Jhepworth
Another CS4 glitch - unable to clear keyframes
Nov 28, 2010 2:06 PM
A new glitch (amongst the millions I already have) in CS4, is that recently i will be unable to clear keyframes. I usualy do this by selecting the keyframes in the timeline, right clicking and selecting 'clear keyframes' but it's greyed out frequently, I can't work out why this is and I don't know of a cure/ work around for this? I tend to just go in and out of symbols until it works. this is sucbh a pain. Anyone had this and able to help?
    Nov 28, 2010 8:38 PM   in reply to Jhepworth
    If you right click on just one of the keyframes, is the menuitem enabled?
    Dec 1, 2010 1:39 PM   in reply to Jhepworth
    I haven't seen this problem before in the versions. Do you have a file that we could look at? Or is it every single file such as a brand new file, always?  I'm not sure what to suggest.
    Dec 1, 2010 2:56 PM   in reply to Jhepworth
    So this is an intermittent problem?  When it does happen on a particular frame, is it always greyed out on that frame, or will it then start working sometimes?
    When you see this happen, can you attach the file and note specifically which frame it's not working on?
    Can you also post your system information (OS). Also, although this isn't a known bug, I'd make sure you're updated to 10.0.2 that has many bug fixes.
    Dec 24, 2010 6:12 PM   in reply to Jhepworth
    I just experienced something similar.  I could click on Clear Keyframe->All, but nothing happened.  I tried many many times, but to no avail.
    Dec 24, 2010 6:15 PM   in reply to barpos
    Actually, only the first frame of a tween has this problem.  Who knows, maybe it is normal??
    Ron
