I have a mess in Lightroom 3 as far as folders (and on my hard drive). I want to reorganize everything into a single main folder, subdivided by date, and rely on keywords and collections for sorting. I know everyone does it different but I am wanting to go the Scott Kelby route, "You can have as many sub-folders inside that one main folder as you want, but if you want to have peace, calm, and order in your Lightroom, the key is not to import photos from all over your computer. Choose one main folder and put all your photos inside that folder. THEN import them into Lightroom."
My question is, since I already have photos in many places on my computer and a lot of folders in Lightroom, how do I go to this format. I am tempted to move all of my photos on my computer out of their current folders and into one giant folder (/Photos) and reimport everything into a new catalogue by date. My concern is I will lose the existing "lightroom data" associated with those photos (flags, picks, ratings, key words, develop settings...). Hoep that makes sense and someone can help me out.
If you re-import, you will lose collections, flags, develop history, stacking and virtual copies, even if you have written out the XMP data. That's okay for me since I don't use those features and can basically re-create my catalog any time I want. For most people, this would be a problem.
I never understood the idea of importing into folders and/or filenames by date. It's just a way to create redundant (and therefore, useless) metadata. Copying the date from one metadata field (capture date, for example) to another (folder name or file name) doesn't seem to add any value to me.
Leave your present structure alone, other than perhaps ensuring all the folders are located under one overall folder. Import all future files into simple date ordered files. Stop worrying about folders and use LR to manage files. Restructuring folder orders is a pain and unnecessary.
Before I really understood LR I had folders all over the place and with names of shoots etc. I eventually brought all these together under one folder to make back ups and recovery easy. Since then files have been imported in date based folders, just for convenience, but as I never look at or make any use of folders in LR the structure is irrelevant.
The date is a very good way to set up your folder structure. Unlike other ways of building folders (eg area of work, theme) the date a photo was taken is a fact that remains the same and doesn't change over time.
Start off by checking that your new picture location will have enough disc space for all your pictures now and for a reasonable period in the future.
In many ways I would advise you to remain with your current catalogue. Use the Folders panel +, New Folder to set up a new folder in the new location (eg a new drive). Then drag and drop your existing folder groups into this new folder, and leave the existing folders as they are - even if their folders are not date-based, you can always use the Filter panel to find images by date. For all new images, import in date based folders. This way you preserve all your LR work such as picks, stacks, history, collections.
If you really want to organise all the older files by date, losing stacks etc, then in your existing catalogue, select all items and use Ctrl S to save most metadata back to the images. Then create a new catalogue, and import those files. The import dialog lets you choose Move and you can select a date based system.
John
I'm not a believer in the date folder structure, though I used to be so I do understand the appeal!
I import into sequential folders using the bucket method as one of my back-up routes is to DVD so the buckets (or folders) are about 4Gig each. That means that some buckets have several days worth of photos and conversely some days have several buckets. Photos are found using metadata entered at the time of importing photos (whether date or keywords or other). The reason I gave up date based folders was to get away from a mess of nested folders but mainly for ease of back-up.
Nevertheless, I agree with John on the existing folders, it's too easy to make a silly mistake on moving things around and you might not realise you've made the mistake until much later by which times it's too late. Hence, most of my older photos are still within date based folders!
As always, this is the usual bad advice about the Lightroom Library Module from Scott Kelby.
You could just as easily, use Lightroom to move everything. Follow the advice of johnbeardy or Pete Marshall.
Please understand, there are really two issues here, storage and organization. Your storage needs determine where the photos should be stored. You may want everything under one directory, for ease of backup. Both johnbeardy and Pete Marshall have discussed this. Leave the structure of your folders alone, (other than to move them under a single directory) even if in the future, your folder structure will be different (date based). And from that point on, ignore folder structure. Use Lightroom tools, such as keywords, metadata and collections, to organize your images (meaning make the photos easy to find via searching in Lightroom). Your efforts will be rewarded.
I think (I haven't read the book so I don't know) that the Scott Kelby quote may be applying to a different situation where the files do not already exist within Lightroom. In that circumstance Scott's method seems entirely sensible to me. In the situation you are in - files already present within Lr - it would be the wrong approach.
Lr has the tools you need to move files around and rename files & folders, so there is no need to do this outside of Lightroom and, for all the reasons mentioned above, doing so would be a bad idea.
There are many different options for file structures, but whichever one you choose it makes sense to migrate your existing files to that structure too. Personally as a wedding & portrait photographer I do maybe 100 shoots per year, rarely more than one per day. I don't favour the Bin method as it makes backups easy to create but difficult to locate when you need them. My file structure is Year then Shoot Name then Raw / JPEG / Client / Etc as appropriate. My shoot name is based on the shoot date in reverse, so I use YYMMDD. This number - YYMMDD - is also my job number and appears on all the client paperwork and in all the filenames related to that client. My Raw files are renamed on import by adding the shoot name to the file name, so I get 101223_DSC1234.NEF. My finished files are renamed with a sequence, ie 101223001.JPG, 101223.002.JPG. Other factors like client details (for a repeat client), location, type of shoot are dealt with in keywords. By using a logical structure like this my files are easily accessible using any software, and should I ever (perish the thought) move away from Lightroom then the structure will migrate easily.
This is not necessarily the best structure for everyone, but it work for me. Whichever method you choose Lr will help you to migrate and manage your files well.
Assuming it was correctly quoted, that advice from Scott is poor and should be ignored. No ifs or buts.
John
Wow! Thanks for all of the advice. Now I have to sort through your replies and apply the best method, it sounds as though I shoudl just take what I have and dump it to an external as is and then start fresh with the date style organization. I think Lightroom Training UK however is saying to try and incorporate my existing files into that same set up:
"There are many different options for file structures, but whichever one you choose it makes sense to migrate your existing files to that structure too."
I have a good bit of wedding and protraits in there so I need to do something logical with them...decisions, decisions....
Thanks for everyone's help and opinions.
Brent
No, there's a big difference between "In that circumstance Scott's method seems entirely sensible to me" and saying that assuming the quote is correct it's wrong.
And you may want to think about using real name rather than misusing Adobe's tradename. Not a good idea. I do not believe you are an official outlet, simply certified.
John
Just to clarify ... in my opinion you should keep your existing catalog and use Lightroom (Library) to move your existing files around on the hard disk so that the file structure matches the one you plan to use from now on. I like everything neat and tidy, and it means that when you get a request for a print from a wedding several years ago it's easy to find.
My drive looks like this:
/photos/2010/101223/RAW/101223_DSC1234.NEF
/photos/2010/101223/RAW/101223_DSC5678.NEF
/photos/2010/101223/JPG/101223001.JPG
My reading of the Kelby advice is to centralize all your image folders into one parent folder. For insatnce, on the Mac directory you might create a folder inside the User>Pictures folder called something like: MY_LIGHTROOM_PHOTOS. Inside this are your sub folders, date based or otherwise. Only photos for your LR catalog go into this folder. Photos and documents you don't want in your LR catalog (PDFs, other people's photos, redundant derivatives, Illustrator files, etc,) would be kept outside this folder.
This is in contrast to having some of your LR catalog images in your Pictures folder, some in Documents, some on the Desktop, some at root level, some on the portable drive, etc. This facilitates imports, backups and finding images if/when the link with LR gets broken.
I don't see why it's such bad advice for beginners, which is who Kelby's audience is.
John, the OP wrote:
"I want to reorganize everything into a single main folder, subdivided by date, and rely on keywords and collections for sorting. I know everyone does it different but I am wanting to go the Scott Kelby route, "You can have as many sub-folders inside that one main folder as you want, but if you want to have peace, calm, and order in your Lightroom, the key is not to import photos from all over your computer. Choose one main folder and put all your photos inside that folder."
I'm having a hard time finding a problem here.
We have seen many people in the many different Lightroom forums/bulletin boards take Kelby's Library Module "advice" and contemplate, or actually do, something rather stupid.
I don't think that's what I (and several others) was advising. In fact, I advise the opposite ... don't go to date based organziation if you already have some other form of organziation or disorganization. I think it is a waste of time. If you really need date base searching, this exists the moment you import the photos into LR, even if your folders are not date based. Why? Because Lightroom allows you to search for all photos taken in January, 2010, or on January 18, 2010, or whatever. Do not put the effort into converting your existing organization or disorganization into date based folders, as you already have this capability inside Lightroom..
Instead, leave your folder names alone (if you want them all under a single parent folder so that backups are easier, then move them so that they are all under a single folder). Use date based folders for future photos (this is a default in Lightroom and so it takes no effort on your part). And don't worry that some folders use one form of naming and other folders use another form of naming. Use Lightroom tools ... keywords, metadata and collections to make your photos easy to find. Lightroom tools give you much more power and flexibility than anything you can set up using folder names. Why? Because a photo can be in only one folder, but a photo can have as many keywords as you want, be in multiple collections, and have large amounts of metadata (captions, titles, etc.), all of which is searchable.
Maybe I am wrong but from reading Kelby's book and his blog he dumps ALL photos into one folder, I am assuming he lets LR sort out the subfolders and dates. His book my be for beginners...I am not a beginner (photography wise) but I guess I would be considered a beginner to file management.
Whatever folder structure you choose - I would strongly advise that you do all your renaming of folders, changing of folder structures, moving images to different folders, etc FROM WITHIN LR.
If you do it from within LR, it will keep your edits, your virtual copies, etc. AND it will know where your images are.
If you do it from your OS, your LR catalog will not reflect what you did, and you will end up doing a lot of work to reconciliate LR with what you did outside of it.
WW
Forgive me, I don't know how to quote on ths forum.
johnbeardy wrote:
"Assuming it was correctly quoted, that advice from Scott is poor and should be ignored. No ifs or buts."
dj_paige wrote:
"And regardless of what Kelby is saying, we're saying there are better ways to do things, that Kelby's advice on the Lightroom Library Module is not good advice."
I'm not particularly a fan of Kelby, but I don't think you guys are making this topic any easier by misinterpreting him yourselves. Again, this is the quote in question:
John, instead of accusing me of parsing it, and making assumptions about how other's may interpret it, can we deal with the quote itself, which both you and dj assail as written?
What specifically is the "poor" and "not good" advice here? Do you guys advocate have pictures from your catalog in various and asundry locations across one's system?
Again thanks. Not everyone has to agree with Kelby or his methods of structure regarding this and it isnt really why I started this post, but I guess what I have learned from you all, is to do everything in LR however you do it. Kelby seems to have gotten pretty far doing it his way so it can't be all that bad. I am going with his method and pieces of advice you have all given me. I am sure no two people do it exactly the same.
ok this is the part where I reiterate that I am not an expert in LR or File management. SO, I imported all my photos into a new master folder on a new external HD, /Wedding Photos....I used the import dialogue in LR and imported them from their current location on my Computer HD to my external HD, selected every folder with photos in it (that I wanted moved) and had include sub folders checked. Well it put them in my master folder on my external by year, and month, etc, broke it down very nicely. I used the "move" option in the LR import dialogue. My question is it doenst look like they are all there...maybe I am still checking but more importantly they are all still on my computer HD right there in LR, just as they were...????I thought this was supposed to "MOVE" them to their new location. What am i doing wrong??
