I'm getting the following error:
TypeError: Error #2007: Parameter text must be non-null.
at flash.text::TextField/set text()
at Function/<anonymous>()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
This is my code:
myButton.addEventListener(MouseEvent.CLICK, onClickNewFB);
function onClickNewFB(e:MouseEvent):String{
var req:URLRequest=new URLRequest(e.target.name+".txt");
var infoLoader:URLLoader=new URLLoader();
var myInfoLoader:String;
infoLoader.load(req);
myInfoLoader=infoLoader.data;
infoLoader.addEventListener(Event.COMPLETE, loadFeedbackText);
//OSD_feedbackText.text=e.target.name;
return myInfoLoader;
function loadFeedbackText(e:Event):void{
//OSD_feedbackText.text=infoLoader.data;
OSD_feedbackText.text=myInfoLoader;
trace(myInfoLoader);
How do I fix this? I'm sure I have an incorrect order of operations and I probably shouldn't declare a function within a function but I don't know how else to approach the solution. Any help is much appreciated.
-markerline
that means whatever you're trying to load, isn't being found by flash. use the trace() function to see what you're trying to load
Instead of the name of my txt file coming back it's coming back in the output window as "[Object URLRequest]". That means that the name of my txt file is not being parsed. How come? I'm using trace(req);
Now I'm getting #1067: Implicit coercion of a value of type String to an unrelated type flash.net:URLRequest . . for the following code:
var req:URLRequest=new URLRequest(e.currentTarget.name+".txt");
var myStr:String= new String();
var req2:URLRequest=new URLRequest(myStr);
myStr=e.target.name+".txt";
infoLoader.load("\""+req2+"\"");
trace(myStr);
The error is being thrown on this line:
I can trace the results of myStr and it gives me the correct filename. But I cannot seem to pass this filename into my infoLoader.load() method. What do I do next?
-markerline
I fixed the code in the following way:
var req2:URLRequest=new URLRequest('\"'+myStr+'\"');
infoLoader.load(req2);
trace(myStr);
but now I'm getting Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL: file: <<filename>>
where <<filename>> is an actual location on my computer
at FlashFileName::MainTimeline/onClickNewFB()
. . . I am at a loss. If I can pass the string to the URL Request and the file exists in my directory, then why am I getting an IO error?
P.S. I should note that <<filename>> actually appears as ///C|Users/[username]/[directory]/"FILENAME.txt" with the double quotes around the filename. I also had to put myStr=e.target.name+".txt"; above the previous line to get this far. If I change the URLRequest to new URLRequest(myStr) then I don't even get an IO Stream error. I get
-markerline
Message was edited by: markerline
you shouldn't be using an absolute path to your file. use a relative path so everything works without security issues and without changing when you upload to a server.
Yes, kglad. I'm well aware of the benefits of relative paths. I was actually simply passing the filename as it stands without directory information but the output console gave me the full path of the filename, which means it's looking in the right place, but it's wrapping the name of the file (not the entire path) with quote marks. I have since changed my file to not use this scripted method for identifying which file to read and have built the text content into movie clips and accessed the movie clips from frame labels on the timeline. However I would still like to know how to do it the scripted way for the benefit of me learning how to properly apply this method and for the benefit of others wishing to do the same.
-markerline
you're doing everything correctly except when constructing your urlrequest. your argument is incorrect in the urlrequest constructor is problematic.
use the trace() function to see what that is and debug.
