I don't even know if I am in the right forum, but I hope that someone out there in cyber world will be able to help me on this.
I have a PDF document that I downloaded, unfortunately, I forgot to rename the document and it saved under the source path which is about a mile long. Now, I can't open it, delete it or move it. I just want it to go away at this point, but I am unable to comply with the error suggestion.
The error report reads:
Source Path Too Long
The source file name(s) are larger than is supported by the file system. Try moving to a location which has a shorter path name, or try renaming to shorter name(s) before attempting this operation.
I can't even figure out how I am supposed to rename the dang thing. Please help, this is just irritating the snot out of me.
thanks,
F.
I had the similiar problem and finally I found solution:
www.tooLongPath.com
I had a problem like that. This worked for me!
Path too long.
Error cannot delete file: cannot read from source file or disk
Cannot delete file: Access is denied
There has been a sharing violation.
Cannot delete file or folder The file name you specified
is not valid or too long. Specify a different file name.
The source or destination file may be in use.
The file is in use by another program or user.
Error Deleting File or Folder
Make sure the disk is not full or write-protected and that the file is not currently in use.
Path too deep.
I had the similiar problem and finally I found solution: http://LongPathTool.com
Long Path Tool helped me in this situation. http://PathTooDeep.com
I hope this works for you too!
