One of our clients use an application to digitally distribute and
approve incoming invoices. The scanned invoices (PDF's) are
visualised in the webbased application by using the embedded Adober Reader 9.0 in Internet Explorer 8.0.
While there is no problem printing PDF's, on some pc's it is impossible to save a PDF. When you click on the save icon, nothing happens.
This issue has been resolved on some pc's by reinstalling Adobe Reader, but not on others.
Does anyone know what causes this problem and how it can be resolved?
Thanks in advance!
Thomas
Thomas-
I have the same problem...
New computer - Windows 7 Adobe Reader 9.3 the save buttoin does NOTHING!
Old computer - Windows XP - Adobe Reader ver 8 - same online statements - no problem!
I uninstalled Adobe 9 and re-installed the program - no change. It will print fine but not save the file.
Called Adobe customer service ... spent 16 minutes on hold wiating for a representative-
Finally got a person - she was of NO HELP WHATSOEVER other than to direct me to this forum.
-Elaine
I have Windows Explorer 8 and Vista Home Premium 64 bit on two pcs. I can save all downloaded pdf files on one, but can't save my bank statements and credit card statments on the other. I can save pdf files that aren't from protected sites. I have installed all updates to no avail.
I can save my bank statements if I turn off the protected mode, but can't get in to my credit card accounts with the protected mode off.
I discovered the same problem after getting a new computer running Win7 64bit, Office2010, Adobe 9.4.0 MUI...Microsoft store installed the latest Adobe Reader version. I don't know what MUI is, stands for, etc... All I know, is until I got this new computer, I could open any pdf and do a 'save as'...and now I can't! Is there a solution here Adobe???
Adobe Reader MUI is Adobe's Multilingual User Interface version. This product is capable of installing any combination of supported languages.It is different from normal reader.I need to know few things before I can help you:
1.Now,are you not able to save ANY pdf or only some specific pdf?
2.Is the Save as option disabled?
3.Are you able to save pdf when you open them directly in Reader.Do one thing,open any pdf in Adobe Reader and just try to do "Save as" for it.Now close Reader and open same pdf in Internet explorer and try to save it from there.Please let me know the result.
Yes, that is exactly what I did and still nothing. The save option had disappeared from both the web based reader as well as the desktop one. I went into the settings and changed it for the desktop one to bring back the save option. I even restarted my pc after that to see if it will have any effect on the web based one. But nothing. This is getting really frustrating now ![]()
For me, the problem is present in both IE and Chrome. My OS - Win 7 32 bit.
I can save a pdf file from the Adobe Reader program...it IS when downloading a pdf from the internet. A simple task that we've all done millions of times, doing a save or save as from a downloaded pdf. I use IE8. I did just discover that it's not every site! It's most frustrating when attempting to save my business' bank statements! Something I've done for years. Is there something that can be done? Thanks
I was having same problem with inability to save from some sites - especially utility statements. I had Adobe Reader 9 and just upgraded to Reader X. When I open statements online now, I CAN save them as pdfs. You don't see the "normal" pdf menu (like the Save icon) but if you go to the top menu, you can do a Save As.
Vista, IE 7.
I finally figured out MY problem...3 months ago, when I purchased my new computer...I paid to have my information migrated to my new computer. I had a LOT of problems that kept cropping up. Took it back, took them 4 days - got it back, everything is working fine -I can save every pdf now! So my problem was the transfer - someone screwed up big time on my computer! Hope everyone gets their problem fixed.
Michelle Brubeck
I have the same problem but it only happens with some PDF files. The disk icon does not display and the File/Save As option doesn't do anything.
However, if I launch IE 8 with the Run as Administrator option I can save the file as expected.
I sure hope this problem gets fixed soon as it is a pain.
Emery
No tool bars, menus etc show up, just the form. The mouse turns into a hand and has either an up arrow or down arrow depending on whether you've moved to the last section of the form or back to the top. Right-click, or left-click, either one only moves you to another section of the form; you don't get a related menu, options, or anything else that is helpful.
Although not a direct solution, I found a solution today. In the source of the PDF (before opening pdf.) right click on download link, & select save as to your desired location. It's an end around, but it works. It would be nice if Adobe would address this issue. My files are supposed to be printable according to the properties in the PDF Reader.
I have been having the same problems with bank statements using Vista. After reading the posts on this forum, I upgraded to Reader X. The floating menu save button still does not work, but "shift+control+s" does work. I made the mistake of checking "do not show this message again" in response to the statement about not not saving any changes, and the shortcut would no longer work. So I uninstalled and reinstalled reader X and now working again only with the shift+control+s.
I had the problem of not being able to save some PDFs opened in IE8 using Adobe Reader X ("save" button was greyed out on the toolbar); also tried upgrading to IE9 (running on Windows 7 Professional 64 bit, but had the same problem running in XP virtual mode). It seems that PDFs open using an Adobe Plug-in rather than the full program by default. To solve the problem, I opened up the Adobe Reader, went to "edit", "preferences", then unchecked the "display PDF in browser" box of the "internet" tab. Now when opening a PDF in IE, the "save" icon is still greyed out, but since the full Reader is open I have the toolbar at the top and can click on "file", "save as". (Note in IE9, when you click on the PDF link you will first be asked if you want to open or save. If you just chose "save" the document will automatically be placed in your "downloads" folder). I hope this helps someone!
As one poster points out below, this continuing problem with Adobe Acrobat 9 can be worked around by changing the default for how pdf files from the web are displayed. Go to Edit>Preferences>Internet uncheck the box that says Display PDF in Browser. The web pdf file will now appear in Acrobat. The save file button will still not function but under the file menu, select Save As, and the file can be successfully saved.
I don't know if this has been fixed in Adobe Acrobat 10, but the fact that Adobe have not bothered to provide a fix for version 9 says a lot about how they see the relation between profit and the responsibility to fix defects they have created and sold to consumers on an "as is" basis.
Hi Guys,
I have Win 7 64bit as well, and I have the same problem.
A pain when you're doing research and opening lots of browser windows
with PDFs in em.
What I've found is that this is an Internet explorer issue.
Everything works perfectly fine in Firefox.
You can save, print, the works, with no problems.
Looks like Microsoft have to do something with IE.
Phil
RE: I had the same issue(Couldn't Save PDF Files) with Explorer 9, Adobe 9.4 and Windows 7
I fixed it by using internet options, security, Trusted Sites, turning off protection mode and entering the site as trusted. The issue is different in Chrome but it is a setting in Chrome.
Kudos to AL the MN Realtor!!! I was frustrated by the exact issues of being unable to save plus being unable to access the properties on my network printer using the embedded Adobe with Explorer 9, Adobe Reader 9.4 in Windows 7 64bit. I did as mentioned above adding the siteI was having troubles with to the trusted sites list and Voila!! works like a charm! Two thumbs up.
I pick up this thread because I have the same problem of inactive floating toolbar, also the inactive menubar at the top of the embeded Adobe Reader-X's window.
Additional symtom may be useful to diagnosis --- Outside of Internet Explorer, if I open a pdf file, the Adobe Reader X gives blurry fonts - but this burry font behaviour does not happen to the embeded window inside the IE9.
I tried to search a solution all over the places but am very disappointed. My system is a brandnew Windows 7 Enterprise, 64-bit.
Your help would be appreciated.
Some one helped me to identify my problem - I post it here and maybe it could be useful for someone else.
Quoted from the help:
Is your Display setting set to "Make text and other items larger or smaller > Larger - 150%" (Win7: Control Panel > Appearance and Personalization > Display > Make text and other items larger or smaller > Larger - 150%)? If it is, then try the following:
1. Launch Reader
2. Choose Edit > Preferences > General > uncheck "Enable Protected Mode at startup"
This was exactly what you expected! After I did what you suggested, it works now! My many thanks for your suggestion.
Following this, I have to change the display setting to 125%. This change solves everthing: inactive toolbars within IE9 as well as the blurry font problem of Adobe Reader outside of IE9!!!!
Do you have any further solution to the problem associated with 150% display setting? If yes, it would be my bonus - my sight reading needs larger fonts. Otherwise, I can live with the 125% setting.
See this http://forums.adobe.com/thread/869951 and the response from me - CADITC - and hopefully it will solve your problem.
