Innovative - will you? where can I find flash/air integration admob android ...
...where is Google Ads - Admob plugin or similar code?
This is a must in next release Flash CS5.5/AIR2.5!
this is very important ...
I was waiting for these people to chime in from the pre-release, but so far i have'nt seen either of them.
In the air/android pre-release, someone ("Jean") had posted some code to work with smaato, another mobile ad provider. The last status posted was that it pulled and displayed the ads with as3, however the smaato account was not registering impressions, (the developer got no credit for the downloads). This person was waiting on a callback from smatto support, then the pre-release forum closed and that thread is gone.
Someone else("nick carr") who was testing the same code, posted an example on the market called "adtest" by carr solutions, perhaps you can check that in the market and email him to see if he ever got the impressions to work properly, or if he has Jeans contact info since Jean wrote it.
Also some other people reportedly were able to use Admob by using a proxy.
Your air for android app calls a php file on your own server, and php calls the ad from admob.
I haven't tried this at all, but it reportedly and worked perfect and is not difficult if you know php at all.
I know this doesnt help much yet, but this is what was going on in the pre-release hopefully we can bring this fprum up to date with this info.
so far it doesn't look like any of these people are showing up on these forums yet..
Looks like i had the example still.
I don't want to take credit for this (i didn't make it) It was an unfinished work in progress provided to the community by "Jean S". You may want to clean it up a bit.
However it does pull an ad from smaato!
For test purpose, publisher ID and AdSpace ID is set to 0. You will eventually change this to your own ID after signing up with smaato.
Here is the source code:
http://www.megaupload.com/?d=MEH35U9B
I hate links like this, if someone can let me know a cleaner public place to upload it i will do so.
(Or am i just crazy and not seeing the attachment link on this forum?)
Accomplishing Admob ad-serving on Adobe AIR is my current official project at work!
I've seen the AdTest app as well. I have spoken on email with Nick Carr and Jean S. from the pre-release forums. I think they both work at carrsolutions.com from the AdTest app. I haven't gotten a hold of Jean recently and can't find her email. My understanding from Nick is that the page impressions are working now through Smaato, but Smaato requires >1Mio impressions and might shut down accounts who aren't meeting the quota.
I'll keep you up-to-date on the progress of my company's Admob ActionScript 3 code. We're also monitoring AdMob's blog. Really, it should be the ad network who provides the code free of charge, but if we can figure out how to code it properly, we can share/sell it with a select few! We'll work out the kinks on here!
-Adele
AdMobAndroid.com (under construction)
I planned to look at the AdMob PHP API client sometime this week and see if I can port it to ActionScript. I have 12 years of PHP development under my belt but unfortunately I'm very new to ActionScript. I'll make a deal with you though. If you can solve this issue for me I'll attempt the port later today and reply here with results!!!
What are you trying to do? If you're using Flex Mobile you can use constraints to set the size and position of the component regardless of screen resolution or orientation.
I'll send you the Flash Builder Mobile project I'm using to get ad's to work through PHP. If Flex Mobile is not an option then I can get the code for you to check when the orientation changes.
Can you loop me in here too? I can share the optimized Smaato code with you two.
So far, that seems to be the only AS3 ad code working without needing your own web server to host ads and request via PHP. But, I would prefer to use AdMob since I use AdSense, AdWords, and others!
My experience is in PHP and MySQL, but I have 3+ years experience in ActionScript (not much AS3 exposure until recently). There's a 100% chance the three of us should be able to get this working.
My solution (requires running .net website)
1. create admob mobile web project which points to your website
2. copy the code you get (c#) in my case and paste into http-handler/webservice
4. filter the html returned by admob so flash can read it as urlvariables
3. get the variables into flash (url, banner-image-url, text) by loading the http-handler
4. make banner from variables
5. profit ?
I guess this also works via php/java ......
Has anyone tried using a StageWebView object and the JavaScript provided by Admob here: http://developer.admob.com/wiki/Android ?
Or constructing a URL request using the information here http://developer.admob.com/wiki/Requests ?
I haven't had a chance to try it yet -- just wondering if anyone had already gone down that path.
I was going down this path; but It doesn't run:
Error #1014: Class flash.media::StageWebView could not be found.
Possibly you need to compile to a later SWF version or update the namespace of the application descriptor to 2.5. For the SWF version in Flash Builder, add -target-player 10.1 to the compile options. However, if you are targeting the iPhone, note that the StageWebView class was added in AIR 2.5 and isn't available on iOS yet.
Anyone know how to hide the scrollbars? Here's what I wrote and it works for loading a page from my site. I still haven't implemented it for using admob. I'm new to admob so first was getting it to display. Can I set up a hidden page on my url and load it in?
import flash.display.MovieClip;
import flash.media.StageWebView;
import flash.geom.Rectangle;
var webView:StageWebView = new StageWebView();
function StageWebViewExample()
webView.stage = this.stage;
//webView.viewPort = new Rectangle(0,0,stage.stageWidth,stage.stageHeight);
webView.viewPort = new Rectangle(0,0,stage.stageWidth,50);
webView.loadURL( "http://www.bluetoastmedia.com" );
StageWebViewExample();
I get no ads using this javascript in my html page... I however have the scrollbars gone. Anyone?
<script type="text/javascript">
var admob_vars = {
pubid: 'a14d430b52xxxxx', // publisher id
bgcolor: '000000', // background color (hex)
text: 'FFFFFF', // font-color (hex)
ama: true, // set to true and retain comma for the AdMob Adaptive Ad Unit, a special ad type designed for PC sites accessed from the iPhone. More info: http://developer.admob.com/wiki/IPhone#Web_Integration
test: false // test mode, set to false to receive live ads
</script>
<script type="text/javascript" src="http://mmv.admob.com/static/iphone/iadmob.js"></script>
Any idea why no ads show up even in the browser on my Android? Requests show to be coming in. I even made a house ad to see if it would serve... nuthin.
I couldn't get it to work using the first example provided by adMob, either. What did work was to use the "manual" mode and call the fetchAd() method in the adMob Javascript code directly.
This is the HTML file that I loaded into my StageWebView object:
NOTE: change the publisher ID to your own -- or I will get credit for your ads!
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Untitled Document</title>
var admob_vars = {
pubid: 'a14d4115a7779ac', // publisher id
bgcolor: 'ffffff', // background color (hex)
text: '000000', // font-color (hex)
test: false, // test mode, set to false if non-test mode
manual_mode: true
function showAd()
//alert("show ad");
_admob.fetchAd(document.getElementById('adspace'));
</script>
<script type="text/javascript" src="http://mm.admob.com/static/iphone/iadmob.js"></script>
<style type="text/css">
body {
margin-left: 0px;
margin-top: 0px;
margin-right: 0px;
margin-bottom: 0px;
</style>
</head>
<body onload="showAd()">
<div id="adspace">
</div>
</body>
</html>
And this is the ActionScript code (I did this using Flash CS on the main timeline, if you are doing this in Flash Builder or in a class, you will have to adapt it accordingly):
//Admob
var adViewPort = new Rectangle( 0, 0, this.stage.stageWidth, 60 );
webView.viewPort = adViewPort;
webView.addEventListener(ErrorEvent.ERROR, onWebViewError );
webView.addEventListener(LocationChangeEvent.LOCATION_CHANGING, onWebViewLocChanging );
webView.addEventListener(LocationChangeEvent.LOCATION_CHANGE, onWebViewLocChange );
var templateFile:File = File.applicationDirectory.resolvePath( "adview.html" );
var workingFile:File = File.createTempFile();
templateFile.copyTo( workingFile, true );
var fstream:FileStream = new FileStream();
fstream.open( templateFile, FileMode.READ );
var htmlString:String = fstream.readUTFBytes( fstream.bytesAvailable );
try
//webView.loadString( htmlString );
webView.loadURL( workingFile.url );
catch (e:Error)
trace( e );
function onWebViewLocChange( event:LocationChangeEvent ):void
trace( "--------------- Change to" + event.location );
if( event.location != workingFile.url )
trace("----------- reset ad URL ----------");
navigateToURL( new URLRequest( event.location ) );
try
catch (e:Error)
trace( e );
function onWebViewLocChanging( event:LocationChangeEvent ):void
trace( "--------------- Changing " + event.location );
event.preventDefault();
function onWebViewError( error:ErrorEvent ):void
trace( error );
One issue I noticed is that the method shown above in AS won't work when you are running on the app through ADL (or Test Movie in Flash CS, etc). You can use the loadString() method, which is commented out. The reason for this is that the StageWebView control is implemented in different ways on different OS's. AIR only controls the desktop control, the other OS's use the OS supplied code.
Well here is my code stored on my URL
</head>
<body bgcolor="#000000">
var admob_vars = {
pubid: 'my_id', // publisher id
ama: false, // set to true and retain comma for the AdMob Adaptive Ad Unit, a special ad type designed for PC sites accessed from the iPhone. More info: http://developer.admob.com/wiki/IPhone#Web_Integration
</script>
</body>
</html>
Here is my AS3:
webView.viewPort = new Rectangle(0,0,800,85);
webView.loadURL( "myURL/page.html" );
Now I need to figure out how to make the viewPort redraw when the ad is clicked...
Any suggestions?![]()
