I am using the trial version of CS5 (probably going to upgrade at the end of the trial), and I've only found one thing about it that I don't like more than CS3. This is VERY VERY annoying, and I'm not sure if it's a glitch, or just a preference that needs to be reset:
When using the move tool, I will move something and it will just snap back to where it originally was. When it snaps back, it might move a few pixels over in the direction I was dragging, but it is definitely not moving to where I want it to go. The only way to get things to move the way I want to is by Free Transform...but it's annoying, when you're trying to design a layout, to have to free transform every element you want to move, first.
I'm guessing that this is a glitch because sometimes it happens and sometimes it doesn't...it's pretty random. I've tried turning Snap on and off, and nothing changes. Any idea how to fix/change this?
~Mike
Message title was edited by: Brett N
This has happend to me also. I just quit out of Photoshop and restart the program and its goes away.
Also, you can quit out of your program...then hold down the "shift, control, cmd" key to reset all your preferences to the default. This won't affect your "workspace" if you have created one.
No, this wasn't the problem either.
I think I found the solution, though...although the solution definitely sounds like this is a glitch in CS5 that needs to be fixed.
I have a Wacom Intuous4 tablet installed. When I try to use the move tool and drag it around with my Wacom mouse, it works fine. When I try to move something around with the trackpad (which I do frequently after I've entered in some keyboard shortcuts), it has the snapback problem.
So I think that maybe the problem is: when you have a tablet installed, the mouse works and the trackpad stops working.
The pen is in the holder, which is on the other side of my desk. Don't think that is the problem.... also, when the pen is too close, that prevents the mouse from moving effectively. It does not affect the trackpad, which is the problem.
I'm using a MacBook Pro with the most recent version of SnowLeopard, if that helps.
I am having the exact same CS5 trackpad drag problem. It seems as if there is a problem within CS5 that after a period of time it seems to have trouble with the glass touchpad on the macbook pro unibody, and doesnt recognize the difference between the button and the pad, so when you release something you drag it snaps back to it's original position because it thinks you are touching two place on the pad.... that's my best guess. My work arounds have been quiting the program and reopening seems to fix it, or just using my tablet. It happens for me with or without the tablet, so the tablet is just a work around. It is a very consistent problem.
MBP 10.6.4 unibody
I think we may know what's going on here. Are there docked panels above the area you are trying to drag objects?
This thread describes a similar problem dragging doc to doc or doc to desktop, but the same issue affects moving layers in a document located in the same area.
I thought that might be the problem seeing the link you posted, but unfortunately it's not. I tried doing that in CS5 and it moved into th
at area perfectly when I used the mouse, but same problem when I tried with the trackpad. I also tried moving the layer in the other direction (so it wasn't overlapping the area), but it did the same jerk-back problem.
I don't believe this is the problem in my case. Everytime I restart photoshop the problem goes away, then after a certain amount of time the problem recurs. I don't have anything protected or docked. I am using a tablet to draw, and I occasionally use the text tool to label something, I can also move the layer with the tablet but not the trackpad. So would something be locked for the trackpad and not the tablet?
I really think it has something to do with a driver or something, over time failing to separate the area over the button as just a button when you click (since there whole pad is a trackpad) and Photoshop somehow thinks you are touching two places at the same time and snaps back to your old position. That's my theory.
This occasionally happens to me with my MacPro and Inutos tablet. With the move tool or transforming a layer.
How I fix it... Undo. Then Command-+ (plus) followed by Command-- (minus). Then the tool will act as expected.
Something to do with the video card not getting correct signals or something when the app has been backgrounded and brought forward.
I am also having this exact same problem. With and without a Wacom Bambo installed. Another note is that if you use the transform tool (cmd+t), you can move the selection fine. Another thing that you may not a have noticed when this problem starts is that the Quick Select Tool stops working.
Can we have a patch or some way of solving this issue without restarting Photoshop all the time.
MBP15'' + Wacom Bambo
Bruce
I have the same problem. Restarting PS doesn't help (full version of CS5)
It's definitely the trackpad on the Macbook Pro, and even the external (wireless) Magic Trackpad has the same problem.
With a Wacom tablet there's no problem at all.
Sure a bug in PS that has to be corrected: please as soon as possible! Very annoying.
I had the same problem with the "move tool snapping back to the original spot" with my BAMBOO Tablet. So, I consulted with our computer experts on how to resolve that problem along with some other problems I was having with my machine. Going to the extreme here, the consultants cleaned off my hard drive, installed a new operating system "snow leopard", reinstalled all my programs and now all my issues have been resolved including the CS5 move tool snapping back to it's original place.
Since I had CS3, CS4, plus CS5 installed on my machine (in which CS3 was deinstalled at one time), the consultants thought that the deinstall on CS3 left ruminants on my hard drive and that might have been creating some of my issues including the CS5 move tool. I was also having other problems in CS5 and the consultants thought that by updating my operating system CS5 would work more efficiently. CS5 in my older operating system ran much slower and now I'm running CS5 in snow leopard and my machine is running extremely fast now.
Since cleaning off my hard drive, updating my operating system to snow leopard, updating my wacom and intuos drivers, and reinstalling all my programs, all my issues have been resolved. I now LOVE working in CS5 and my computer is running extremely fast!
Good luck and hope you don't have to go to extreme measures like I had too!
p.s. I have an Intuos Tablet at home and it behaved the same way. Then my hard drive finally blew up a couple of months ago. I got a new computer with the latest operating system and resintalled all my programs and updated my Intuos Wacom tablet driver and haven't had any issues since. What operating system are you running for CS5...Just a thought.
It looks like the layer move problem in this thread might actually be two separate issues.
The first was related to where the mouse was released when dragging the layer. This issue was fixed in the 12.0.2 update. Here's a forum thread (same one that Jeff posted above) with a more visual demonstration:
http://forums.adobe.com/thread/713999?tstart=0
The second issue is not related to the positioning of the panels or where the mouse is released, and that's the one that people are still running into, even after installing 12.0.2. We are trying to track down the cause of this one, so any information is appreciated.
For those of you with 12.0.2 installed who are still encountering an issue with moving layers, are you using a tablet when this problem occurs? If not, do you have a tablet driver installed and/or the tablet plugged in at the time?
The problem only occurs when my Intuos4 tablet is plugged in. It occurs in mouse AND pen mode. When the tablet is unplugged, the trackpad works normally. It's still annoying not being able to use the trackpad when the mouse is plugged in, as many times I don't want to switch out the mouse/pen just to nudge something a little.
