Hi I'm new to unit testing so I've been having issues...
I am trying to run tests with parameters and I have fixed the errors up to here by browsing the net, but I can't find why this isn't working...
Any help is greatly appreciated, thanks in advance=D
Here is the test class:
package flexUnitTests
import flexunit.framework.Assert;
import Game.Rand;
import org.flexunit.runners.Parameterized;
[RunWith("org.flexunit.runners.Parameterized")]
public class RandTest
private var classToTestRef : Rand;
private var foo:Parameterized;
public static var inputInt:Array= [ [ 1, 20 ], [ 2, 8 ], [ 16, 18 ], [ 1, 100 ], [ 16, 80 ]];
[Test(dataProvider="inputInt")]
public function testIntWithinRange(nMin:Number, nMax:Number):void
classToTestRef = new Rand();
var bInRange:Boolean = false;
var Random:int = classToTestRef.Int(nMax);
if((Random > nMin-1) && (Random < nMax-1)){ bInRange=true;}
Assert.assertTrue(bInRange);
Random = classToTestRef.Int(nMin,nMax);
[Test]
public function testStore():void
Assert.assertNotNull(classToTestRef.Stored());
public static function inputRandomSelection():Array {
return [ [ [2,3,5,7], 1, true ], [[2,3,5,7], 2, true ], [[2,3,5,7], 3, true ], [[2,3,5,7], 4, false ], [[2,2,7,7], 3, false ] ];
[Test(dataProvider="inputRandomSelection")]
public function testRandomSelectionLengthsAreCorrect(aVariables:Array, iAmount:int, bShouldWork:Boolean):void
var iCounter:int;
var Selection:Array = classToTestRef.RandomSelection(aVariables, iAmount);
//Make sure that iAmount is greater then iVarables.length
var bAmountHigher:Boolean = false;
if(iAmount > aVariables.length){ bAmountHigher = true; }
if(bShouldWork == true){Assert.assertTrue(bAmountHigher);}
else {Assert.assertFalse(bAmountHigher);}
//The correct number of varibles were returned
var bCorrectNumber:Boolean = false;
if (Selection.length == iAmount){bCorrectNumber = true;}
if(bShouldWork == true){Assert.assertTrue(bCorrectNumber);}
else {Assert.assertFalse(bCorrectNumber);}
public function testRandomSelectionArraysAreCorrect(aVariables:Array, iAmount:int, bShouldWork:Boolean):void{
var iCounter:int, iCounter2:int;
//Check that all the values reurned are unique
var bUnique:Boolean = true;
for(iCounter = 0; iCounter < Selection.length; iCounter++){
for(iCounter2 = 0; iCounter2 < Selection.length; iCounter2++){
if((Selection[iCounter] == Selection[iCounter2]) && (iCounter!=iCounter2)){ bUnique = false; }
if(bShouldWork == true){Assert.assertTrue(bUnique);}
else {Assert.assertFalse(bUnique);}
//All numbers returned were from aVariables
var bFromSource:Boolean = true;
if(aVariables.indexOf(Selection[iCounter]) == -1){ bFromSource = false; }
if(bShouldWork == true){Assert.assertTrue(bFromSource);}
else {Assert.assertFalse(bFromSource);}
And here is the trace:
Error: Custom runner class org.flexunit.runners.Parameterized cannot be instantiated
at org.flexunit.internals.runners::InitializationError(InitializationErr or.as:50)
at org.flexunit.internals.builders::MetaDataBuilder/createInitialization Error(MetaDataBuilder.as:209)
at org.flexunit.internals.builders::MetaDataBuilder/buildWithSecondSigna ture(MetaDataBuilder.as:179)
at org.flexunit.internals.builders::MetaDataBuilder/buildRunner(MetaData Builder.as:146)
at org.flexunit.internals.builders::MetaDataBuilder/runnerForClass(MetaD ataBuilder.as:115)
at org.flexunit.runners.model::RunnerBuilderBase/safeRunnerForClass(Runn erBuilderBase.as:63)
at org.flexunit.internals.builders::AllDefaultPossibilitiesBuilder/runne rForClass(AllDefaultPossibilitiesBuilder.as:106)
at org.flexunit.runners.model::RunnerBuilderBase/localRunners(RunnerBuil derBase.as:119)
at org.flexunit.runners.model::RunnerBuilderBase/runners(RunnerBuilderBa se.as:87)
at org.flexunit.runners::Suite(Suite.as:170)
at org.flexunit.internals.builders::MetaDataBuilder/buildWithSecondSigna ture(MetaDataBuilder.as:174)
at org.flexunit.runner::Request$/classes(Request.as:201)
at Function/http://adobe.com/AS3/2006/builtin::apply
at org.flexunit.runner::FlexUnitCore/runClasses(FlexUnitCore.as:191)
at org.flexunit.runner::FlexUnitCore/run(FlexUnitCore.as:171)
at flexunit.flexui::FlexUnit4TestRunner/run(FlexUnit4TestRunner.as:75)
at flexunit.flexui::FlexUnitTestRunnerUI/runWithFlexUnit4Runner(FlexUnit TestRunnerUI.mxml:148)
**[ at FlexUnitApplication/onCreationComplete(FlexUnitApplication.mxml:26) ]
**[ at FlexUnitApplication/___FlexUnitApplication_Application1_creationCompl ete(FlexUnitApplication.mxml:7) ]
at flash.events::EventDispatcher/dispatchEventFunction
at mx.core::UIComponent/dispatchEvent(UIComponent.as:12266)
at mx.core::UIComponent/set initialized(UIComponent.as:1577)
at mx.managers::LayoutManager/doPhasedInstantiation(LayoutManager.as:759 )
at mx.managers::LayoutManager/doPhasedInstantiationCallback(LayoutManage r.as:1072)
