Hi I'm new to unit testing so I've been having issues...
I am trying to run tests with parameters and I have fixed the errors up to here by browsing the net, but I can't find why this isn't working...
Any help is greatly appreciated, thanks in advance=D
Here is the test class:
package flexUnitTests
import flexunit.framework.Assert;
import Game.Rand;
import org.flexunit.runners.Parameterized;
[RunWith("org.flexunit.runners.Parameterized")]
public class RandTest
private var classToTestRef : Rand;
private var foo:Parameterized;
public static var inputInt:Array= [ [ 1, 20 ], [ 2, 8 ], [ 16, 18 ], [ 1, 100 ], [ 16, 80 ]];
[Test(dataProvider="inputInt")]
public function testIntWithinRange(nMin:Number, nMax:Number):void
classToTestRef = new Rand();
var bInRange:Boolean = false;
var Random:int = classToTestRef.Int(nMax);
if((Random > nMin-1) && (Random < nMax-1)){ bInRange=true;}
Assert.assertTrue(bInRange);
Random = classToTestRef.Int(nMin,nMax);
[Test]
public function testStore():void
Assert.assertNotNull(classToTestRef.Stored());
public static function inputRandomSelection():Array {
return [ [ [2,3,5,7], 1, true ], [[2,3,5,7], 2, true ], [[2,3,5,7], 3, true ], [[2,3,5,7], 4, false ], [[2,2,7,7], 3, false ] ];
[Test(dataProvider="inputRandomSelection")]
public function testRandomSelectionLengthsAreCorrect(aVariables:Array, iAmount:int, bShouldWork:Boolean):void
var iCounter:int;
var Selection:Array = classToTestRef.RandomSelection(aVariables, iAmount);
//Make sure that iAmount is greater then iVarables.length
var bAmountHigher:Boolean = false;
if(iAmount > aVariables.length){ bAmountHigher = true; }
if(bShouldWork == true){Assert.assertTrue(bAmountHigher);}
else {Assert.assertFalse(bAmountHigher);}
//The correct number of varibles were returned
var bCorrectNumber:Boolean = false;
if (Selection.length == iAmount){bCorrectNumber = true;}
if(bShouldWork == true){Assert.assertTrue(bCorrectNumber);}
else {Assert.assertFalse(bCorrectNumber);}
public function testRandomSelectionArraysAreCorrect(aVariables:Array, iAmount:int, bShouldWork:Boolean):void{
var iCounter:int, iCounter2:int;
//Check that all the values reurned are unique
var bUnique:Boolean = true;
for(iCounter = 0; iCounter < Selection.length; iCounter++){
for(iCounter2 = 0; iCounter2 < Selection.length; iCounter2++){
if((Selection[iCounter] == Selection[iCounter2]) && (iCounter!=iCounter2)){ bUnique = false; }
if(bShouldWork == true){Assert.assertTrue(bUnique);}
else {Assert.assertFalse(bUnique);}
//All numbers returned were from aVariables
var bFromSource:Boolean = true;
if(aVariables.indexOf(Selection[iCounter]) == -1){ bFromSource = false; }
if(bShouldWork == true){Assert.assertTrue(bFromSource);}
else {Assert.assertFalse(bFromSource);}
And here is the trace:
Error: Custom runner class org.flexunit.runners.Parameterized cannot be instantiated
at org.flexunit.internals.runners::InitializationError(InitializationError.as:50)
at org.flexunit.internals.builders::MetaDataBuilder/createInitializationError(MetaDataBuilder.as:209)
at org.flexunit.internals.builders::MetaDataBuilder/buildWithSecondSignature(MetaDataBuilder.as:179)
at org.flexunit.internals.builders::MetaDataBuilder/buildRunner(MetaDataBuilder.as:146)
at org.flexunit.internals.builders::MetaDataBuilder/runnerForClass(MetaDataBuilder.as:115)
at org.flexunit.runners.model::RunnerBuilderBase/safeRunnerForClass(RunnerBuilderBase.as:63)
at org.flexunit.internals.builders::AllDefaultPossibilitiesBuilder/runnerForClass(AllDefaultPossibilitiesBuilder.as:106)
at org.flexunit.runners.model::RunnerBuilderBase/localRunners(RunnerBuilderBase.as:119)
at org.flexunit.runners.model::RunnerBuilderBase/runners(RunnerBuilderBase.as:87)
at org.flexunit.runners::Suite(Suite.as:170)
at org.flexunit.internals.builders::MetaDataBuilder/buildWithSecondSignature(MetaDataBuilder.as:174)
at org.flexunit.runner::Request$/classes(Request.as:201)
at Function/http://adobe.com/AS3/2006/builtin::apply
at org.flexunit.runner::FlexUnitCore/runClasses(FlexUnitCore.as:191)
at org.flexunit.runner::FlexUnitCore/run(FlexUnitCore.as:171)
at flexunit.flexui::FlexUnit4TestRunner/run(FlexUnit4TestRunner.as:75)
at flexunit.flexui::FlexUnitTestRunnerUI/runWithFlexUnit4Runner(FlexUnitTestRunnerUI.mxml:148)
**[ at FlexUnitApplication/onCreationComplete(FlexUnitApplication.mxml:26) ]
**[ at FlexUnitApplication/___FlexUnitApplication_Application1_creationComplete(FlexUnitApplication.mxml:7) ]
at flash.events::EventDispatcher/dispatchEventFunction
at mx.core::UIComponent/dispatchEvent(UIComponent.as:12266)
at mx.core::UIComponent/set initialized(UIComponent.as:1577)
at mx.managers::LayoutManager/doPhasedInstantiation(LayoutManager.as:759)
at mx.managers::LayoutManager/doPhasedInstantiationCallback(LayoutManager.as:1072)
No problem. The version that came with Flash Builder 4 was the 4.0 release version of FlexUnit. We didn't introduce parameterized testing until the 4.1 beta version. If I run your code (with references to your Rand class commented out) it all works as expected which is why I guessed we were on different versions.
Go here:
http://www.flexunit.org/?page_id=14
Download the 4.1 RC1 code (which will be released very shortly). You will get a bunch of libraries and docs in the zip file. You can ignore mos
...Copy link to clipboard
Oh, also I'm using Flahs Builder 4 build 272416 😃
Do you know what FlexUnit build you are using or is it just the one that came with Flash Builder?
Mike
It just came with Flash Builder 4, I was using Flex 3 before but upgraded cause I'm wanting to try TDD.
Go here:
Download the 4.1 RC1 code (which will be released very shortly). You will get a bunch of libraries and docs in the zip file. You can ignore most of that for now. All you really need is the flexunit-core-*.swc file. Extract that one and drop it in the libs folder of your project and your code will likely run just fine.
Mike
In the Plug-ins tab of the Flash Builder Installation Details, it claims that I have version 4.0.0.272416 of everything to do with flexunit.
Great. Just updating that core swc file should take care of everything. You could replace the version FlashBuilder uses directly, or just drop it in the libs folder of your project which will effectively trump the version that comes with Flash Builder.
Mike
Yep, I posted my last post after you posted yours which made it alot more redundant... Either way, I don't have the error any more... I have a BUNCH more to keep me busy now! Thanks a bunch Mike!
You got it.
Mike
