Can is there a way to configure the print settings (i.e. paper size, orientation, etc.) and save this setting as part of the pdf file? I would like the users of pdf files to be able to open the file and simply print, without having to manually configure the print settings.
Use the Advanced tab in the properties of the document.
Can outline the process besides selecting the "Advanced" option? Thanks
I don't understand.
Not sure if this will help. I got this information from the built-in help under Acrobat 9.
In the PDF settings for Acrobat, you can set a base Uniform Resource Locator (URL) for web links in the document. Specifying a base URL makes it easy for you to manage web links to other websites. If the URL to the other site changes, you can simply edit the base URL and not have to edit each individual web link that refers to that site. The base URL is not used if a link contains a complete URL address.
You can also associate a catalog index file (PDX) with the PDF. When the PDF is searched with the Search PDF window, all of the PDFs that are indexed by the specified PDX file are also searched.
You can include prepress information, such as trapping, for the document. You can define print presets for a document, which prepopulate the Print dialog box with document-specific values. You can also set reading options that determine how the PDF is read by a screen reader or other assistive device.
A PDF can contain a set of print presets, a group of document-specific values that is used to set basic print options. By creating a print preset for a document, you can avoid manually setting certain options in the Print dialog box each time you print the document. It’s best to define print settings for a PDF at the time that you create it, but print presets provide a means to add basic print settings to a PDF at any time.
The next time you open the Print dialog box, the values will be set to the print preset values. These settings are also used when you print individual documents in a PDF Portfolio.
Hi! Is it possible to configure Acrobat to ignore a document's preset print settings? I didn't find anything suggesting so in the Preferences, and I receive a document with what can only be described as an inconvenient preset on a regular basis. Anything that could help me out here would be greatly appreciated!
