Spry Tabbed Panels 2 - Remember Last Tab
Nov 16, 2010 8:37 AM
Using the Spry UI Tabbed Panels 2, has anyone found a way for the page to remember which tabbed was last viewed?
I can see that I can use the showPanel() method to set the panel, and I can use the getCurrentTabIndex() to retrieve the current tab index, but I am not sure what to do with them next.
I am thinking about maybe setting a cookie with the current tab index, but I don't know what to attach the onclick event to. Should I use a spry selector to add the onclick attribute to the a tag that is automatically generated?
Does anyone else have any clever ideas?
Cheers,
Steve
    Nov 16, 2010 3:02 PM   in reply to Dooza (Steve)
    Hi Steve,
    Have a look here http://go.spry-it.com/cookie with thanks to Arnout
    (the site was down at the time of posting, please be patient)
    Ben
    Aug 10, 2012 1:55 PM   in reply to Ben Pleysier
    I have been searching for an answer for this for sometime now.  The http://go.spry-it.com/cookie  is not working.  Any help/suggestions.  I want to go to the last tab looked at after a page refresh or change.  Any help would be appreciated.
    Aug 10, 2012 2:52 PM   in reply to Brewster Jones
    Have a look here http://pleysier.com.au/sprycookie/
    Gramps
    Aug 10, 2012 4:47 PM   in reply to Ben Pleysier
    Thanks Gramps... I found your previous post to this before as well.  I am just going nuts and know the cookie is not reading somewhere in this part of the code:
    var cookie = Spry.Utils.Cookie('read','tabbedpanels');
    var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1",{defaultTab:cookie ? cookie : 0});
    Spry.Utils.addUnLoadListener(function(){
              Spry.Utils.Cookie('create','tabbedpanels',TabbedPanels1.getCurre ntPanelIndex());
    I found another post that tweaked it some to:
    var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", { defaultTab: cookies ? parseFloat(cookies) : 0 });
    but that was no good and made the whole tabgroup not work.
    The next question is... why am I using Spry?  LOL.  Man I would like to solve this issue.
    Aug 11, 2012 6:57 PM   in reply to Ben Pleysier
    THANK YOU VERY MUCH GRAMPS!:  THIS DID WORK!
    <!DOCTYPE html>
    <html>
    <head>
    <meta charset="utf-8">
    <title>Spry Accordion</title>
    <link href="SpryAssets/SpryTabbedPanels.css" rel="stylesheet">
    </head>
    <body>
    <div id="TabbedPanels1" class="TabbedPanels">
      <ul class="TabbedPanelsTabGroup">
        <li class="TabbedPanelsTab" tabindex="0">Tab 1</li>
        <li class="TabbedPanelsTab" tabindex="0">Tab 2</li>
      </ul>
      <div class="TabbedPanelsContentGroup">
        <div class="TabbedPanelsContent">Content 1</div>
        <div class="TabbedPanelsContent">Content 2</div>
      </div>
    </div>
    <script src="SpryAssets/SpryTabbedPanels.js"></script>
    <script>
    var Spry; if (!Spry) Spry = {}; if (!Spry.Utils) Spry.Utils = {};
    // We need an unload listener so we can store the data when the user leaves the page
    // SpryDOMUtils.js only provides us with a load listener so we create this function
    Spry.Utils.addUnLoadListener = function(handler /* function */)
        if (typeof window.addEventListener != 'undefined')
            window.addEventListener('unload', handler, false);
        else if (typeof document.addEventListener != 'undefined')
            document.addEventListener('unload', handler, false);
        else if (typeof window.attachEvent != 'undefined')
            window.attachEvent('onunload', handler);
    Spry.Utils.Cookie = function(type /* String*/, name /* String */, value /* String or number */, options /* object */){
        var name = name + '=';
        if(type == 'create'){
            // start cookie String creation
            var str = name + value;
            // check if we have options to add
            if(options){
                // convert days and create an expire setting
                if(options.days){
                    var date = new Date();
                    str += '; expires=' + (date.setTime(date.getTime() + (options.days * 86400000 /* one day 24 hours x 60 min x 60 seconds x 1000 milliseconds */))).toGMTString();
                // possible path settings
                if(options.path){
                    str += '; path=' + options.path
                // allow cookies to be set per domain
                if(options.domain){
                    str += '; domain=' + options.domain;
            } else {
                // always set the path to /
                str += '; path=/';
            // set the cookie
            document.cookie = str;
        } else if(type == 'read'){
            var c = document.cookie.split(';'),
                str = name,
                i = 0,
                length = c.length;
            // loop through our cookies
            for(; i < length; i++){
                while(c[i].charAt(0) == ' ')
                    c[i] = c[i].substring(1,c[i].length);
                    if(c[i].indexOf(str) == 0){
                        return c[i].substring(str.length,c[i].length);
            return false;
        } else {
            // remove the cookie, this is done by settings an empty cookie with a negative date
            Spry.Utils.Cookie('create',name,null,{days:-1});
    var cookie = Spry.Utils.Cookie('read','panel');
    //alert(cookie);
    var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", {defaultTab: cookie ? parseFloat(cookie) : 0});
        Spry.Utils.Cookie('create','panel',TabbedPanels1.getCurrentTabIndex());
    </script>
    </body>
    </html>
