Using Squiggly with Spark TextArea causes TLF formatting to disappear
Oct 22, 2010 8:29 AM
We are using a Spark TextArea component in our application to offer more enhanced text formatting options to our users. Yesterday we downloaded Squiggly since it's the only one available that seems to support the spark components. It is highlighting misspelled words correctly and does have a nice right-click context menu with suggestions, etc. However, when we select a word from the suggestion list and it replaces it in the text area, it seems to replace the entire contents of the textarea as plain text. Any formatting on the text such as bold, italics, font sizes, underlines, all immediately disappear once the misspelled word is replaced. We're using the SpellUI implementation. Below is some of the snippets of the code we're using to implement SpellUI:
protected function createTextArea():void {
  _textArea = new TextArea();
  _textArea.editable = true;
  _textArea.enabled = true;
  _textArea.textFlow = TextConverter.importToFlow(XML(dataModel.value)[0], TextConverter.TEXT_LAYOUT_FORMAT);
  _textArea.textFlow.flowComposer.updateAllControllers();
  _textArea.addEventListener(FlexEvent.CREATION_COMPLETE, setupSpellCheck, false, 0, true);
private function setupSpellCheck(event:Event=null):void {
  logger.debug("setupSpellCheck", "Setting up spell check system...");
  _textArea.removeEventListener(FlexEvent.CREATION_COMPLETE, setupSpellCheck);
  resourceManager.localeChain = [localeStr];
  enableSpellCheck();
  enableSpellCheckContextMenu();
private function enableSpellCheck():void {
  SpellUI.enableSpelling(_textArea, localeStr);
private function enableSpellCheckContextMenu():void {
  var contextMenu:Object = {add:resourceManager.getString('SquigglyContextMenu', 'add'),
                                         enable:resourceManager.getString('SquigglyContextMenu', 'enable'),
                                         disable:resourceManager.getString('SquigglyContextMenu', 'disable')};
  SpellUI.setSpellingMenuEntries(contextMenu);
As you can see, we're constructing a new TextArea control and setting it's textFlow by importing an existing textflow XML that we have saved in our database. Once the TextArea has dispatched the FlexEvent.CREATION_COMPLETE, we are setting up the spell check system and everything works ok until you actually correct a misspelled word by selecting it from the right-click suggestions list. The text initially imported may have any number of styles applied to it as I mentioned above. Once the spelling replacement occurs, all the formatting is wiped out for the entire text area.
Any thoughts?
-Jason Kringen
    Oct 23, 2010 5:23 PM   in reply to JKringen
    I've got the same problem with the text flow. Everything disappears once the correct word is selected. Any suggestions to get over the problem is highly appreciated.
    Oct 26, 2010 1:08 PM   in reply to JKringen
    Currently the support for TLF is limited. Text replacement doesn't work well when the TextArea has rich formatted text. The Squiggly dev team will continue to improve the support for TLF and Spark components.
    As for workaround, you can try to use the non-UI SpellChecker class with your own UI handling code.
    Feb 28, 2011 4:23 PM   in reply to Xie Fang
    We have recently released Squiggly 0.5 which has native TLF support, along with fixes to Spark component formatting issues.
    Please give it a try and let us know if it meets your needs.
    - Bruce, Adobe
