Found how in Photoshop... but can you in InDesign, Illustrator etc?
Sorry, I don't believe there's any way to remove it (the setting in Photoshop is the exception).
Just curious - what is it about this particular item that motivates you to want to remove it? Are there other items that appear in your applications' interface that are equally annoying, or is there something special about this one?
No, it is actually the presence of the button. It would stop all the questions and help requests. This is just a test rollout we are doing and this is taking up too much help desk time. The other sites have many more users. If we can deploy with no button, it would not be an issue. I'd like to disable the entire functionality of CS Live and remove it from the menu as well.
Any ideas?
It's possible to disable network access, but there's no provision to remove the CS Live menu itself (at least not from InDesign or Illustrator - Photoshop does include an option to show/hide the CS Live menu in its Plug-Ins preferences).
Network access (for Photoshop, InDesign or Illustrator) can be disabled by editing a plist (Mac) or registry entry (Windows), but CS Live menu will still be there. If you disable network access, then the first item on the CS Live menu will say "Access to CS Live Services has been disabled".
Am 13.05.2010 19:23, schrieb David Herman - Adobe:
Network access (for Photoshop, InDesign or Illustrator) can be disabled by editing a plist (Mac) or registry entry (Windows), but CS Live menu will still be there. If you disable network access, then the first item on the CS Live menu will say "Access to CS Live Services has been disabled.
Hi David,
Bummer! I'd really appreciate to get an option to actually remove the
Button in a Service release. Which Registry-Key do I have to edit?
This is perfect. Thanks.
Perhaps Adobe should have a little humility and, since their programming model is to run pretty much their entire set of programs as frameworks that run plugins, just make sure to give the user the easy, accessible opportunity to remove the more ridiculous items of their feature sets. I mean really, "let's put a big, grotesque button for a feature only some people will use occasionally." Seriously.
Just note that renaming this will disable the CSLive button, as well as the following:
It will also disrupt functionality of Adobe Drive.
Cheers!
Matthew
The CS Live Button totally interferes with Adobe Connect Pro when you are trying to share the Photoshop application. The Sharing button is behind the CS Live and block usage of the Sharing button such as Stop and Annotation. What an example of one Adobe Product interfering with another. I also want to get rid of the CS Live button and try to demonstrate Photoshop in Adobe Connect Pro.
I tried following these steps, so I changed the FOLDER name to .bak at the end and it just created a new folder. Did I change the wrong thing? I looked through all the folders in the CS5.5ServiceManager folder and didn't see an actual file with that name, so I figured the folder is what needed to be changed. Can someone give me a few more hints? ...also, doing a search found 0 results. I'm on Mac OS X 10.6 (Mac Pro 2 x 2.8 GHz Quad-Core Intel Xeon)
