Locked
Flash shows green screen when playing videos
Jun 10, 2010 Jun 10, 2010
I installed 10.1 today and any time I play a flash video on hulu on youtube all it shows is a green screen, the sound works fine. I'm using firefox and windows 7 x64, video card is an ATI 4870. If i disable hardware acceleration it works but the video stutters a bit (not surprising), I was under the impression that with 10.1 hardware acceleration would work now.
I have the 10.2 version of ATI Catalyst drivers installed.
104.6K
Community Beginner , Dec 21, 2011 Dec 21, 2011
Ok it's been a year and a half and I figured out why I was having problems now, I had to replace my motherboard for unrelated issues and when I did that Flash started working normally, I didn't reinstall windows when I did that so it must have been that. I think there may have been a voltage issue accross the PCI-e slot as I was having some other video issues at the end as well.
Guest
Hi, the following thread may be helpful to you:
http://forums.adobe.com/message/2706243#2706243
Hope it helps.
eidnolb
I actually just installed the new version today, so the beta patch they mention wont help.
Guest
Hi, I should have read the entire thread. Well that doesn't sound good, if the beta was the fix, and now you have Installed the final release and have the green screen. Hmmmm.
Someone today had that issue and there was a response and it wasn't the beta. Ok, I found it. This user had a flashing green screen, but take a look.
http://forums.adobe.com/thread/657387?tstart=0
If this is a common issue, then we'll be receiving more threads and hopefully have a solution. I have never seen that, so don't have anything to suggest.
eidnolb
This is displaying on a 22" monitor at high rez, not much there
Guest
Hi, well so much for that. So back to square one. Do you think this is due to the 10.1? Did you ever experience this with the 10.0.45.2 version? I would just guess no. Until today I had not heard of anything like you describe nor those other threads.
You do have the Shockwave Flash Object Enabled in the IE add ons don't you? Check all add ons for it.
Then using FF, find the plug-in SWF and it should be Enabled as well.
Then you can also use this Adobe test site, first Using IE, then Using FF:
http://www.adobe.com/software/flash/about/
Let me know.
eidnolb
Nov 27, 2010 Nov 27, 2010
VERY Simple Solution.
When it plays in Green.
Right Click on the video
Uncheck Hardware Acceleration
Refresh Window
Problem solved.
[sig deleted by host]
Enthusiast ,
Dec 30, 2010 Dec 30, 2010
Unchecking harware accleration worked for me, Thanks Ed.
Jay
Glad that helped Jay. I had to do it in both my firefox browser and internet explorer browser. After that I haven't had to do anything since.
Nov 09, 2011 Nov 09, 2011
In my case, the browser hung on the 'green screen', so there was no ability to right-click in the video area to disable hardware acceleration.  There's no option to disable hardward acceleration prior to playing the video.  This problem occurred with all latest version of all browser and standalone flash players (i.e. Sothink FLV player).  The only way I was able to disable hardware acceleration was to go to this site: http://kb2.adobe.com/cps/839/cpsid_83952.html and then right-click on the Flash logo block.
Flash and ATI's Catalyst drivers used to work and play well together, but obviously, that's no longer the case.  After today's announcement from Adobe (conceding defeat of Flash to Apple/HTML5), it's probably hopeless to think that any more resources will be devoted to fix any more problems with it.
danno33 wrote:
Flash and ATI's Catalyst drivers used to work...
You may need to update the drivers for your display adapter.
Sorry, I should have mentioned that I had already updated the Catalyst driver to the latest version with no success.
Dec 20, 2011 Dec 20, 2011
The fix is however simple and its not ur catalyst driver or adobe. While you are on a video page, right click anywhere inside the Flash Player and choose settings. Now click the first tab that says Display (look for the monitor icon) and uncheck “Enable Hardware Acceleration.” Then hit F5 or refresh..
Please read my 11/9 message above - there's no option to right-click inside the Flash Player because the browser (all of them FF, IE, Chrome) has locked up and hung.  I just downloaded and installed another update to the Catalyst driver and the problem still exists, so I still believe it's the Catalyst driver that's to blame.  I've reported the problem to ATI/AMD, but since it's been at least 6 weeks without a response or fix, I assume that they've ignored it.
Feb 05, 2012 Feb 05, 2012
Thanks man! Unchecking the hardware acceleration works for me!
Feb 07, 2012 Feb 07, 2012
No problem! Ur welcome
[private data removed]
Apr 06, 2012 Apr 06, 2012
for anyone else with nothing above working for you like me.....
i had to go into Global Settings >>  Advanced Tab >>  Delete All browsing settings and data.
refresh site page.
working again.
