I have two pages in Illustrator and I want to create a 2 page PDF file. In CS3 there was a multiple page PDF selection I could make in the save dialogue box of my Illustrator file. That feature is not there in Illustrator CS5. Is it possible to do this??
Thanks in advance
Sarah
You simply use the "Use Artboards" option.
Mylenium
Mylenium
I might need a bit more info, I don't use "art boards" I use an art board and
create multi pages within that one artboard. So, I would create several art boards then save as a pdf?
Seems more complicated then simply clicking an option. I will try it though,
Thank you.
sarah
Thank you.
sarah
Not really...just think of it as Page=Artboard. So,
I. If you're creating a new file to save as a multi-page PDF, in the new file dialogue choose the number of Artboards to equal the number of pages. If unsure at the outset, just choose a sufficient number... you can always add or delete later. Give the Artboard/s the size of the page you want... eg A4, A5, or custom, etc., etc. Create the matter of each page on that number artboard.
II. If you're working with an existing file, then you already have the pages created on your single artboard. So:
1. Just resize the artboard to the output size
2. Move all matter of page one to that
3 Create new artboards (2, 3, 4, etc) and just move all mater corresponding to the already created pages 2, 3, 4, etc. to the respective artboards...
As everyone is suggesting make a change and use multiple artboards you have less problems and methods or reorganizing them that yu do not have with tiling.You have much bettercontrol over bleed area wihout being dependent on what is on the next tile, etc.
You will be much happier with artboards.
For multifile PDFS The use artboards option in in the place where you write the file name, not in the general pane. Also don't be like me and accidentally select only one artboard when I wanted multipages.
The solution for me, although clumsy and time consuming, was to select Adobe Postscript file in the printer drop down menu of my printer dialogue box. This creates a .ps file on my desktop which I then open in acrobat and save as a pdf file. It saves the page tiling settings from Illustrator then.
As I am more comfortable working on one artboard I needed a solution that worked within that restriction, this worked for me.
Sarah
Its explained all here
http://tv.adobe.com/watch/illustrator-cs5-feature-tour/multiple-artboard-enhancements/
I'm having the same problem! And that suggestion of using artboards instead of page tiling won't work in mi case, because I have to create a 126 page pdf, and you can only have 100 artboards in Illustrator...
So, is there any other way to to this besides changing to artboards?
You'll have more fun when doing all these pages in a layout software.
What if I don't have any layout software available? Right now I can only work with Illustrator and Photoshop... Any idea of what can I do?
You have to make more than one document then and add the pages in Acrobat.
I divided the PDF into 126 Illustrator files and put them in one folder, then I opened that folder with Bridge and found how to convert it into a PDF under "Output" (F4) options. That worked out perfectly!
I'm posting this in case someone has the same problem, this an alternative solution.
Thank you anyway for the sugestions!
Pamelissha, How exactly did you do this?
No one seems to be helpful enough to show us how to create everything, and your idea seems so much easier. Could you elaborate a little?
You say you just made an ai file for each page, then put them all into one folder, and then opened all the files in acrobat and created a multipage pdf... ? Could you please give specifics?
Forget it - I figured it out - it is quite simple! Thanks
