How to release memory when deleting tiles?
Jan 19, 2010 2:07 PM
How can we release memory when removing tiles from a view?
Do we have to handle this inside the tile?
Or is it supposed to be done by the shell itself ?
Thank you!
    Jan 20, 2010 5:04 AM   in reply to matetnic
    AFAIK the memory management of opening and closing tiles is handled by the Mosaic framework.  There is nothing that you should need to do as a tile developer.
    Jan 20, 2010 10:18 AM   in reply to matetnic
    I spoke with the Developers about this issue.  Unfortunately there doesn't seem to be an immediate solution:
    Mosaic runs into the same flashplayer memory issues that other apps using SWFLoader experience. Mosaic 9.0.1 will include some memory optimization to help reduce the problem... [Engineering is] working ... to isolate the issues and get a fix.
    Dec 15, 2010 6:31 PM   in reply to Hodmi
    Hello,
    I'm also facing same problem, when I remove and add tiles in the view application crashes, Is there any fix for this?
    Sharath
    Dec 16, 2010 6:17 AM   in reply to sharathchandra s
    The original problem was with the Mosaic 9.0 product, and has been fixed since.  If you are seeing something similar with the current release (9.5.0.1), then I suspect its another cause (although the symptoms may be similar).
    Can you share the code segment that adds/removes the tile?
