Stijn Debrouwere
Extendables: a framework for Adobe ExtendScript
Nov 1, 2010 6:08 AM
Howdy folks,
New here, but I come bearing gifts. I've just open-sourced Extendables, a small framework that simplifies ExtendScript coding. Check it out at http://extendables.org and the documentation at http://extendables.org/docs/.
Extendables isn't a whiz-bang does-everything-for-you kind of framework, but if you're doing any serious scripting, it will definitely make your life easier. It includes some of the newer Javascript 1.6+ Array methods like forEach, useful shortcuts/monkeypatches and modules for logging, HTTP connections and creating user interfaces. Plus a bunch of other stuff.
With the rise of server-side Javascript (you might've heard of node.js, Narwhal or Rhino), there's a growing number of libraries and frameworks out there which don't depend on a browser to work, so the timing felt right to tap into that ecosystem as well for our own profit. For example unit testing is provided by a slightly tweaked Jasmine, which is a great DOM-less Javascript testing framework.
Do note that this release is halfway between a teaser and a working product. Some parts aren't feature-complete, like the HTTP library. Other parts are experimental. There's no common style yet. The UI helpers have a domain-specific language vibe and so does the unit testing library. The HTTP library and a couple of other parts work entirely getter/setter-based (think jQuery). But in other parts I've tried to stay close to how ExtendScript works out of the box, so that it'd feel intuitive for long-time scripters.
It's pretty stable, but I've only been able to test it out on my own system (InDesign CS4 — that's all I have a license for), so I've labeled it an alpha release regardless.
If you're up for that, do feel free to contribute via GitHub, either by helping to flesh out the core framework, by reviewing the documentation or by making your own module packages. There's already a lot of collective wisdom and code snippets out there, and it probably wouldn't hurt to bring some of that together and release it as proper packages.
I guess what I'm saying is: try it out, skim through the docs, let me know what you like, don't like or would like to see. I'd be happy to keep in touch with any tester over Google Talk, mail or IRC, to help sort out any inevitable kinks you might encounter.
(I've put up a similar message over at my blog, but feel free to continue the conversation over here.)
    Community Member
    Nov 1, 2010 6:14 AM
    Hi Stijn, and welcome to the party!
    (Your extendables.org links return a 502 for now, but that may get fixed automagically.)
    How does this work? I mean, not down to the nitty gritty internal details, but in practice -- is this a replacement for the system-wide Javascript parser? Can I write my scripts as usual, save them into ID's Scripts folder, and run them from within ID?
    Community Member
    Nov 1, 2010 6:53 AM
    Hi Stijn and welcome!
    Nice work!
    I've actually been doing some work myself recently on converting my personal UI library into something which can be consumed by the general public. Mine is more geared towards increased functionality and ease of creating standard elements. It's not as fine-grained as what you've done.
    Harbs
    Nov 1, 2010 7:24 AM
    JavaScript 1.6+, DOM shortcuts, CommonJS-type namespaces, unit testing, UI library... this framework seems to have all the right ideas!
    Community Member
    Nov 1, 2010 1:10 PM
    Nice work, Stijn!
    Peter
    Community Member
    Nov 6, 2010 6:28 AM
    This is an amazing and huge project!
    Thanks for sharing :-)
    Marc
    [ Question: how behave Extendables' conditional #include directives when compiling a project as .jsxbin? ]
    Community Member
    Nov 6, 2010 9:25 AM
    Hi Stijn,
    Sorry for the rejection of your comment: Indiscripts spam filter is probably too harsh -- although I still get a lot of unfiltered ads...
    Let's continue the discussion by email...
    Marc
    Community Member
    Nov 7, 2010 3:09 PM
    Hi Stijn,
    I can't wait to give your framework a try. I was getting sick using ESTK
    As others pointed out, thanks for sharing you very expected project !
    Loic
    Community Member
    Nov 10, 2010 9:47 PM
    First try here:
    http://www.indiscripts.com/post/2010/11/my-first-extendables-script-fo r-indesign
    (Unicode Character infos box using the Extendables' http library.)
    Cool!
    Marc
    Dec 7, 2011 7:31 AM
    Hello,
    I have been trying to use this framework with Indesign, but I am unable to get it working. I will appreciate your help on this. Below is the code that I am trying.
    So far, what I have understood is that this framework does not work with any authentication parameters and I think I have seen some where that it's not yet implemented. Is that correct? If so, could some one help me on how would I be able to get this working?
    Thank you so much for the help.
    Indesign code:
           var auth=new Object();
           auth.username="admin";
            auth.password="admin";
            var auth = { username:'admin', password:'admin'};
            var response = http.get("http://localhost:4502/content/geometrixx/en/company/news/articles/jcr: content/par/text.html",auth,5);
            alert(response.body);
            if (response.status_code == 200) {
            } else {
                alert("Connection failed");
    Result:
    It fails at the runtime by pointing the ExtendScript debugger at the line number 137 in object.conversions.jsx. The line 137 is : throw RangeError("This method cannot convert from {} to {}".format(this.prototype.name, type));
    Community Member
    Dec 7, 2011 7:54 AM
    Cool, thanks. I have just seen your post already there as a feature request. I did reply to your post and also added a new issue too. Also, I want to know when this will be implemented and do you know whom do I need to talk to on this?
    Thanks so much for the help,
    Murali
