where are swcs and bin directories?
Dec 20, 2010 11:47 PM
am also getting these errors (in  additon to others reported before) after latest SVN checkout (19495) and  importing insync sample project:
where are the bin directories?
cannot find them anywhere in the installation.
find . -name Module.swc -print;
nothing here...
find . -name Module\* -print;
doesn't show any bin dirs either.
do we need to build all this using Maven?
if so, what about all the build errors reported before?
Description    Resource    Path    Location    Type
unable to open '/Module/bin/Module.swc'    insync-modularExtended-api        Unknown    Flex Problem
unable to open '/Observer/bin/Observer.swc'    insync-basic        Unknown    Flex Problem
    Dec 21, 2010 3:00 AM   in reply to BugsBn
    Hi Gary,
    I'm trying to reproduce your issue, have you imported the projects located in the libraries folder as well?
    /Module/bin/Module.swc,  '/Observer/bin/Observer.swc'  relates to projects that should be located in your workspace.
    Dec 21, 2010 4:32 AM   in reply to BugsBn
    You should declare the M2_REPO in your workspace linked resources: Preference->General->Workspace->Linked Resources.
    The M2_REPO variable should point to your local maven repository.
    Regarding the bin folders, you can either import the other projects in your workspace or copy the generated libs that you built with Maven (and rename them if you want).
    Dec 22, 2010 1:59 AM   in reply to BugsBn
    It seems that you do not have the ant plugin install on your Flash Builder. Which version of the builder are you using?
    Jan 27, 2011 2:50 PM   in reply to BugsBn
    I'm in exactly the same situation. I'm using Flash Builder Standard 4.0.1 (build 277662) along with the 4.1 Flex SDK. I've checked out the project http://opensource.adobe.com/svn/opensource/cairngorm3/trunk/samples/in sync/insync-basic and when I try to build it I get the error "unable to open '\Observer\bin\Observer.swc'".
    I think I have the Ant plug-in installed. That is, if I try to install from Ganymede Update Site \ Java Development \ Eclipse Java Development, I get the message "Eclipse Java Development Tools will be ignored because it is already installed."
    Other things I've tried:
    1) Setting up Maven (it works).
    2) Getting http://opensource.adobe.com/svn/opensource/cairngorm3 to my local folder C:\Program Files (x86)\Adobe\Adobe Flash Builder 4 Plug-in and setting the environment variable M2_REPO to C:\Program Files (x86)\Adobe\Adobe Flash Builder 4 Plug-in\cairngorm 3\maven-repository.
    This really should not be so hard.
    Jan 28, 2011 2:30 PM   in reply to scotchfasterr
    I eventually got this to work by creating a brand new project and copying in files. A description of what I went through and a ZIP file containing the fixed project can be found here:
    http://journeysinflexland.wordpress.com/2011/01/28/wwcbd/
