Hello,
I can't access help files after having recently purchased and installed several copies of CS5 Web Premium.
Here's the situation: military site with closed (non-internet) network needs CS5 to replace existing CS3 installation. Windows 32-bit. A stand-alone internet computer with cd-r drive is available, but I can't install anything on it. See the problem?
I've already read a number of threads on this subject and all the relevant KB articles that I could find (including 84215 and 83703). I downloaded the PDF manuals individually (much later I found http://blogs.adobe.com/premiereprotraining/2010/08/help-documents-for- creative-suite-5-pdf-and-html.html, which points to all of them in one place - that should be linked from the support site). Adobe phone support could not help beyond suggesting download of the PDFs.
My developers are used to being able to hit F1 and search help, specifically in Flash for ActionScript language reference. The external PDF manuals, while useful, are not an option for this purpose - just too clumsy.
As I understand it, the first time Adobe Community Help is run, it can optionally download all html help files for offline use. Since I can't connect the development computers to the internet, I need to download an archive of those files from elsewhere.
It seems like I need to either:
a) Find a magical adobe.com page with an archive of the html help files that I can download
-or-
b) Go home and download (on my mac) the applicable portions of adobe.com and burn to CD
(e.g. http://help.adobe.com/en_US/flash/cs/using/index.html)
-then-
c) Find the appropriate file location to install these files on my development computers
d) Update any TOC or preference files so that the CS5 apps will know that the files are installed locally.
I could also just download the html files and put them on an internal web server, but this isn't preferred since then it wouldn't be connected to the CS5 apps, unless I can point them to an arbitrary web address for when my users hit F1 for help.
It seems like this would be a problem not just for military users but for any company that uses development computers not connected to the internet.
Any ideas would be greatly appreciated!
- Jim Grisham, United States Navy
P.S.
Not sure if it's related, but in Flash Professional CS5 when attempting to request help from the menu I receive the following error:
<Windows Internet Explorer>
Cannot find 'file:///C:/Program%20Files/Common%20Files/Adobe/Help/en_US/Flash/CS5 /AS3LR/index.html
I think that's after telling Community Help to work offline. In Photoshop, I get no such error, just a message that I need to access the internet to download help.
Hi Jim: you could try either approach (either hosting on your own intranet or copy the local help files to each machine). Here's some info that may help:
1. the Help application relies on a small XML file called the Help Configuration file (.helpcfg). There is one for each product located in the user's Local Store.
2. The Help Config file tells the app two very important things:
There are a few other variables managed by the file but those two are the most important.
3. Open the Help Config with a text editor and look for the following property: baseUrl="http://help.adobe.com/"
4. Now look a little further down in the file and you should see a number of "package" elements. Each package represents a distinct help book (i.e. "Using Flash CS 5"). The path variable is where the online HTML is located. For example, path="en_US/Flash/CS5/Using"
5. Look further below and you will see a variable called, downloadContent. For example, downloadContent="client.Flash_CS5_Using_en-us.zip"
6. If you put these three elements together (baseURL + path + downloadContent), you can parse the location for each downloadable help archive like so: http://help.adobe.com/en_US/Flash/CS5/Using/client.Flash_CS5_Using_en- us.zip
So what does this mean for you? What you could do is manually download the help files and host them on your own intranet -- you can then alter the baseURLs in the Help Configs to point to your own server. This would require editing each and every HelpConfig file so this may not be scalable for a very large team.
Or, you could go home, fire up the Help app, download the Help content outside of your network and then copy the entire Help folder back into the Local Store for each user. The app will automatically default to local Help if it cannot detect an internet connection so your team should be able to access just fine as long as the files are in the Help folder of your Local Store. No additional edits to the config file required.
For your convenience, here are a few additional package URLs relevant for the Web Suite - these are the default packages that a user is prompted to download on first launch. There are many other packages defined in the help configs so there may be additional books relevant to your team.
Photoshop: http://help.adobe.com/en_US/Photoshop/CS5/Using/client.Photoshop_CS5_U sing_en-us.zip
Illustrator: http://help.adobe.com/en_US/Illustrator/CS5/Using/client.Illustrator_C S5_Using_en-us.zip
Dreamweaver: http://help.adobe.com/en_US/Dreamweaver/CS5/Using/client.Dreamweaver_C S5_Using_en-us.zip
Fireworks: http://help.adobe.com/en_US_Fireworks_11.0_Using/client.Fireworks_CS5_ Using_en-us.zip
Flash Builder (aka Flex):
Using Flash Builder: http://help.adobe.com/en_US_Flex_4.0_UsingFlashBuilder/client.Flex_4.0 _UsingFlashBuilder_en-us.zip
ActionScript 3.0 Language and Component Reference: http://help.adobe.com/en_US/AS3LCR/Flex_4.0/Flex_4.0_en-us.zip
Using Adobe Flex 4: http://help.adobe.com/en_US/Flex/4.0/UsingSDK/client.Flex_4.0_UsingSDK _en-us.zip
Accessing data with Flex 4: http://help.adobe.com/en_US/Flex/4.0/AccessingData/client.Flex_4.0_Acc essingData_en-us.zip
LiveCycle Service Discovery: http://help.adobe.com/en_US/Flex/4.0/LCServiceDiscovery/client.Flex_4. 0_LCServiceDiscovery_en-us.zip
Flash
Using Flash CS5: http://help.adobe.com/en_US/Flash/CS5/Using/client.Flash_CS5_Using_en- us.zip
ActionScript 3.0 Reference for the Flash Platform: http://help.adobe.com/en_US/Flash/CS5/AS3LR/Flash_CS5_en-us.zip
Mark,
Thanks for the quick response!
I was able to download the .zip files you referenced (some of the urls got mangled - I reposted them below to help others).
I could not find the help config files you mentioned. This is what I find when I go to C:\Documents and Settings\ * USER NAME* \ApplicationData\ chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1\Local Store\:
appDB.db
chc-pref.xml
#SharedObjects (directory)
|--> s_br.sol
#ApplicationUpdater (directory)
|--> state.xml
There was no HelpCfg directory nor any help configuration file (.helpcfg). Since this is under my user account, these files are created upon first run of community help. I assume I need that configuration file no matter what to make Community Help work.
Am I supposed to extract the files from the .zip files that I download? If so, what do I name the directory? Is it:
client.Photoshop_CS5_Using_en-us.zip becomes Local Store\client.Photoshop_CS5_Using_en-us\
In summary, I what I really need to know is:
a) Where can I get a copy of the HelpCfg directory/files
b) Where exactly do I put the help files that I downloaded (see above).
Thank you for the assistance,
- Jim
Links to help archives:
*Creative Suite*: http://help.adobe.com/en_US/CreativeSuite/CS5/Using/client.CreativeSui te_CS5_Using_en-us.zip
*Photoshop*: http://help.adobe.com/en_US/Photoshop/CS5/Using/client.Photoshop_CS5_U sing_en-us.zip
*Illustrator*: http://help.adobe.com/en_US/Illustrator/CS5/Using/client.Illustrator_C S5_Using_en-us.zip
*Dreamweaver*: http://help.adobe.com/en_US/Dreamweaver/CS5/Using/client.Dreamweaver_C S5_Using_en-us.zip
*Fireworks*: http://help.adobe.com/en_US/Fireworks/CS5/Using/client.Fireworks_CS5_U sing_en-us.zip
*Flash Builder (aka Flex*):
Using Flash Builder: http://help.adobe.com/en_US/Flex/4.0/UsingFlashBuilder/client.Flex_4.0 _UsingFlashBuilder_en-us.zip *Flash* Using Flash CS5: http://help.adobe.com/en_US/Flash/CS5/Using/client.Flash_CS5_Using_en- us.zip
Hi Jim: can you check another location? The CS installer places a set of 'bootstrap' config files into the following folder:
Hopefully, you should see some HelpCfg files in that directory. Usually, the help app will rely on those bootstrap config files to connect to an initialization service to download new, updated Help Config into the Local Store.
So I think the lack of network connectivity is the culprit. My recommendation at this point would be to install the Suite on your Mac laptop and fire up the Help app at home (where the app can then connect to the initialization service, etc.).
On your Mac, you should then be able to download the Help content and updated config files into the proper locations. You can then zip up the entire Local Store on your Mac from:
And then copy it over to the Windows machines at the corresponding location:
This way, you won't need to worry about downloading the help archives or placing them in the right directories, etc.
Hi all,
I'm having a similar problem as well as I'm trying to use Dreamweaver CS5 on a PC in a secure environment (so no direct internet access).
I've followed the instructions above and do eventually get Adobe Help CS5 to show up but with about a 2-3 minute lag.
Do I need to edit the baseURL value in Dreamweaver_11.0.helpcfg to relfect the path to the local copy of files?
I installed Dreamweaver on another PC so I could copy over the "Local Store" directory to the secure PC.
Thanks for any assistance.
Tom
I am also running a network full of Adobe apps that currently have no help files because of this strange requirement that all machines have 'Net access. I am trying to implement your fix, but I found that on Windows 7x64 the file path is different (no shock, though) - it's now:
Users\USERNAME\AppData\Roaming\chc....
The problem I'm having is that one of the filenames is too long for even Windows 7x64 on NTFS -
"filesystemdatagridnamecolumnrendererautomationimpl.html". It doesn't look like I need it, though...
I realize this is an old thread, but it finally gave me the solution to launching offline help (F1) in Photoshop CS5. Now my quest is to find the HTML help files for Lightroom. All the references to local help I've found in the LR forum have been for the pdf file. Does HTML help exist for LR 3.0 and if so, where can I find it?
Thanks.
Never mind, finally figured out the syntax.
http://help.adobe.com/en_US/Lightroom/3.0/Using/client.Lightroom_3.0_U sing_en-us.zip
