Todd_Kopriva
Mercury, CUDA, and what it all means
Jan 20, 2011 2:27 PM
[I'm creating this thread as something that we can all refer to whenever one of the frequent questions about CUDA and the Mercury Playback Engine arises. I'm making this a forum thread instead of a blog post because I expect there to be questions.]
'Mercury Playback Engine' is a  name for a large number of performance improvements in Premiere Pro CS5.  Those improvements include the following:
- 64-bit application
- multithreaded application
- processing of some things using CUDA
Everyone who has Premiere Pro CS5 has the first two of these. Only the third one depends on having a specific graphics card.
Confusingly---because  of one of our own early videos that was just plain unclear---a lot of  people think that 'Mercury' just refers to CUDA processing. This is  wrong. To see that this was not the original intent, you need look no  further than the project settings UI strings 'Mercury Playback Engine  GPU Acceleration' and 'Mercury Playback Engine Software Only', which  would make no sense if 'Mercury' meant "hardware" (i.e., CUDA).
The official and up-to-date list of the cards that provide the CUDA processing features is here:
http://www.adobe.com/products/premiere/systemreqs/
Some of the cards on that list are only enabled if you have the recent updates.
On Mac OS, CUDA processing features of Premiere Pro CS5 require Mac OSX v10.6.3 or later.
CUDA is an Nvidia technology, so only Nvidia cards provide it.
If you don't have one of these CUDA cards, you can still use Premiere Pro CS5; you just won't get the advantages of processing with CUDA.
Here's a list of things that Premiere Pro CS5 can process with CUDA:
- some effects
- scaling
- deinterlacing
- blending modes
- color space conversions
It's worth mentioning one set of things that Premiere Pro CS5 doesn't process using CUDA: encoding and decoding.
Note  that whether a frame can be processed by CUDA depends on the size of  the frame and the amount of RAM on the graphics card (VRAM). This article gives details about that, toward the bottom.
Processing  with CUDA doesn't just mean that things are faster. In some cases, it  can actually mean that results are better, as with scaling. See this article for details.
The  term 'Mercury Playback Engine' refers to Premiere Pro. It has nothing  to do with After Effects. After Effects CS5 is a 64-bit application, and  it has been multithreaded for a long time, so those improvements are  there. But After Effects doesn't use CUDA (though a few third-party  plug-ins do).
    Community Member
    Jan 4, 2011 12:23 PM
    Why a list?
    I find it a bit unfair that there should be a list and a very small one at that, when I was buying my card I looked at the GTX 470 which is now on the list but all the revues said that the newer GTX 460 was better I.E. faster lower power consumption etc. Anyone buying a card has a dilemma, buy the older slower card and be on the list or buy the newer faster card which is not on the list. Why can't PPCS5 just look at your card and decide whether it's good enough to use Mercury ? Harm mentioned that it was possible to "hack" PP to use a non listed card and I have done this but is it allowed ?
    Regards
    Kevin Mooney
    Community Member
    Jan 4, 2011 1:06 PM
    Kevin,
    The 460 is a slimmed down version of the 470. It is not faster. The 470 is the faster of the two cards.
    One can only guess at the reason Adobe left this easy 'hack' available for use by many.
    One could argue that:
    1. the limited list of supported cards makes the development time, manpower and support less costly for Adobe, and
    2. the 'hacked' cards using non-supported cards will show if and where problems may be without any effort from Adobe, apart from reading the forums, and
    3. the talk about the 'hack' improves the commercial potential of CS5 for Adobe without any effort.
    All three points are distinct benefits for Adobe.
    Do you seriously think that a potential buyer of CS5, who currently has a GTX-480, would consider downgrading to a GTX-470 when he can see that 60% of the top-20 performers in the PPBM5 Benchmark are using a 'hacked' version of the 480? He would keep his 480 and not hesitate to buy CS5. Adobe meanwhile does not have to give costly support, does not have to do extensive testing to certify the card and still sells a license, so everybody is happy.
    Community Member
    Jan 4, 2011 1:11 PM
    so with the mercury playback software only there are still significant improvements in processing or functionality of PP but with CUDA there is even MORE speed due to using the hardware ( gpu and cuda  ? )
    how much of the gpu does the software ONLY use ??  in comparison to the gpu using the vram to take stress off the cpu processing ?
    Community Member
    Jan 4, 2011 1:26 PM
    Shame that this doesn't speed up rendering. That's the only bottleneck I have to deal with. 23.5 hour renders
    making a 2 hr Blu-ray movie with unsharp mask and color correction filters. That ties
    up a workstation for an entire day--if PPro doesn't crash on render--which it often does on long h.264 renders.
    Community Member
    Jan 4, 2011 1:30 PM
    Software MPE does not use the GPU/CUDA. Only hardware MPE uses the GPU/CUDA and that of course depends on your timeline. Supported effects, transitions, scaling and blending used. In some cases it can use more than 50% of the GPU processing power, in other cases only 10%. To complicate this even further, look at the explanation on the Background page of the PPBM5 Benchmark
    On this benchmark test the average speed increase of hardware MPE over software MPE is around 10 x, depending on a number of other factors, like video card, CPU, memory, clock speed etc. So, for example the test takes 10 seconds with hardware MPE and 100 seconds with software MPE.
    One very important thing to take into consideration is that hardware MPE is not only about speed, but also about quality. Hardware MPE uses maximum quality all the time, if one uses software MPE and set MRQ on, the quality will be comparable to hardware MPE, but the render times may differ by a factor 30 - 50.
    Sidebar: If the video card/VRAM is completely used, hardware MPE reverts to software MPE automatically and lost is the maximum quality. Just to be aware of.
    Community Member
    Jan 4, 2011 1:32 PM
    None. That's the point. The term 'software' in this context refers to CPU-only processing.
    Well, this begs the question, then: why market and then include in the software the confusing phrase "Mercury Playback Engine?" I mean, I understand the desire for catchy slogans and stuff that can adorn ad slicks, but if you have access to the Mercury Playback Engine regardless of having an approved GPU or not, why bother? It seems it would be easier and more logical to simply say, "Premiere Pro CS5 is fast. Add a certain graphics card, and it will be even faster."
    Endusers ultimately don't care about the names of underlying proprietary technologies. Sure, we all love to boast about a certain brand or another that we purchase or use, but "Mercury Playback Engine" isn't a brand. Tell them what they can do to squeeze more performance out of the software, and leave it at that. If Adobe wants to sell more copies of Premiere Pro, simply stop referring to MPE at all, and say, "Right out of the box, you have X; add a specific GPU and you have X+10."
    PS: Todd, you should probably refer to the Mercury Playback Engine correctly, and not just Mercury... or Dennis will send you a nasty note
    Community Member
    Jan 4, 2011 1:43 PM
    ahh...OK, thank you Todd and Harm...both...i understand this much better now
    one more question, with regard to Open GL
    IIRC, glide and then open glide ( open gl ) was for gaming at first to draw ( using the gpu and vram ( mem on card )) complex 3d scenes etc FAST, so that the cpu wasnt being used for those things that the GPU could do ( light source vectors and refraction and reflection and any number of skin related ( attributes of 3d objects ) ) ??? is that about right ?
    so with pp cs5 that open gl does not apply whatsoever, but in AE ( which I dont have ...I do have maya and know a little bit about 3d stuff ) ...in AE the open gl IS USED in some circumstances....is this right....pp cs5 does NOT use open GL, AE does sometimes ?
    sooo, in terms of the PP CS5 mercury playback and open GL cards abilities, you would notice a big difference with PP CS5 but not such a big difference with AE CS5  ??
    Community Member
    Jan 4, 2011 2:25 PM
    Is it possible to rebase Mercury Playback Engine on OpenCL, which I imagine might make it easier to support ATI cards? I have one computer with an Nvidia card and another with an ATI card. Is OpenCL appropriate and sufficiently mature?
    Community Member
    Jan 4, 2011 2:29 PM
    thanks Todd, thats pretty much what I figured... mostly for gaming and for some 3d rendering ....( to screen )
    in defense of the forces that be, the marketing and the "basics" of presenting cs5 to the world, I have to say its awfully complicated by nature and is sorta not geared toward a "casual user " of computers to do this kind of work ( editing , SFX , etc )
    So "squishy" and so on is probably part of the translation from programmer ( who already knows whats up ) to " writer " who has less of a clear idea of whats up unless someone tells him.  And I wonder how many copy writers get their arms twisted to just " keep it simple " ...for the sake of getting the product delivered.  Can't blame it on some conspiracy theory or something in this case. I don't have cs5 but I haven't been misled about whats up with this stuff....  I kinda GET IT, from the experience I have and knowing the hardware applications from the past.  When you throw in CPU's with "new graphics abilities " like the recent news ...I just go back to thinking how commadore and atari dealt with "player missle" stuff.... somehow I doubt its gonna matter to my editing.
    Community Member
    Jan 4, 2011 2:31 PM
    I see what you are saying but most people wouldn't know about the hack I only found out two days ago, infact I also only found out at the same time that if a card wasn't on the list mercury didn't work so I hacked my card and did the benchmark test 252 secs no too bad ?
    Community Member
    Jan 4, 2011 2:49 PM
    What's this?  Colin and I agreeing on this issue?  (Now where did I put that calendar...)
    Community Member
    Jan 4, 2011 5:44 PM
    Regardless of the hype created about the name and what it implies, the MPE or "Fast CS5" has taken me away from FCP.
    Anyone who spends countless hours every day pushing a mouse around, should, in a professional sense, always be seeking a faster cost effective alternative to their workflow. CS5 does that.
    I don't care what it's called
    So thumbs up Adobe!
    Community Member
    Jan 9, 2011 9:11 AM
    So if Mercury Engine is "Grayed Out" in project
    settings, that means your graphics card is not suitable?
    My AVCHD footage is pixelating on the timeline, could that be the problem?
    thanks
    Community Member
    Jan 9, 2011 9:28 AM
    That Is Correct but you can make it suitable search for the "Premiere Pro hack" I have done it and now my GeForce GTX 460 works fine, I can't give you a direct link because forum rules don't allow it, however I think your graphics card has to have 1Gb of memory or perhaps 750 Mb. What are the specs of your card ?
    Regards
    Kevin
    Community Member
    Jan 9, 2011 12:15 PM
    Sorry
    Windows 7 64 bit
    4 GB Ram
    Graphics - NVidea Geforce 7300 LE 128mb DDR3
    Processor - Twin Intel core 2 cpu 6300 1.86 ghz
    Hard Disks - 3 on Raid 0
    Message was edited by: Michael J Ward
    Community Member
    Jan 9, 2011 3:13 PM
    Hello again, sorry but I would say your card is not suitable for hacking my GTX 460 was very reasonable and the hack works, I bought a Palit sonic platinum which is manufacturer overclocked by 20%. I am afraid that although PPCS5 has fantastic capabilities it is resource hungry and I personally am always planning my next upgrade (currently 18gb ram to 24gb i7 950 to i7 980X Samsung spinpoint to ssd's so on and so fourth it never stops) Good luck there are always lots of top experts to help on this forum to help.
    Regards
    Kevin
    Community Member
    Jan 9, 2011 5:46 PM
    Thanks Kevin
    Looks like I need to buy one of the recommended graphics cards.
    Community Member
    Jan 10, 2011 1:57 AM
    Just be careful most top cards need extra power so you have to be sure your power supply has the correct plugs they're square with six connections, my GTX 460 has two extra sockets for power, if you're planning an upgrade a good GTX card and an 850 watt power supply (buy a good one) would not be wasted. I have just done a search and you can get conversion cables from the 4 pin flat molex to the square graphics card plug but you must make sure your power supply is up to it.
    Regards
    Kevin
    Adobe Employee
    Jan 16, 2011 5:21 PM
    Even on After Effects, it's only really useful for rough preview renders; it's not appropriate for final renders or high-fidelity previews.
    That is incorrect. OpenGL is only used on preview for "historic" effects, effects where CPU versions existed and were in use. This gaurantees consistency in final render from version to version. One some new filters, such as Cartoon, GPU is also used for final render (depending on the system configuration), because the performance is so much better (and the quality is comparable, but not pixel-for-pixel across machines like CPU).
    Community Member
    Feb 10, 2011 3:04 PM
    Why is a powerhouse like Adobe behind when it comes to encoding? No CUDA/Stream/Quick Sync enhanced encoding in AME...
    Intel released a plugin for AME that does basic H.264 profiles http://software.intel.com/en-us/articles/adobe-premiere-propremiere-el   ements-encoder-plug-in-using-intel-media-sdk-and-intel-quick-sync-vid e  o-technology/
    Intel lists the apps that support quick synch http://www.intel.com/technology/quicksynch/index.htm
    * Arcsoft MediaConverter*
    * Arcsoft MediaImpression*
    * Corel Digital Studio*
    * CyberLink MediaEspresso*
    * CyberLink PowerDirector*
    * MainConcept*
    * Movavi Video Converter*
    * Roxio Creator*
    When will AME take advantage of CUDA/Stream/Quick Sync for encoding and why are you so behind the times??
    Community Member
    Feb 10, 2011 4:44 PM
    Todd, others, one of the things I'm still a bit unsure about is the difference of using GPU and non-GPU Mercury when it comes to real-time playback.
    When I added my cards, I guess I assumed my realtime playback would either stay the same, or in some cases improve, due to processing being conducted by the GPU.
    What I have found in some of my HDV projects, especially where I have an embedded AE comp, is that I can't get anything approaching realtime playback, UNLESS I turn off GPU assistance and go back to software only.
    So I'm wondering, if I can't get realtime using the GPU, do I need a better card, a better machine, or both? Are there cases where using the GPU is not advised/appropriate?
    Could you clarify for me what GPU is doing or not doing for realtime playback?
    W64, E8400, 8GB, GTX470
    cheers
    Matthew P
    Community Member
    Feb 12, 2011 2:45 PM
    Hi
    I have a question regarding the capacity of CUDA and Mercuryengine to playback HD bitmap files in real time in PremierePro CS5 (5.0.3).
    I do film animation and work with uncompressed image sequences shot on DSLR cameras reduced to the 16:9 HD 1080 resolution. I don't have any problems playing XDCAM HD 422, the processor being able to easily deal with them. But when it is time to play bitmap image (TGA) sequences, the playback is choppy, even if the PremPro session corresponds to the input. My solution for now is to render the files before playback.
    Here are the specs of my computer:
    • Windows 7 64 Pro
      • Installed (With software) on a Seagate     Barracuda 7200 500 Gig
    • 2 Intel Xeon E5520 2.26 MHz, Multithreaded
    • 2 x 500 Gig Seagate Barracuda 7200
      • Configured in      RAID 0 for animation and editing projects (Software RAID)
    • 12 gig of RAM (2 x 6, DDR3 1333     Mhz Kingston)
    • PNY QuadroFX 1800 with the latest     driver
    • Supermicro X8DAi E-ATX
    • Antec 850W power supply
    I have researched the Bitmap playback subject, but there is very little information found on the topic. I am wondering if a switch to a GeForce GTX 470 graphic card would do anything since bitmap playback is not CPU intensive, unlike the XDCAM HD 422 file type? As much as possible, I am trying to avoid a proxy work flow. For now, it seems that the problem might be related to memory bandwidth and stream performance (Geekbench test).
    Thanks for your help.
    Adobe Employee
    Feb 12, 2011 2:57 PM
    GPU acceleration does not aid in decoding footage, so if you cannot play an image sequence in realtime on it's own, a faster GPU is unlikely to help you.
    Adobe Employee
    Feb 12, 2011 3:20 PM
    GPU acceleration does no decoding, so if your TGA sequence will not playback on its own I would not expect a new GPU to help.
    Community Member
    Feb 12, 2011 3:58 PM
    Thanks for your response Steve. It is appreciated.
    Here is what I have found to improve playback: My TGAs are of 24 bit, 6 Mb each. Despised the absence of an alpha channel within the file, I decided to go to "interpret Footage" and check "Ignore Alpha Channel".  I can now play those images in real time, in several layers, including an XDCAM HD 422 file, with playback resolution to 1/2.
    Would it be because PremPro was looking for the alpha channel anyway?
    Jean
    Adobe Employee
    Feb 13, 2011 4:30 AM
    Seeing as neither Todd nor I are in marketing, I think he's safe from a nasty note from me.  Besides he helps me out too much for me to get on his bad side anyway!
    Community Member
    Feb 14, 2011 7:12 AM
    I sure hope Adobe fixes the fire wire out preview for external monitor support using MPE!!
    You can't even preview what your effects are doing let alone preview the time line playing.
    Community Member
    Feb 16, 2011 6:06 PM
    i am trying to buy a pc from either HP or Dell that will allow me to take advantage of this Mercury/CUDA.
    unfortunately, none of the nvidia options they provide are on the list as published by adobe.
    i find this a little strange.
    help?
    Community Member
    Feb 16, 2011 8:08 PM
    Build your own.  It'll be cheaper, and you can use whatever card you want.
    Community Member
    Feb 16, 2011 9:32 PM
    thanks. i don't feel like building my own - hardware is a pain. i just want
    to order something that works.
    rob
    Adobe Employee
    Feb 16, 2011 9:42 PM
    I have a HP Z600 workstation that is a nice design and kind of inexpensive (relative).  Their onsite warranty is quite nice.  My Z600 runs CS5 like a champ.
    http://www.hp.com/sbso/busproducts-workstations.html
    Dennis
    Community Member
    Apr 2, 2011 8:36 AM
    Is it possible to use GPU accelerated rendering/transcoding from a Premiere Pro sequence within Adobe Encore?
    When I render out from Premiere Pro CS5 using Adobe Media Encoder (MPEG2-DVD), the GPU really helps speed that up, especially when downsampling from HD and/or adding color correction.  But this requires that I calculate the bitrate for the DVD titles manually, and lose some the other nice features of Encore as well.
    When I dynamically link Premire Pro sequences within Encore and use the automatic bitrate setting, I don't have to worry about bit rates, but the transcode seems to take forever, so I'm assuming that's not GPU accelerated.  In addition, I haven't found any settings for Maximum Render Quality or Maximum Bit Depth within Encore, so I'm assuming the quality of the renders will be worse.
    This all seems to indicate that Encore doesn't support GPU acceleration, which makes dynamic linking a sequence somewhat useless for me.
    Am I missing something?
    Community Member
    Apr 2, 2011 10:43 AM
    I'm guessing here, but Steve Hoeg will undoubtedly correct me if I'm wrong. Encore is still a 32 bit application that does not support hardware MPE. But even a 64 bit application like PR does not use hardware MPE for encoding, that is still a CPU matter. The benefit of hardware MPE comes from the scaling and blending, which is hardware assisted and is very noticeable when going from HD to SD.
    What I would suggest is using a bitrate calculator like DVD-HQ  Bitrate & GOP calculator to manually determine your best encode settings and export directly to MPEG2-DVD, which also gives you the advantage of being able to use AC3 5.1 sound if you have the Surcode plug-in.
    Community Member
    Apr 4, 2011 4:56 PM
    From the article:
    For example, one image size from a Canon T2i is 5184×3456. Doing the math, this requires 1,094MB, which just exceeds the 1GB available on the Quadro FX 3800, but is still within the 1.5GB of the Quadro FX 4800.
    The GeForce GTX 470 has 1280MB of memory so it would be able to use CUDA in the scenario above.
    For larger frame sizes:
    1. Would having dual GTX 470s work together to enable CUDA?
    2. From the list of things that CUDA accelerates, would the performance increase with dual cards be negligible?
    Has it been tested how dual cards increases performance of MPE?
    Alex
    Community Member
    Apr 4, 2011 5:00 PM
    Premiere Pro does not use dual cards in an SLI configuration.
    Community Member
    Apr 15, 2011 1:44 PM
    I run a hacked GTX 460 on my PC. The hack works great!
    I have burned up one already, but later came to find out why CS5 burned it up:
    1: The case wasn't cool enough; CPU is liquid cooled but I forgot to get another case for specifically for the GPU).
    2: The GTX 460 doesn't utilize it's auto fan controller very well, which is why Nvidia offers a fan controller software on the driver's CD. This will allow you to set the fan speed with different profiles. If I remember right, my GTX 460 fan speed was very marginal. Oh well. Nvidia replaced mine with no hassles and I have two case fans cooling it (one is blowing cool air on it, the other is blowing cool air out of the back of the case).
    It was kinda funny watching smoke pour out of my GPU after hours of editing on it.
    Community Member
    Apr 16, 2011 12:14 PM
    it is great to see the expanded list of nvidia cards.
    hp still does NOT ship with any of these. too bad. i think hp desktop
    packaging is really superior right now.
    but it looks like dell offers the quadro 6000 in a higher end configuration.
    maybe by next year, we will be able to buy a good selection of machines off
    the shelf that will run premier pro w CUDA support.
    r
    Adobe Employee
    Apr 16, 2011 3:39 PM
    I've had 2 HP laptops that ship with them and I know you can get most Z station desktops configured with current Quadro cards as well.  Was there a specific model you were looking at that didn't offer it?
    Dennis
    Community Member
    Apr 16, 2011 5:48 PM
    Todd, what are the plans for Adobe to take advantage of 2x, 3x, and 4xSLI GPU configurations? It's a shame for people to have thousands of dollars of hardware potentially going unused by an Adobe application.
    Can a person with an SLI configuration use the MPE as is, or do they need to disable the SLI configuration before using Adobe software? Meaning, if I have 3-Way SLI, if I use PPCS5/5.5 will it simply only use the GPU of one card, or will the SLI throw it off, and I am required to disable the SLI before PP will correctly use the GPU for MPE?
    Thanks in advance!
1 2 3 Previous Next
Actions
Bookmarked By (1)
