"an unidentified error has occurred" Dreamweaver
Aug 23, 2010 3:37 PM
Hello
I was trying to connect to a Mysql server in Dreamweaver Cs5.
When I test the server the following error appear ""an unidentified error has occurred".
The thing is the FTP server works fine, the test server is active.
The password and the name are correct and the host is correct too.
If I use a php script I have no trouble reaching the server but if I try to use Dreamweaver I keep getting the same error.
My Dreamweaver version is CS5, I am using Windows 7 in a Pc with a Intel Core i7 computer.
Please help me.
I never had this error before, and the SQL connection use to work in Dreamweaver CS3.
    Aug 23, 2010 3:44 PM   in reply to Virtual Viadas
    Are you trying to use DW to connect to the remote server, or a local one?  If the former, have you enabled your IP address as a foreign client on the remote site's control panel?
    Oct 1, 2010 12:51 PM   in reply to Virtual Viadas
    I don't know if you got this working or not, but I am going to add my 2 cents.
    I was having the same problem, and after supplying a 'testing server' I was able to connect to my local mysql database
    So, basically, you'll be using it for testing purposes only, then when the website goes live, or you want to update the mysql data on the remote server, you can just do an export from localhost phpmyadmin, to the remote server phpmyadmin.
    This is the screen I am talking about.
    Oct 1, 2010 4:15 PM   in reply to Virtual Viadas
    http://forums.adobe.com/message/2260933#2260933
    This has worked for me for virtually ever issue I have had with the DW program itself. Completely safe to try and worth a shot.
    Brad Lawryk
    Adobe Community Professional: Dreamweaver
    Northern British Columbia Adobe Usergroup: Manager
    Thompson Rivers University: Dreamweaver Instructor
    My Adobe Blog: http://blog.lawryk.com
    Oct 28, 2010 4:00 PM   in reply to MurraySummers
    NO I have not, I will try this , any other help you can advise would be great
    Nov 3, 2010 10:43 PM   in reply to olie04
    thanks olie, you solved my problem
    Mar 29, 2011 10:07 AM   in reply to Virtual Viadas
    Olie04 - I have had this issue several times and worked around it using different methods.  This time I had hit a snag but your suggestion worked like a charm.
    thanks.
    Apr 3, 2012 9:17 AM   in reply to olie04
    2 years later and this answer works. Thanks Ollie!
    Jun 12, 2012 5:45 PM   in reply to Brad Lawryk
    I tried deleting WinFileCache after closing Dreamweaver, and I still had the same problem.  I tried it again several times and even shut down and rebooted.  Then I renamed the Personal Configuration folder (ConfigurationBACKUP, and then restarted the PC, and still I am getting the same errors.
    I can connect via FTP with no problems.  Files already on the site still function properly - I can insert and modify data through the admin pages I created.
    The only thing different is that I did an UPGRADE on all Adobe products today via the Help tab.
    I have tried everything, but cannot get my database to work through Dreamweaver CS6.
Bookmarked By (1)
