converting excel to text file
Nov 9, 2010 8:20 AM
HI All -
I am uploading an excel file using coldfusion. Once the file has been uploaded, I  want to convert it to a text file. What I am trying to do now is once the file is  uploaded, I am reading the excel file and then writing the output to text file.  but the write method creates all junk in the text file.  What is the best way to do this?
    Nov 9, 2010 8:21 AM   in reply to funandlearning333
    Are you in CF9? If so you can read in the data. Then you could write
    it out to a text file.
    Nov 9, 2010 8:28 AM   in reply to funandlearning333
    If you are on CF8 you may want to look into Ben Nadel's POI Utility:
    http://www.bennadel.com/projects/poi-utility.htm
    --Nathan
    Nov 9, 2010 10:29 AM   in reply to funandlearning333
    funandlearning333 wrote:
    The problem is the html is getting written to the text file. How can I make sure, i get only the header and rows values
    Then don't put HTML into the output content?  Whatever you put into the "output" string variable via <cfsavecontent variable="output"> is going to be written to the file with the output="#output#" parameter.
    Nov 10, 2010 12:24 PM   in reply to funandlearning333
    The version of the POI libraries bundled with ColdFusion 8 do not support
    the OOXML (.xlsx) format. To read .xlsx files you need to use the latest
    version of POI, which you can find here: http://poi.apache.org/
    For info on using POI with JavaLoader see:
    http://cfsearching.blogspot.com/2008/08/how-to-install-poi-on-coldfusi on-8.html
    (Note: CF 9 supports .xlsx natively via cfspreadsheet.)
    --Nathan
    Nov 12, 2010 10:38 AM   in reply to funandlearning333
    How are you saving it as Microsoft 2000-2003? The options I get in Excel
    2010 when I choose "File -> Save As" list "Excel 97-2003 Workbook (*.xls)"
    but no 2000-2003 options.
    --Nathan
    Nov 12, 2010 11:11 AM   in reply to funandlearning333
    Can you open the files with Excel after downloading them? Are you sure they
    are Excel files and not .csv or some other format?
