I checked out the code from the trunk directory and am trying to attempt to get my local environment setup so I can make my own rules; however, when I initially run "MVN package" per the instructions I receive the following error. Is this swc required or should I remove the dependency for it?
Andrew
[INFO] --------------------------------------------------------------------- ---
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) com.adobe.cairngorm:event-source:swc:1.1
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=com.adobe.cairngorm -DartifactId=event-
source -Dversion=1.1 -Dpackaging=swc -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=com.adobe.cairngorm -DartifactId=event-so
urce -Dversion=1.1 -Dpackaging=swc -Dfile=/path/to/file -Durl=[url] -Drepository
Id=[id]
Path to dependency:
1) com.adobe.ac:flex-pmd-flex-lib:swc:1.3-SNAPSHOT
2) com.adobe.cairngorm:event-source:swc:1.1
1 required artifact is missing.
for artifact:
from the specified remote repositories:
flexmojos-repository (http://repository.sonatype.org/content/groups/public/),
central (http://repo1.maven.org/maven2),
dist.codehaus.org (http://dist.codehaus.org/),
nexus.codehaus (https://nexus.codehaus.org/content/repositories/releases),
maven2-repository.dev.java.net (http://download.java.net/maven/2/),
apache (http://cvs.apache.org/repository/),
flex-mojos (http://repository.sonatype.org/content/groups/flexgroup)
Thanks Xavier.
I know that I risk looking like a fool here, but I have absolutely no Java development experience so please excuse my ignorance. I was able to edit the java file for a ruleset and now I would like to use it. I read the documentation but I don't understand the exact steps that I need to take. Could you please explain how to run the unit-tests that you reference in the documentation? Also, once I run the unit-tests do I need to compile and/or move any files to a directory to finalize the changes?
Andrew
