Locked
Textflow link element doesn't work after append to an existed textflow
Nov 10, 2010 Nov 10, 2010
It's a strange problem
I have two textflow container : RichEditableText
the first one I new the textflow2 everytime I clicked the button,and append a link returned by getElement
the second one I initially new a textflow and reused it to append new link returned by the same function getElement
but the strange thing is , the first one works just fine ,but the second one 's link seems invalid with no hand cursor nor function
thanks a lot for any clue or comment
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                           xmlns:s="library://ns.adobe.com/flex/spark"
                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="400" minHeight="300">
        <s:layout>
                <s:BasicLayout/>
        </s:layout>
        <fx:Script>
                <![CDATA[
                        import flashx.textLayout.elements.LinkElement;
                        import flashx.textLayout.elements.ParagraphElement;
                        import flashx.textLayout.elements.SpanElement;
                        import flashx.textLayout.elements.TextFlow;
                        [Bindable] public var textFlow:TextFlow = new TextFlow();
                        [Bindable] public var textFlow2:TextFlow = new TextFlow();
                        protected function button1_clickHandler(event:MouseEvent):void
                                textFlow2 = new TextFlow();
                                textFlow2.addChild(getElement());
                                textFlow.addChild(getElement());
                        private function getElement():ParagraphElement{
                                var linkSpan:SpanElement = new SpanElement();
                                linkSpan.text = "link";
                                var link:LinkElement = new LinkElement();
                                link.addChild(linkSpan);
                                link.href = "event:ok"
                                var p:ParagraphElement = new ParagraphElement();
                                p.addChild(link);
                                return p;
        </fx:Script>
        <fx:Declarations>
        </fx:Declarations>
        <s:RichEditableText editable="false" text="RichText" width="180" height="165"  textFlow="{textFlow2}" />
        <s:RichEditableText editable="false" x="196"   text="RichText" width="180" height="165" textFlow="{textFlow}" />
        <s:Button x="116" y="217" label="button" click="button1_clickHandler(event)"/>
</s:Application>
Text layout framework
5.6K
Adobe Employee ,
I can reproduce this in TLF 2.0 and filed a bug.  I did observe that if I click on textFlow2 the link begins to work.  What version of TLF are you using?
Richard
Thanks for the reply
I am using flex sdk 4.1 bundled version.I don't know which version exactly, is that 1.1?
is there a way to workaround ? If I switch to tlf2.0 or newer version the problem might gone?
Adobe Employee ,
Nov 11, 2010 Nov 11, 2010
Yes - Flex 4.1 is using TLF 1.1.  Thanks.
I have fixed this in 2.0.  For a 1.1 workaround you can do this:
        <s:layout>
                <s:BasicLayout/>
        </s:layout>
        <fx:Script>
                <![CDATA[
                    import flashx.textLayout.compose.StandardFlowComposer;
                    import mx.core.mx_internal;
                    import flashx.textLayout.tlf_internal;
                                ret2.mx_internal::textContainerManager.tlf_internal::convertToTextFlowWithComposer();
                                ret.mx_internal::textContainerManager.tlf_internal::convertToTextFlowWithComposer();
                                link.href = "http://www.adobe.com"
                                p.addChild(link);
                                return p;
        </fx:Script>
        <fx:Declarations>
        </fx:Declarations>
        <s:RichEditableText id="ret2" editable="false" text="RichText" width="180" height="165"  textFlow="{textFlow2}" />
        <s:RichEditableText id="ret" editable="false" x="196"   text="RichText" width="180" height="165" textFlow="{textFlow}" />
</s:Application>
Nov 12, 2010 Nov 12, 2010
Thanks for your timely reply!
I swtiched to tlf2.0 and replaced the two as files downloaded from tlt homepage, the problem seems gone.
But here's another one !
The link worked only some firstly added ones, the next added ones can not click.
repoduce steps
use the code below with tlf2.0 and flex sdk4.1 updated version
click the button few more times till the scroller begin to work
check the links at the bottom, they don't work,
    <s:layout>
        <s:BasicLayout/>
    </s:layout>
    <fx:Script>
        <![CDATA[
//                textFlow2 = new TextFlow();
//                textFlow2.addChild(getElement());
                textFlow.flowComposer.updateAllControllers();
                scrollerChat.verticalScrollBar.value = ret.contentHeight;
                p.addChild(link);
                return p;
    </fx:Script>
    <fx:Declarations>
    </fx:Declarations>
    <s:RichEditableText id="ret2" editable="false" text="RichText" width="180" height="271"  textFlow="{textFlow2}" />
    <s:Scroller id = "scrollerChat" x="193"  width="180" height="271" verticalScrollPolicy="on" >
        <s:RichEditableText id="ret" editable="false"    text="RichText" textFlow="{textFlow}"  y="0"/>
    </s:Scroller>
    <s:Button x="381" y="9" label="button" click="button1_clickHandler(event)"/>
</s:Application>
Adobe Employee ,
My fix hasn't been posted to the TLF sourceforge site yet - there's a lag because we have to run a script that get's odd timeout errors. A separate 2.0 bug with scrolled links demonstrated by your example was fixed a couple of days ago - build 200 contains all these fixes.
In your sample code the call to updateAllControllers can cause a RTE.  The textFlow in a RichEditableText is not guaranteed to have a flowComposer. Normally flex takes care of composing for you and that line can be removed.
If you do want to force a compose use this function:
ret.mx_internal::textContainerManager.updateContainer()
BTW thanks for the code examples - they're much easier to follow than verbal descriptions.
Hope that helps,
Richard
Nov 14, 2010 Nov 14, 2010
Thanks for your correction!
I tried use the new sdk4.1 build by myself with 2.0 tlf. But some other problem pop up related to css,
and I have to merge the spark.swc to my app file because of the signature issue, and  the swz file is different for adobe's ftp version
I must host or merge them.
So I think I better use the production version and wait for the sdk 4.5's production version .
Do you know when 4.5sdk will be ready?
Adobe Employee ,
Nov 15, 2010 Nov 15, 2010
Can't comment about 4.5 dates beyond what's posted here:
http://opensource.adobe.com/wiki/display/flexsdk/Hero
Richard
Jun 29, 2011 Jun 29, 2011
I'm facing the same issue and i'm using 4.5 SDk.
Here's my code. Works fine if textFlow value is not bindable, else shows nothing(Blank).
   creationComplete="init()">
<s:layout>
<s:VerticalLayout/>
</s:layout>
<fx:Script>
<![CDATA[
import flash.text.engine.FontWeight;
import flashx.textLayout.conversion.TextConverter;
import spark.utils.TextFlowUtil;
private var hi:String="my code"
private var cnt:int=10;
var markup:String="hello";
private var text:TextFlow;
private var levelName:String = "family"
public function init()
trace("here");
markup += "world";
if(levelName == "family"){
markup +="<span fontSize='15' color='#ff0000' fontFamily='Verdana'>"+ hi + "</span> (<span fontSize='12' color='#007fc5' fontFamily='Arial'>"+cnt+") > </span>";
trace("string::"+markup)
text=TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
private function clickBtn(event:MouseEvent):void{
markup += "world";
rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
</fx:Script>
<s:RichText>
Hello
<s:span fontSize='16'>BIG NEW</s:span>
World!
</s:RichText>
<!-- Or the TextFlow child tag. -->
<s:RichText id="rTxt" textFlow="{text}"/>
<s:RichText id="rTxt1" />
<s:Button click="clickBtn(event)" label="Click"/>
</s:Application>
Adobe Employee ,
Jun 30, 2011 Jun 30, 2011
Replace the line
rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_F ORMAT);
with
var imp:ITextImporter = TextConverter.getImporter(TextConverter.TEXT_FIELD_HTML_FORMAT);
rTxt1.textFlow = imp.importToFlow(markup);
Then your code will work.
flashx.textLayout.convertion.TextConverter is the converter in TLF, which work well. TextFlowUtil is not under our control.
Hi Jin,
Thanks for the response, but its not working for me.
Its not working for when i'm binding the value.. can you please once lok at it and helping me in resolving this issue.
<s:layout>
<s:VerticalLayout/>
</s:layout>
<fx:Script>
<![CDATA[
import flashx.textLayout.conversion.ITextImporter;
trace("here");
markup += "world";
text = imp.importToFlow(markup); {Your code}
//text=TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT); {my code}
markup += "world";
</fx:Script>
<s:RichText>
Hello
World!
</s:RichText>
<s:RichText id="rTxt" textFlow="{text}"/> {not working this way}
<s:Button click="clickBtn(event)" label="Click"/> {Working this way}
</s:Application>
Adobe Employee ,
[Bindable]
Declare text as Bindable
Besides, I found that two types of import show different results. Choose the one you like
After binding i can see the text but without formatting...so my problem is still at the place from where i have started
Am i missing anything?
Message was edited by: kanukukreja
One more thing which i just noticed is that after removing textFlowUtil from the clickEvent, its also started showing the text without formatting.
markup += "world";
//rTxt1.textFlow =TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
Adobe Employee ,
TextFlowUtil.importFromString will give you text with sytles, while  imp.importToFlow cannot. I will investigate if it's a TLF bug.
(At the very beginning, TextFlowUtil.importFromString does not show any text, but importToFlow can. But now importFromString works. I'm not sure what's going on. My answer at #9 is wrong.)
Thanks a ton Jin for the quick responses, please share if you find anything regarding the same.
>>> Let me know if you find any solution for the same.
>>> Only in the case of bindable textflow values otherwise it shows the formatted text.
>>> importFromString still works but not with the bindable texts. Thats the only issue.
Adobe Employee ,
    <s:layout>
        <s:VerticalLayout/>
    </s:layout>
    <fx:Script>
        <![CDATA[
            import flashx.textLayout.conversion.*;
            [Bindable]
                trace("here");
                markup += "world";
                text = TextFlowUtil.importFromString(markup,TextConverter.TEXT_FIELD_HTML_FORMAT);
                markup += "world";
    </fx:Script>
    <s:RichText>
        Hello
        <s:span fontSize="16">BIG NEW</s:span>
        World!
    </s:RichText>
    <s:RichEditableText id="rTxt1"/>
    <s:Button label="Click" click="clickBtn(event)"/>
</s:Application>
Thanks a Jin, its working fine now.
I found one more way of doing the same, please have a look below:
<s:layout>
<s:VerticalLayout/>
</s:layout>
<fx:Script>
<![CDATA[
[Bindable]
private var textFlowTxt:TextFlow;
private var markup:String="hello";
private var levelName:String = "family";
private function createTextFlow():TextFlow {
var htmlText:String = "<span fontSize='15' color='#ff0000' fontFamily='Verdana'>"+ hi + "</span> (<span fontSize='12' color='#007fc5' fontFamily='Arial'>"+cnt+") > </span>";
var textFlow:TextFlow = TextFlowUtil.importFromString(htmlText, TextConverter.TEXT_FIELD_HTML_FORMAT );
return textFlow;
</fx:Script>
<s:RichText>
Hello
World!
</s:RichText>
<s:RichText id="rTxt" textFlow="{createTextFlow()}"/>
</s:Application>
