Mar 11 14:53:58 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Response URL is http://downloads.tweetdeck.com/TweetDeck_0_37.5.air
Mar 11 14:54:04 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Download success
Mar 11 14:54:06 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Unpackaging file:///private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp0 to /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp1
Mar 11 14:54:10 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Application signature verified
Mar 11 14:54:10 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Unpackaging/validation complete
Mar 11 14:54:10 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: No app located for appID 'TweetDeckFast' and pubID 'FFF259DC0CE2657847BBB4AFF0E62062EFC56543.1'
Mar 11 14:58:09 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Cancel request received
Mar 11 14:58:09 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1718]: Application Installer end with exit code 6
Mar 11 14:58:21 Natalia-Reddys-MacBook-Pro ReportCrash[1788]: Saved crash report for Adobe AIR Application Installer[1718] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Application Installer_2011-03-11-145821_Natalia-Reddys-MacBook-Pro.crash
Mar 11 14:58:29 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1800]: Application Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 14:58:29 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1800]: Commandline is: -psn_0_434282
Mar 11 14:58:29 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1800]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 14:58:44 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1800]: Cancel request received
Mar 11 14:58:44 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1800]: Application Installer end with exit code 6
Mar 11 14:58:45 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x6a06a].com.adobe.air.ApplicationInstaller[1800]): Exited with exit code: 6
Mar 11 15:00:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Application Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:00:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Commandline is: -playerVersion=10,2,152,33 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://apprepo.adobe.com/download/TweetDeckFast.air
Mar 11 15:00:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:00:02 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Begin air file download from http://apprepo.adobe.com/download/TweetDeckFast.air
Mar 11 15:00:02 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Download destination is /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp1
Mar 11 15:00:03 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Received download status 200
Mar 11 15:00:03 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Response URL is http://apprepo.adobe.com/download/TweetDeckFast.air
Mar 11 15:00:18 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Download success
Mar 11 15:00:33 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Unpackaging file:///private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp1 to /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp2
Mar 11 15:00:35 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Application signature verified
Mar 11 15:00:35 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Unpackaging/validation complete
Mar 11 15:00:35 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: No app located for appID 'TweetDeckFast' and pubID ''
Mar 11 15:01:14 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Cancel request received
Mar 11 15:01:14 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[1828]: Application Installer end with exit code 6
Mar 11 15:05:32 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Application Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:05:32 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Commandline is: -playerVersion=10,2,152,33 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://apprepo.adobe.com/download/TweetDeckFast.air
Mar 11 15:05:32 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:05:33 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Begin air file download from http://apprepo.adobe.com/download/TweetDeckFast.air
Mar 11 15:05:33 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Download destination is /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp2
Mar 11 15:05:36 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Received download status 200
Mar 11 15:05:36 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Response URL is http://apprepo.adobe.com/download/TweetDeckFast.air
Mar 11 15:05:51 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Download success
Mar 11 15:06:03 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2025]: Application Installer end with exit code 0
Mar 11 15:06:10 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Application Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:06:10 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Commandline is: /Users/nataliamacbook/Desktop/TweetDeckFast.air
Mar 11 15:06:10 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:06:11 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Unpackaging file:///Users/nataliamacbook/Desktop/TweetDeckFast.air to /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp2
Mar 11 15:06:13 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Application signature verified
Mar 11 15:06:13 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Unpackaging/validation complete
Mar 11 15:06:13 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: No app located for appID 'TweetDeckFast' and pubID ''
Mar 11 15:08:49 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Cancel request received
Mar 11 15:08:49 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2061]: Application Installer end with exit code 6
Mar 11 15:09:06 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2153]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:09:06 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2153]: Commandline is: -psn_0_491640
Mar 11 15:09:06 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2153]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:09:09 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2153]: Launching subprocess with commandline /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater -installupdatecheck
Mar 11 15:09:09 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2153]: Runtime Installer end with exit code 0
Mar 11 15:09:09 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:09:09 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Commandline is: -installupdatecheck
Mar 11 15:09:09 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Performing pingback request
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Starting runtime background update check
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Begin Background update download from http://airdownload.adobe.com/air/3/background/macos/x86/patch/2.5.1.17750/update
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Unpackaging http://airdownload.adobe.com/air/3/background/macos/x86/patch/2.5.1.17750/update to /Users/nataliamacbook/Library/Application Support/Adobe/AIR/Updater/Background
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Runtime update not available
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Unpackaging cancelled
Mar 11 15:09:10 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2157]: Runtime Installer end with exit code 0
Mar 11 15:09:22 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x76076].com.adobe.air.ApplicationInstaller[2061]): Job appears to have crashed: Bus error
Mar 11 15:09:23 Natalia-Reddys-MacBook-Pro ReportCrash[2132]: Saved crash report for Adobe AIR Application Installer[2061] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Application Installer_2011-03-11-150923_Natalia-Reddys-MacBook-Pro.crash
Mar 11 15:09:24 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2162]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:09:24 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2162]: Commandline is: -psn_0_503931
Mar 11 15:09:24 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2162]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:09:29 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2162]: Launching subprocess with commandline /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater -installupdatecheck
Mar 11 15:09:29 Natalia-Reddys-MacBook-Pro /Applications/Adobe/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2162]: Runtime Installer end with exit code 0
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Commandline is: -installupdatecheck
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Performing pingback request
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Starting runtime background update check
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Begin Background update download from http://airdownload.adobe.com/air/3/background/macos/x86/patch/2.5.1.17750/update
Mar 11 15:09:30 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Unpackaging http://airdownload.adobe.com/air/3/background/macos/x86/patch/2.5.1.17750/update to /Users/nataliamacbook/Library/Application Support/Adobe/AIR/Updater/Background
Mar 11 15:09:31 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Runtime update not available
Mar 11 15:09:31 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Unpackaging cancelled
Mar 11 15:09:31 Natalia-Reddys-MacBook-Pro /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[2168]: Runtime Installer end with exit code 0
Mar 11 15:10:01 Natalia-Reddys-MacBook-Pro SubmitDiagInfo[2182]: Submitted crash report: /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Application Installer_2011-03-11-150923_Natalia-Reddys-MacBook-Pro.crash
Mar 11 15:10:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Application Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:10:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Commandline is: /Users/nataliamacbook/Desktop/TweetDeckFast.air
Mar 11 15:10:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:10:02 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Unpackaging file:///Users/nataliamacbook/Desktop/TweetDeckFast.air to /private/var/folders/GL/GLLciMNLFVyzxCpvXphh1U+++TM/TemporaryItems/FlashTmp2
Mar 11 15:10:03 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Application signature verified
Mar 11 15:10:03 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Unpackaging/validation complete
Mar 11 15:10:03 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: No app located for appID 'TweetDeckFast' and pubID ''
Mar 11 15:10:31 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Cancel request received
Mar 11 15:10:31 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[2199]: Application Installer end with exit code 6
Mar 11 15:10:32 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x7f07f].com.adobe.air.ApplicationInstaller[2199]): Job appears to have crashed: Bus error
Mar 11 15:10:32 Natalia-Reddys-MacBook-Pro ReportCrash[2212]: Saved crash report for Adobe AIR Application Installer[2199] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Application Installer_2011-03-11-151032_Natalia-Reddys-MacBook-Pro.crash
Mar 11 15:15:52 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:15:52 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Commandline is: -psn_0_544901
Mar 11 15:15:52 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:15:57 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Relaunching with elevation
Mar 11 15:15:57 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Launching subprocess with commandline /Applications/Utilities/Adobe AIR Uninstaller.app -eu
Mar 11 15:15:59 Natalia-Reddys-MacBook-Pro authexec[2381]: executing /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer
Mar 11 15:16:00 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2381]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:16:00 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2381]: Commandline is: -eu
Mar 11 15:16:00 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2381]: Installed runtime (2.5.1.17750) located at /Library/Frameworks/Adobe AIR.framework
Mar 11 15:16:01 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2381]: Starting runtime uninstall. Uninstalling runtime version 2.5.1.17750
Mar 11 15:16:42 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2381]: Runtime Installer end with exit code 0
Mar 11 15:16:42 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Elevated install completed
Mar 11 15:16:42 Natalia-Reddys-MacBook-Pro /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/MacOS/Adobe AIR Installer[2374]: Runtime Installer end with exit code 0
Mar 11 15:21:33 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2582]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:21:33 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2582]: Commandline is: -psn_0_581774
Mar 11 15:21:33 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2582]: No installed runtime detected
Mar 11 15:22:10 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2582]: Runtime Installer end with exit code 6
Mar 11 15:22:10 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x8e08e].com.adobe.air.Installer[2582]): Job appears to have crashed: Bus error
Mar 11 15:22:10 Natalia-Reddys-MacBook-Pro ReportCrash[2613]: Saved crash report for Adobe AIR Installer[2582] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Installer_2011-03-11-152210_Natalia-Reddys-MacBook-Pro.crash
Mar 11 15:23:34 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2661]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:23:34 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2661]: Commandline is: -psn_0_606356
Mar 11 15:23:34 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2661]: No installed runtime detected
Mar 11 15:23:43 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2661]: Runtime Installer end with exit code 6
Mar 11 15:23:46 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x94094].com.adobe.air.Installer[2661]): Exited: Killed
Mar 11 15:25:04 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2723]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:25:04 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2723]: Commandline is: -psn_0_614550
Mar 11 15:25:04 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2723]: No installed runtime detected
Mar 11 15:25:50 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2723]: Runtime Installer end with exit code 6
Mar 11 15:25:50 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x96096].com.adobe.air.Installer[2723]): Job appears to have crashed: Bus error
Mar 11 15:25:50 Natalia-Reddys-MacBook-Pro ReportCrash[2745]: Saved crash report for Adobe AIR Installer[2723] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Installer_2011-03-11-152550_Natalia-Reddys-MacBook-Pro.crash
Mar 11 15:31:43 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2927]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 15:31:43 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2927]: Commandline is: -psn_0_643229
Mar 11 15:31:43 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2927]: No installed runtime detected
Mar 11 15:32:37 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[2927]: Runtime Installer end with exit code 6
Mar 11 15:32:40 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0x9d09d].com.adobe.air.Installer[2927]): Exited: Killed
Mar 11 16:00:45 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[3837]: Runtime Installer begin with version 2.5.1.17750 on Mac OS 10.6.6 x86
Mar 11 16:00:45 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[3837]: Commandline is: -psn_0_716975
Mar 11 16:00:45 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[3837]: No installed runtime detected
Mar 11 16:01:09 Natalia-Reddys-MacBook-Pro /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[3837]: Runtime Installer end with exit code 6
Mar 11 16:01:16 Natalia-Reddys-MacBook-Pro com.apple.launchd.peruser.502[120] ([0x0-0xaf0af].com.adobe.air.Installer[3837]): Job appears to have crashed: Bus error
Mar 11 16:01:17 Natalia-Reddys-MacBook-Pro ReportCrash[3850]: Saved crash report for Adobe AIR Installer[3837] version 2.5.1 (2.5.1.17750) to /Users/nataliamacbook/Library/Logs/DiagnosticReports/Adobe AIR Installer_2011-03-11-160117_Natalia-Reddys-MacBook-Pro.crash
Adobe Employee ,
Hi Natalia,
I'm sorry you're running into this issue trying to install TweetDeck.  Out of curiosity, is this the only AIR application that you're encountering problems with?  Would you mind trying to install another app (eg. http://www.twhirl.org/)  to see if it also fails?
In addition, could you send me the Adobe AIR Installer crash logs found in your /Users/nataliamacbook/Library/Logs/DiagnosticReports/ folder?  Please feel free to attach to a post here or you can email me directly at ccampbel@adobe.com
Chris
Jul 09, 2011 Jul 09, 2011
Thanks so much! I am cluless with computers and now could install Adobe Air (and YNAB!) through your script and help!!!!!
