Mac OS X 10.5.8
2.4 GHz Intel Core 2 Duo MacBook
4 GB RAM
Amplitude Statistics dialog box does not appear to function.
Upon selecting audio range, I am able to open the dialog box and toggle among the tabs, but the Scan Selection button is unresponsive.
Numerical text values are absent from boxes within the General tab, & no data appears on the graph within the Histogram tab.
Thanks in advance for any advice/input.
One important gotcha - amp stats works on audio files when they're open in the editor, but not multitrack sessions. So, if you had a MT session open, what you're describing might occur (i.e. you can see the panel but it's unresponsive and empty). To analyze a file in your session, you can double-click on it and the amp stats panel should become available. If you want to analyze the stats of your MT session as a whole, you'll have to mix it down first (Multitrack menu).
As far as I know, amp stats should ALWAYS be functional if you have a wave file open in the editor, regardless of channel count or file type. If it's not, that's DEFINITELY a problem.
Scott C
