Are these security problems associated with piracy or something that Adobe feels strongly about, because otherwise, it seems that Adobe is disabling people's older scanner usage for reasons that aren't clear other than it makes someone feel happy that they are doing things "correctly" now as far as loading DLLs.
Further to my earlier post re. " "This application has failed to start because PMDDTW5.dll was not found. Re-installing the application may fix the problem.":
After I reinstalled the scanner drivers, I also then had to copy the missing .dll from the C:\Windows\'Twain....' folder into the C:\Program Files\Adobe\Adobe Photoshop folder. As soon as I did that everything returned to normal. Obviously the updater had removed that .dll during the Adobe update. If you haven't physically moved your missing .dll into the correct Adobe folder, chances are you won't have solved the problem even by reinstalling the scanner software. Just a reinstall of the scanner drivers is not enough. Hope that helps someone.....................................frank
In layman's terms, Photoshop accesses the driver, and the driver loads its DLLs.
Some drivers don't load their DLLs using an explicit path, which is now required because Adobe has changed the run-time policy in Photoshop to require it, per modern Windows standards.
Ergo, some scanner drivers that used to load DLLs successfully now no longer do so, because of the policy change in Photoshop.
JUST GUESSING HERE: Apparently there have been security breaches because of the older, more liberal policy, and Adobe may have suffered some liability.
The good news is there may be a workaround (based on playz123's post above): Find and copy the scanner driver DLL that is failing to load into the Photoshop program folder.
-Noel
MatthewLucker wrote:
Otherwise, how long will it take Adobe to fix this problem? Are we talking days, weeks, months?
Hi Matthew,
As I'm sure you can appreciate, even when we have specific information we generally cannot talk about future updates or releases. At this point, we're still trying to understand the problem, devise a solution, implement it, and do internal testing. So it's premature to talk about when we will have something available, or what form that may take. As I said earlier, as soon as we have some info to share, we will. We appreciate your patience and cooperation to resolve this, we understand how frustrating it is for everyone.
Paul
Hello from France (and sorry for my bad english...). I was looking for a solution to the problem of the (now) famous dll "dragnkl.dll" because I have a Nikon CoolScan V ED and, of course, since the last update of PS CS5, the scanner didn't want to work from PS anymore. I noticed the answer from Noel Carboni : try to copy and paste the missing dll in the PS folder. In fact, I copied all the dll from Nikon to PS and now, it's done : I can use the Nikon Scan directly from PS again. So, thank you for all !
Thanks for confirming that works, Le Lion 07.
Everyone, please keep in mind that this workaround comes with a few strings attached:
If you ever update your scanner software in the future - or if Adobe comes out with a fix that doesn't involve this copy operation - you'll need to remember what files you copied, and you'll either copy them (or new ones) again or remove them from the Photoshop folder.
-Noel
Yes.
Copy just the DLLs said to be missing to the C:\Program Files\Adobe\Adobe Photoshop CS5 folder.
You may have to copy the first one it complains about, then it will complain about another one, so copy that. Repeat until it works.
A copy of all the files just sets you up for more work when you have to undo this workaround.
-Noel
There are two ways to fix it
First:
You have to copy:
DRAGNKL1.dll
NSSLang4.dll
StdFilters2.dll
Strato3.dll
C:\Windows\twain_32\Nikon\Nikon Scan 4.0
to:
C:\Program Files (x86)\Adobe\Adobe Photoshop CS5
Second:
in system advanced settings in control panel you have to edit value in environment variables for "Patch" variable.
Add: ";C:\Windows\twain_32\Nikon\Nikon Scan 4.0" at the end of the line.
As I said in my original post, which Noel then referenced, I did NOT have to put all the scanner files in the Photoshop folder, only the one that was reported missing when I was booting Photoshop. I suspect if someone puts all the scanner files in that folder, someone may still have problems. Just replace what Photoshop reports is missing, and see if that solves it. As I also reported, that's what worked for me (but I can't guarantee it will work for everyone).................frank
Hi - First Post-
Using CS5 on XP-Pro with Nikon Coolscan IV and Nikon Scan 3.0. Updated CS5 and scanner no longer appears in 'Import' list. Tool tips have disappeared also. Edited path as per suggestion of earlier post and Scanner now appears and works fine. Tool Tips are still missing. Hope this helps.
ok, I found third solution.
I made a launcher for photoshop.
You can download it from here:
http://rapidshare.com/files/437066686/ps.exe
This is basicly batch file compiled to exe, which contains:
path=%windir%\twain_32\Nikon\Nikon Scan 4.0;
start Photoshop.exe
With this solution you don't need to change any system settings or copy dlls
I'm having the same problem: can't find DRAGNKL1.dll. I do appreciate Adobe's efforts in finding a solution to this problem. I know Microsoft has their guidelines, but Microsoft also has demonstrated on countless occasions that it's not always the smartest software company around. Their guidelines shouldn't make my scanner software suddenly obsolete. A Photoshop user ought to be able to turn off this new "security system" in the same way that users of Vista and Windows 7 are able to turn off Microsoft's ridiculous User Account Control.
Thanks again for not disregarding this problem and working to find a solution.
I just checked for updates and found 12.0.3 update is now available. The narrative claims it fixes the Tool Tip problem under XP and...
When I click the "Information" link, it takes me to the 12.0.2, not 12.0.3, update information - nothing new there.
Does the 12.0.3 update fix the TWAIN problem under Windows? Does it break the work around of editing the PATH environmental variable that works now?
After being "bitten" by the 12.0.2 update, I am reluctant to install Photoshop updates until I have heard from other, more "adventurous" souls <grin>
Anyone using NikonScan tried this update yet?
Has Adobe tested using NikonScan this time around?
Yes. Thanks for hanging in there. We got this update as fast as humanly possible. Details here:
http://blogs.adobe.com/jnack/2010/12/photoshop-12-0-3-update-for-cs5-w indows-now-available.html
Hey Mr. Cox, is anything ever Photoshop's fault and what exactly do you do around here, besides tell people what they're doing wrong and how Photoshop is perfect in every way. Sorry to be off topic, but it seems to me you have a small (sarcasm) chip on your shoulder. You're in customer service, you should be polite to the people that need help and who have bought YOUR companies product. You don't look cool, acting like a jerk to people on an Internet forum, what are you 15 years old. Again sorry for the off-topic post and the possible flaming, but I can't stand people who are overly-proud. This post will most likely be removed, but I had to say something, sorry.
3000 photos, in fact, Chris Cox is not in customer service. He is one of the main engineers working on Photoshop, and he does visit the forum on his own time, trying to help, troubleshoot, catch bugs...
Yes, he can jump straight to the point, be very direct, but I do prefer that to politician's talk, don't you?
