Good news Rachel!
I haven't actually tested your theory about setting the site to permalinks first. Could work and I might look at that later today myself. One thing I noticed was changing permalinks back to default and then back again to let's say day name, they would keep the same link values. At least on small test site.
Cheers
Michael
To any Joomla users that are managing to get live view to work but can't get it to discover dynamic files, I think I found the problem, Rachels post made me think....if permalinks in Wordpress cause a problem, I wonder if enabling SEO in config does the same?
I'm sort of glad to say taht if you untick the seo stuff in teh global configuration, everything works and all files are properly discovered in DW5 ![]()
Just a minor bug taht hopefully they will sort
I have got that problem, is there any fix?
Concise problem statement:
Using CS5 connect with Wordpress 3.0.1 and 2.7
Error found when attempted to "Discover dynamically-related files" when "Permalinks setting" is not in default "Ugly" mode.
Steps to reproduce bug:
1. Turn on Permalink setting ("Pretty Permalink") in wordpress dashboard
2. Work with DW CS5, with the localhost properly defined and appropriate "Site" defined in DW
3. Open index.php file in the "site root"
4. Click "Discover dynamically-related files..."
Results:Dynamically-related files could not be resolved because the site definition is not correct for this server
Expected results:
When I turn off "Pernalink setting" back to "Default" setting, DW has no problem and all Dynamically-related files can be found.
Remark: Pretty Permanlink function properly in wordpress links.
Is there any fix?
thanks
Bruce
I am also having these issues, but changing the permalimk settings didn't seem to do it for me because they were already set to default.
but one thing I need to be clear on is this:
when using the wordpress files in dreamweaver, do I need to set up a new site definition just for the wordpress blog? like for editing them in dreamweaver?
or is it ok to simply add on another testing server to the remote server I already have for my whole site?
you see my site is not just a blog, the blog is only a part of it cuz I also have a bunch of nav buttons for home page, videos, pictures etc. and whenever I see tutorials on how to bring wordpress into dreamweaver, they always make a brand new site definition in dreamweaver as if its the only thing in the site which is unlike mine, because the blog is among many other pages.
any help would be appreciated, thanks!
Hi there,
In my case, DW only likes workpress "Ugly" link (default) setting. If it's doesn't work for you, there may have setting problems in site definition.
In your case, I think you only need to create ONE site definition even you host more than one wordpress in the same site root. But the site need to be properly defined:
you can follow this:
http://www.youtube.com/watch?v=KPpjuievC04
Just take a look at site definition setting.
From experience:
A. NO, only One site definition is enough... but technically, you can create a site definition for your wordpress only.
A. for web development, it's always good to set up a testing server, and one testing server is enough.
A. Take a look at tutorial video from lydia:
http://www.youtube.com/watch?v=exSNc_t3jVU
http://www.youtube.com/watch?v=JoEvTGCgmnU
there example project is exactly what you are looking for, the wordpress blog is only part of the feature ofthe whole website.
hope can help you.
bruce
hi,
my work around of this issue:
1. if you are working with "pretty" permalink, you need to switch back to "Ugly" default setting in wordpress first.
2. Open DW and click discover dynamically-related files button
3. DW will find all the related file
4. Go back to wordpress dashboard, change the pemalink setting from "Ugly" to "Pretty" mode again.
5. Go back to DW, and now you can work with DW will "Pretty" permalink feature enabled.
hope adobe will have a better fix on this issue, but we can try out this work around method.
Bruce
OK I FINALLY GOT IT!!!!!!!!!!!!!
yes!!
I found out the only issue I was having was that the web URL on my Remote Server was wrong, I always had it http://www.MYDOMAIN.com because I thought thats what I was supposed to do, but I was watching more tutorials and realized that doesnt have to be because I always seen them put their web URL for the local info in the advanced section as http://localhost/DATABASENAME/ and since they have to be the same thing thats why I was confused. so I changed my web URL of the remote server to be the http://localhost/DATABASENAME/ one and miraculasly it worked!
so now that thats out of the way, is the purpose of opening the wordpress files in dreamweaver to actually edit the blog posts or is it just to change the styling and stuff like that?
Hi Jordan,
You definitely wouldn't edit blog posts inndreamweaver, just the design. Use the wordpress admin to edit and add new posts.
Rachel.
Rachel McCollin
07858 378178
www.compass-design.co.uk
websites - site maintenance - promotional materials - business stationery
I can't beleive that it's just pretty permalinks choking up DW... Well, CS5 improve on CS4... Hopefully CS6 can handle multiple virtual hosts (and DocumentRoots) and htaccess's at the same time! (with perhaps xampp or some sollution bundled and managing the host file for us! LOL)
Also, check out the second answer here and the link to here for sollutions to running more then one testing site.
I really am hoping that the next version has built in management for this (or some nifty CS5 Extension that I could easily install...)
this is the kind of response i call expert response....
I was forced to logon and comment to his solution....
Just so everyone knows....even today DW cant fix this bug and after trying to search for almost 2 days i came to this page and it was a bug of dreamweaver which was not letting me do discover.....
Some one in adobe DW QA team should get fired for that, almost 6 months over and still such a suily bug exists without an open article explaining the bug atleast....
I am seriously furious that DW is hiding bugs...it should be atleast open to all that this is how you fix discover issue ....
I understand the frustration, Prakash. While this is certainly an issue, I'm not sure that it's fair to call it a bug in Dreamweaver. Wordpress is artificially generating pretty URLs that are different than the actual record indexes for the posts and pages stored in the database. This is functionality that is in the Wordpress code and would require an entirely new level of functionality in Dreamweaver rather than some kind of "bug fix." (An analogous situation, if you have a Wordpress site online, occurs if you change its permalink settings. All the search-engine-indexed pointers to the site will fail, because they have the now-obsolete URLs. That's not a bug in the search engines, although it certainly is a problem.)
You can work with generic permalinks on your testing server and pretty-permalinks on your remote site without issue, since it's a Wordpress dashboard setting, not a change to the existing page or post database records, so it's not a major practical hurdle. I certainly prefer having DW able to handle dynamically linked files now than have the DW team wait until they added pretty-permalink handling before releasing the functionality.
I tried the Permalink fix and it didn't work. Then I realized that I hadn't made all of the necessary Settings changes after copying a live WordPress site to my local test server.
It turns out that he WP site address URL in WordPress General Settings must match the Web URL for the testing server in Dreamweaver.
Once I set these appropriately (and reverted Permalinks to Default), it started working properly.
So, if you're having this issue with WordPress, check to make sure that the site URLs are the same in both WordPress General Settings and in the test server configuration in Dreamweaver:
For other Dreamweaver users who need help setting up a testing server and getting WordPress to work in Dreamweaver without the problems discussed above I have written this tutorial
http://www.webdesignforbeginners.info/dreamweaver-and-wordpress/
Theo
