Hi
I need Sample Flash phone souce code .
thanks
Thanks a lot
I am beginner in flex and I am using Flex builder 4 .when I open this sample in flex 4 , 3 error showed in problem tab .
In audioClient.as
· 1119: Access of possibly undefined property info through a reference with static type flash.net:NetStream. audioClient.as /FlashPhone/src line 261 Flex Problem
· 1119: Access of possibly undefined property info through a reference with static type flash.net:NetStream. audioClient.as /FlashPhone/src line 262 Flex Problem
· 1195: Attempted access of inaccessible method getStream through a reference with static type Streams. audioClient.as /FlashPhone/src line 89 Flex Problem
But when I change Flex Compiler SDK version to 4 and use Flex compatibility 3 mode , only I have error 1195 in line 89.
I have no problem to use sample in my test server, I can call via my sip account .I can’t solve this error.
Thanks again for your help
Regards
Hi Bob,
There is a known compilation error with the sample flash phone source ; The next FMG update on Adobe Labs is likely to have it fixed.
For now, you might try recompilation after updating FlashPhone/src/Streams.as using the following steps:
1) Streams.as: Line #33 : Change method signature of getStream to public from private i.e.
public function getStream (streamName:String):NetStream {
2) Streams.as: Line #149: Inside method name subscribeStream, right after line #149, insert a new statement to attach Netstream to video display
var ns:NetStream = this.getStream(streamName); // Line #149
rootApp.videoObj.video.attachNetStream(ns); // Line #150: New statement
I hope it helps,
-Pankaj
