Voting poll using PHP & MySQL >>TypeError: Error #2007: Parameter text must be non-null.
Dec 12, 2010 Dec 12, 2010
I am getting this back:
at flash.text::TextField/set text()
at AS3_Flash_Poll_PHP_MySQL_fla::WholePoll_1/completeHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
PHP code:
<?php
// ---------------------------------------- Section 1 -----------------------------------------------
//  IMPORTANT!!!! Connect to MySQL database here(put your connection data here)
mysql_connect("ginaty05.fatcowmysql.com","fall2010","@regina") or die (mysql_error());
mysql_select_db("poll_2010") or die (mysql_error());
// When Flash requests the totals initially we run this code
if ($_POST['myRequest'] == "load_numbers") {
// Query the totals from the database
    $sql1 = mysql_query("SELECT id FROM votingPoll WHERE choice='1'");
    $choice1Count = mysql_num_rows($sql1);
    $sql2 = mysql_query("SELECT id FROM votingPoll WHERE choice='2'");
    $choice2Count = mysql_num_rows($sql2);
    $sql3 = mysql_query("SELECT id FROM votingPoll WHERE choice='3'");
    $choice3Count = mysql_num_rows($sql3);
    echo "choice1Count=$choice1Count";
    echo "&choice2Count=$choice2Count";
    echo "&choice3Count=$choice3Count";
// ---------------------------------------- Section 2 -----------------------------------------------
// IF POSTING A USER'S CHOICE
if ($_POST['myRequest'] == "store_choice") {
    //Obtain user IP address
    $ip = $_SERVER['REMOTE_ADDR'];
    // Create local variable from the Flash ActionScript posted variable
    $userChoice = $_POST['userChoice'];
    $sql = mysql_query("SELECT id FROM votingPoll WHERE ipaddress='$ip'");
    $rowCount = mysql_num_rows($sql);
    if ($rowCount == 1) {
$my_msg = "You have already voted in this poll.";
print "return_msg=$my_msg";
    } else {
$sql_insert = mysql_query("INSERT INTO votingPoll (choice, ipaddress) VALUES('$userChoice','$ip')")  or die (mysql_error());
$sql1 = mysql_query("SELECT * FROM votingPoll WHERE choice='1'");
$sql2 = mysql_query("SELECT * FROM votingPoll WHERE choice='2'");
$sql3 = mysql_query("SELECT * FROM votingPoll WHERE choice='3'");
$my_msg = "Thanks for voting!";
        echo "return_msg=$my_msg";
        echo "&choice1Count=$choice1Count";
AS3 code:
stop(); // Stop the timeline since it does not need to travel for this to run
// Assign a variable name for our URLVariables object
var variables1:URLVariables = new URLVariables();
//  Build the varSend variable
var varSend1:URLRequest = new URLRequest("parse_my_poll.php");
varSend1.method = URLRequestMethod.POST;
varSend1.data = variables1;
// Build the varLoader variable
var varLoader1:URLLoader = new URLLoader;
varLoader1.dataFormat = URLLoaderDataFormat.VARIABLES;
varLoader1.addEventListener(Event.COMPLETE, completeHandler1);
// Set variable to send to PHP here for the varloader below
variables1.myRequest = "load_numbers";
// Send data to php file now, and wait for response using the COMPLETE event
varLoader1.load(varSend1);
function completeHandler1(event:Event):void{
    count1_txt.text = "" + event.target.data.choice1Count;
    count2_txt.text = "" + event.target.data.choice2Count;
    count3_txt.text = "" + event.target.data.choice3Count;
// hide the little processing movieclip
processing_mc.visible = false;
// Initialize the choiceNum variable that we will use below
var choiceNum:Number = 0;
// Set text formatting colors for errors and success messages
var errorsFormat:TextFormat = new TextFormat();
errorsFormat.color = 0xFF0000; // bright red
var successFormat:TextFormat = new TextFormat();
successFormat.color = 0x00FF00; // bright green
// Button Click Functions
function btn1Click(event:MouseEvent):void{
    choiceNum = 1;
    choice_txt.text = choice1_txt.text;
function btn2Click(event:MouseEvent):void{
    choiceNum = 2;
    choice_txt.text = choice2_txt.text;
function btn3Click(event:MouseEvent):void{
    choiceNum = 3;
    choice_txt.text = choice3_txt.text;
// Button Click Listeners
btn1.addEventListener(MouseEvent.CLICK, btn1Click);
btn2.addEventListener(MouseEvent.CLICK, btn2Click);
btn3.addEventListener(MouseEvent.CLICK, btn3Click);
var variables:URLVariables = new URLVariables();
var varSend:URLRequest = new URLRequest("parse_my_poll.php");
varSend.method = URLRequestMethod.POST;
varSend.data = variables;
var varLoader:URLLoader = new URLLoader;
varLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
varLoader.addEventListener(Event.COMPLETE, completeHandler);
// Handler for PHP script completion and return
function completeHandler(event:Event):void{
    // remove processing movieclip
    // Clear the form fields
    choice_txt.text = "";
    choiceNum = 0;
    // Load the response from the PHP file
    status_txt.text = event.target.data.return_msg;
    status_txt.setTextFormat(errorsFormat);
    if (event.target.data.return_msg == "Thanks for voting!") {
        // Reload new values into the count texts only if we get a proper response and new values
        status_txt.setTextFormat(successFormat);
// Add an event listener for the submit button and what function to run
vote_btn.addEventListener(MouseEvent.CLICK, ValidateAndSend);
// Validate form fields and send the variables when submit button is clicked
function ValidateAndSend(event:MouseEvent):void {
    //validate form fields
    if(!choice_txt.length) {
        // if they forgot to choose before pressing the vote button
        status_txt.text = "Please choose before you press vote.";
    } else {
        status_txt.text = "Sending...";
        processing_mc.visible = true;
        // Ready the variables for sending
        variables.userChoice = choiceNum;
        variables.myRequest = "store_choice";
        // Send the data to the php file
        varLoader.load(varSend);
    } // close else after form validation
} // Close ValidateAndSend function ////////////////////////
ActionScript
585
Dec 13, 2010 Dec 13, 2010
This error means that you are trying to set the text field but there is no data in the variable. As a first step, try to identify where this is happening, eg Is it the first call, or once you have submitted your data or only if you try to submit data second time?
Trace out the data that is returned for both completeHandlers to see if there is a missing var. Try this for "load_numbers" and "store_choice". Do it twice for "store_choice". Do you get back what you expected?
You could also try altering the php to return some fixed dummy variables, eg  choice1Count=11&choice2Count=22&choice3Count=33, etc. If this works then you know that the error is in the PHP.
It looks to me like the issue is when you submit the data a second time and just get back the return_msg - the handler then tries to assign the choice1Count etc but doesn't have any count data back from the poll.php.
Test that there is data before assigning it, eg
    if(event.target.data.choice1Count){
        count1_txt.text =  event.target.data.choice1Count;
        count2_txt.text =  event.target.data.choice2Count;
        count3_txt.text =  event.target.data.choice3Count;
