BlazeDS serialization question
Oct 25, 2010 5:29 AM
I recently came into a situation when sending a nested object from Java to Flex via a HashMap the Objects were null. More precisely:
final Map<Integer, List<String>> tempMap = new HashMap<Integer, List<String>>();
would send the keys as integers but the values were all null.
But when sending the same with String keys:
final Map<String, List<String>> tempMap = new HashMap<String, List<String>>();
the objects came thru.
Are there any restrictions in BlazeDS serialization when using complex types as keys?
    Dec 21, 2011 3:55 AM   in reply to FidelGonzo
    Just in case anyone is still looking for an answer to this issue, I just ran into the same problem.  During my investigation, I learned that BlazeDS serialization is expecting only String key values for Map objects.   Since the Map coming in has Integer keys, the key is changed to a string by the serialization.  At that point, the value cannot be obtained and serialized.  Change the Integer key to a String and it works.  Here is the site that helped me get it working.
    http://agricola-online.blogspot.com/2010/01/hibernate-blazeds-java-5-e num-and-flex.html
