Rasterize/Flatten Image
Guest
Nov 09, 2010 Nov 09, 2010
Hey guys, I have a couple of questions wanted to know if you could help me out. I know these are probably geared more toward photoshop but I was just curious. Under the Layer menu there is a function called 'Rasterize', what does this do and what is it for?
Second one, let's say I wanted to send a file to the printer from photoshop. Would I want to flatten the image (also under the Layer menu at the bottom) to send a smaller file size or send the file as separate layers? What is the better of the two?
Lastly, if you have a vector image in illustrator or photoshop is it preferrable to keep it vector rather than raster for any reason(s)?
29.8K
Firstly this is the InDesign forum - you could navigate back to the main forum pages and select the Photoshop forums for photoshop queries.
Rasterize in the Layers Panel will convert any vector object in Photoshop, vector shapes, vector masks or text to Pixels. Meaning they will lose their scalability as increasing raster physical dimensions causes interpolation (jaggy edges)
Sending a file from Photoshop to the printers is precarious depending on file format
TIFF and PSD can both retain layers, including vector layers, type layers, vector shapes and vector masks - BUT they both output the data as Raster
EPS can retain the vector information only for PRINTING - if you open an EPS in photoshop again it is completely flattened and rasterised - http://livedocs.adobe.com/en_US/Photoshop/10.0/help.html?content=WSfd1234e1c4b69f30ea53e41001031ab64-78f7.html
EPS also does not retain layers, and it can be problematic http://www.prepressure.com/library/file-formats/eps
The IDEAL format then is to use the PDF option when saving a file from Photoshop. The PDF can retain layers, vector information for editing later and also outputs the vector and raster data - it's fully retains the objects as it wraps them in a PDF wrapper ensuring they output correctly.
Lastly-
It is preferable to keep it vector and sometimes it is prefereable to rasterise it.
Vectors are sometimes best left as VECTORs as they can be increased or decreased to any size without losing sharpness.
But some Vector objects from Illustrator are very complex and yield massive file sizes. If you had a 10 x 100 mb vector images in a document, that would be a 1gb of information for just those vectors. It may be best to rasterise these vectors at 300 ppi at actual print size, which could reduce the file size significantly - you may or may not notice quality issues with it - depends on the content of the image, something with sharp edges, like buildings may be more noticeable, but an illustration of a painting with soft edges may not be so noticeable.
Hope that helps.
Guest
Okay, only reason I asked on here is because anytime I've asked advice on the photoshop wing of the forum I seldom got a response and when I did it wasn't very helpful but ok.
So basically the answer to my first question sort of goes hand in hand with the third question I asked, if the file is too big as vector then I should rasterize it? It was meant to shrink file size?
To what you're saying about the PDF wrapper, does it really make any difference whether the original file has separate layers or one flattened single layer when in print?
dumb question: if I open a vector (.ai file) in photoshop as a vector file and then save it as TIFF or PSD it now becomes raster?
You do not have to rasterise the file if the file size is too big. I know printing companies that RIP 10gb of information for print jobs. BUT if you needed to get the file size down for whatever reason - then you can rasterise the vector, but you will lose some quality and sharpness - it may or may not be noticeable in print. But this rasterised version should only be used to get the file size down - you should always keep the vector as the master file.
If you make an EPS - be sure to save another version as an editable PDF/TIFF/PSD file in photoshop - that way you can edit the text or other vectors again. If you save a file as an eps and open that again, everything is rasterised and flattened to a single layer. So why bother saving as an eps in the first place (Placing to Quark is one example of why you'd need an EPS file - as it will retain the vectors for outputting). But you should always always always have an editable version of the file to make changes.
If you have  TIFF or PSD with text layers, you can open that in Photoshop and adjust the text. Then when you print it the text is rasterised, it's not vector, so it loses it's sharpeness.
If you make a PDF from photoshop - it will retain the text layers for altering at a different date, plus it retains the Sharpness of the vector in print.
So just save it as aPDF to start with - and you won't clutter up your system with different versions of the file.
Yes - when you open or place an Illustrator file in Photoshop it becomes a Smart Object. Smart Objects are denoted in the Layers Panel. A smart object is a vector object that can be scaled in Photoshop without losing resolution. BUT it is converted to RASTER on output at the native resolution of the document.
SO:
If you start a new document and choose 300 ppi (or any res)
Then place an AI file it becomes a smart object
You can now scale that within Photoshop to ANY size you want and it retains it's vector sharpness
BUT when you output (even to PDF) the image gets' rasterised to 300 ppi (or whatever resolution you choose)
THE only thing that PDF can out put as vector from Photoshop are Text Layers, Vector Masks and Vector shapes created within Photoshop.
Guest
Okay, so when in Photoshop if I go to File>Place and then pick an .ai file to place, when it prompts me for smart object, shape layer, pixels, etc. always pick smart object to retain it's sharpness? I think I understand.
Thank you very much for your help Eugene, always appreciated.
Yes smart object will be better.
BUT keep in mind that when you output it - no matter what file type you choose - it will rasterise to that PPI>
If you have a 72 ppi image and you insert the AI file it will be converted to 72 ppi and rasterised for output - but inside photoshop it will look sharp no matter what size you set it.
Why are you placing it into photoshop anyway?
You'd be better off putting the Photo into Illustrator.
Guest
Well, these are hypothetical questions. I mean, I have tried to import an .ai file into photoshop before and wasn't sure how to go about it. And when I set up the .ai file from the beginning before I even started drawing I always set the ppi to 300 and then when I open a new photoshop blank document I set it up as 300 too so it's good, it's rare that I do that but I have tried it before.
How would placing a photo into illustrator be better? Please explain.
Where are you setting 300 ppi in Illustrator? Illustrator only has Raster EFFECT settings, and these are what things like drop shadows and bevels use from the FILTER menu (not the ffects menu), and the 300 dpi becomes the resolution of the EFFECT - it has nothing to do with the vector elements. And, if you scale an image that is using effects the resolution is lessened.
And if you have a vector image why would you want to convert it to pixels by placing in Photoshop? It loses it's sharpness on output.
If you have Illustrator and an illustration in there, the place the photo in there and do the composition in Illustrator.
Or you could place the photo and the illustration into a program like InDesign (which is ideal for page layout especially multipage documents like brochures, booklets, books etc.)
Guest
I just meant that when I launch illustrator I can choose between different document profiles on the opening screen like "CMYK document" and "Print document" and what I was saying was I always choose Print document because I am assuming that by default it is set to 300 ppi. But I didn't know that the raster effects alone were raster, I guess from now on I will make sure that I only add them after I have done my scaling since you said that.
I think just to cut out the middleman that from here on out I will just stick to importing everything from their native programs/file formats directly to InDesign because it's too much work. .AI and .TIFF or .PSD to InDesign, just so much easier than all this unneccessary navigating. I trust your judgement better than my own.
Just to make sure I understand you correctly, when you say:
are you saying that I should place a raster photo (image, not a drawing or illustration) an image into illustrator for editing or am I misunderstanding you?
Illustrator doesn't have a setting for PPI when starting a document. It's a vector based program, meaning the objects are drawn using mathematical formuals, there is no resolution.
Photoshop has a resolution as it stores each bit of information in a pixel. The more pixels you have per inch the higher the resolution.
Yes you should import AI files and photoshop files directly to InDesign. Don't forget, don't just use PSD files for the sake of it. If you have text layers in photoshop then save as PDF from Photoshop and place that, then your text layers (vector masks and vector shapes) are retained for output.
And no you didn't understand me at all - I probably made it far more complex.
Photoshop rasterises illustrator files. So don't put illustrator files in photoshop.
However, if you have to combine an image with the vector, then you can import the photoshop image to Illustrator, that way your vector won't be rasterised.
Guest
Nov 11, 2010 Nov 11, 2010
Hi Eugene, sorry it's taken me a bit to respond to you. I've always been sort of confused as to when and how a vector becomes as raster. Opening a vector in photoshop by itself doesn't make it raster, saving it as another file format is what converts it (aside from the rasterize function I asked about earlier) am I right?
While we're on the topic of resolution, I know Peter glossed over this in an earlier thread I started but I'm still a tiny bit confused about that subject. Maybe you can make sense of this for me?
What I have been doing when working with images on the web I download them as JPEG and open them in photoshop. I go to Image>Image Size and the dialog box comes up. I don't mess with the pixel dimensions at the top of that box, don't even really know what those are for to tell you the truth. In the document size area I more than half most images in size because I remember you guys saying that shrinking a size of an image increases the true resolution but here's where I am confused... at near the bottom is resolution field, I punch in 300 but I'm guessing doing so doesn't literally and so easily change the true resolution of the image, so why even have that field in the first place if it doesn't really affect the resolution?? What's it for?
And to wrap it up at the very bottom of the image size pop up box I click the drag down menu and select bicubic sharper (best for reduction) and then I'm done. Am I doing this right?
At this point in time I'm just trying to learn enough to get my portfolio finished and resolution is something I think I really need to understand enough of to finish this up. Thanks Eugene
Sorry, don't have time to go into detail today unfortunately.
These are very basic questions though.I suggest you buy a book on photoshop, like Real World Photoshop or similar.
Guest
Nov 12, 2010 Nov 12, 2010
It's okay, thank you again for all your help Eugene, always appreciated.
I see Jongware covered it there
seriously - having books around you is the most help I can give you. You should see my bookshelf at work. Everything from Real World books to Typography, to graphic design, to books about font choices, to XML to whatever you can think of. I mostly use them for reference, but over the years I've had to use them less and less
Guest
That's cause you know your stuff Eugene!
As of right now I am starting with the first of three spokes, I am reading up on the illustrator cs4 bible to understand that then onto photoshop. I'm working on it, how long did it take you to learn this stuff?
It's easy enough.
In Photoshop, the top two dimensions are for the current picture size. Now that size in mm or picas or points or (Jedediah Buxton style) hair's breadths does not mean a thing. It's the actual number of pixels that count (or are counted), and their "physical" measure is determined purely by the image resolution -- the number of pixels per fixed (real) distance, or, in reverse, how big the sizes are in our physical dimension, given a certain number of pixels.
(Read the above again, please.)
(Done that? Understood it? No? Read it again. If you understand it correctly, you'll agree "it's easy enough".)
Now what happens when you don't change the pixel dimensions but do type in another number for the resolution?
As per this explanatory paragraph, the 'image' will appear to shrink or grow, but only when viewed in real dimensions. The number of pixels stays the same.
What does this have to do with viewing the image on a web page? Well, web pages are famous (notoriously so) for not actually having physical dimensions. Oh sure, you can define type in "10p" or "5mm" (I think CSS allows that), but actually, those are usually just shortcuts for a fixed calculation into the number of pixels the type should be. And that's what you are viewing, on a web page: pixels.
Given an 96 x 96 pixel image, would it matter if you saved it with a 300 dpi resolution instead of 96? At 96 dpi, the image would be around 1 inch square, because -- by convention -- current screens are around 96 dpi. (That Is A Lie. But read on -- it's just a minor one.) So on your screen, hypothetically 96 pixels per inch, displaying a 96 x 96 pixel image comes to about 1 inch. What if you change the dpi to 300? Well, the screen is still only 96 dpi, and web browsers don't adjust image size for dpi, so it would still display exactly 96 x 96 pixels -- the same size as before.
So ... how would you make an image appear larger or smaller on a web page? You have to change the number of pixels.
Given that this is, for now and the foreseeable future, still the InDesign forum: resolution is of paramount importance to accurately print images. InDesign reads the dpi settings of images when you place them into a document, and that document size is a physical dimension. "But in CS5 you can define stuff in pixels!" you might complain. Well, that is a lie, straight and true, outrageous as it may seem. Personally, I consider allowing pixels as a "valid measurement" one of Adobe's gravest errors -- your post is by far the only one of someone utterly and completely getting confused by this.
If you have saved the same image as above twice, once with a 96 dpi setting, and once with a 300 dpi setting, and you place both of them into InDesign at their default size, the first one will come in as a perfect 1 inch square. The second one will come in at a square of 96/300 = 0.32 inch, and if you think "oh boy, that's a bit too small -- I'd better scale it a bit up", you are making a classical mistake . Scaling that image up to, oh say, 1 inch again, will not change the image pixels, but it will change the resolution -- to be precise, back to that ol' 96 dpi again.
Guest
Jongware, if I understand you correctly this is what I sort of got out of it:
In photoshop the image size dialog box, the two top fields of pixel dimensions are actually the measurements of the document and there is where I was making the mistake of thinking that altering this will increase the pixels/resolution which really only increases/decreases the size of the image. Messing with the pixel dimensions and/or image size measurements are one and the same, they do the same thing am I right? There are a set number of pixels within every inch of an image/document, you can never create pixels out of thin air so they will always be there it's just a matter of how I concentrate them (with JPEGs).
So I guess, if you're saying that 96 x 96 dpi comes to one inch that 96 dpi is a set number of pixels within that one inch and will only appear to be of a higher resolution if the image is shrunk down smaller (like you were saying punching in 300 dpi will make the image much much smaller in InDesign) when in fact it is still 96 dpi just in a smaller, concentrated area. I'm at a gross disadvantage because I'm working with JPEGs and doesn't allow for much other than to shrink them down to hide the flaws. I just need to find some treasure trove of high resolution, non-lossy format images to work with because it stinks trying to work with these watered-down JPEGs I'm finding on google.
If I have in any way misunderstood you or are wrong about anything please feel free to let me know?
Since I don't get to say it much, Eugene, Jongware, Peter, Bob, everyone thank you very very much for your help. I know there is a lot of specialization in this field, you guys really know your stuff and I really appreciate your patience and willingness to help. I really admire you guys (a bit intimidated at times lol) but I really value your time and effort, thank you guys so so much. You guys are the coolest and it makes me feel a lot better to know that I have this kind of help on my side.
Imagine this is one inch wide
It has 96 pixels across and 96 pixels down
Now - if you made this two inches wide - how many pixels would you have?
Well you have two answers
1.Same amount of pixels - but the the pixels will be larger
Or
2. Or you can doulbe the double the amount of pixels to - 192
Guest
How would I go about doubling the amount of pixels to 192 and is that ideal or would this give interpolation? If possible, heck yeah I would like to increase the resolution but from what I've read that isn't possible without actually capturing/creating the image in another non-lossy format.
You don't...you can't just invent data. You need a better image.
Bob
Guest
Maybe I'm confused as to what Eugene is saying in the number 2 option, I know the first one will give the jaggy edges and make the pixels bigger. What would the second option do? Going to refer to my photoshop book too...
It's not really a good idea try to upsample an image - as you know it becomes blurry when you do.
I'm just trying to give you a visual representation of what's going on.
If you doulbe the amount of pixels - then photoshop trys to guess what colour the new pixels are by sampling other pixels around it, and it's not very accurate.
Guest
Upsampling is when you just expand the image to a bigger size am I right? If not, how do I do that should I ever need it?
Ideally you don't want to try make an image bigger - if you can avoid it.
http://www.cambridgeincolour.com/tutorials/image-interpolation.htm
