Jhvegas
Opacity Curves and MPE+GPU
Jan 4, 2011 10:02 PM
Ok - I'm baffled...
Working on my first large scale project with MPE+GPU (I'm a Matrox refugee).
Noticed funny behavior on fade outs using opacity keyframes: If I keyframe a linear fade from 100-0 (or vice versa) the fade looks normal when in the 50-100 range. In the 0-50% range, it's far to opaque. So the end result is: The clip will fade out to a point, then drop off (or vice versa).
I noticed this only occurs when GPU acceleration is turned on. To test, just setting a clip at 2% opacity, hardly visible w/o the GPU acceleration (as expected), but quite visible with the GUP accel (looks more like 20% to me). It's almost as if there's a tweaked opacity 'curve' in the GPU acceleration drivers.
Any ideas? Will this affect the output render? Is there a fix or a setting I need to adjust? A workaround?
Thanks so much in advance!
    Jan 5, 2011 6:22 AM   in reply to Jhvegas
    Welcome to hardware MPE and linear color processing--many more suprises await you.
    Hardware MPE enables 32-bit color and linear color processing; what this means is that the gamma curves we're accustomed to get flattened out to a perfect 1.0. In other words, one unit in, one unit out. This results in the rather "chunky" looking dissolve where it has the "now-you-see-it-now-you-don't" effect.
    We're used to smoother logarithmic curves with dissolves (and that's what you see in software mode); the opacity diminishes rapidly for the first part of the dissolve and then slows down and gently eases out through the end of the dissolve. With a linear "curve" you instead get a more stepwise approach to changing opacity. For example, let's say you have a 10 frame dissolve from 100% opacity to 0%. In software mode, the values of opacity at each frame would look something like this (I'm making these numbers up as I don't know how to calculate them, but they'll work for illustration purposes )
    100 - 92 - 80 - 64 - 44 - 28 - 16 - 08 - 04 - 02 - 0
    Whereas hardware MPE and linear color processing looks more like this:
    100 - 90 - 80 - 70 - 60 - 50 - 40 - 30 - 20 - 10 - 0
    Again, these aren't accurate numbers (though the linear should be correct-ish), but you can see why after the halfway mark of your dissolve that the hardware-rendered dissolve looks so different from the software-rendered dissolve. Beyond that, you've probably noticed a "pop" at the last frame of a dissolve when in hardware MPE mode, where the dissolved video just seems to disappear instead of dissolve; again, the numbers paint the picture.
    So that's the "what" and the "why" to what you're seeing. Unfortunately, the only way around this is to not use hardware MPE mode; since there is no toggle for linear color processing, we're stuck with this unfortunate side effect if we want to use hardware MPE. Additionally, 32-bit color and linear color processing have some rather deleterious effects on alpha processing as well, in my opinion. Things like glows, drop shadows, and blurs are negatively affected when using hardware MPE. Read about some of my misadventures here for more background: Battling Hardware MPE, Episode 2: Chunky Blurs
    Anyway, sorry I can't provide a good solution to this; it's just something we have to live with (or live without other benefits) at this time. I'm making a feature request for a 32-bit/linear color processing toggle in the preferences; won't you join me?
    Adobe - Feature Request/Bug Report Form
    Jan 5, 2011 7:10 AM   in reply to Jhvegas
    Ok - so the big question is: Can I do all my work with MPE+GPU on (definitely need it) and then turn it off when I do output rendering? Other than the opacity differences, are there any really major 'gotchas' that will hurt me?
    OR - is it that these effects (linear color processing) are only for display/preview, and it will render correctly when I'm done.
    That's pretty much what I do. In fact, I set up a keyboard combo to launch the Project Settings dialog so that I can toggle GPU acceleration on and off and check what output will actually look like. But yes: if you leave GPU acceleration turned on, then what you see is what you get in output. In software mode, you can enable Maximum Render Quality and Maximum Bit Depth in order to (to certain degree) replicate the effects of hardware MPE. If you check the link I posted above, I put together a pictorial diagram showing what the combination of hardware acceleration, MRQ, and MBD can result in in the outputted file.
    The effects definitely trickle down into the output, and are not merely in the preview. It's really a frustrating situation, in my opinion; the scientific possibilities overtook and quelched the aesthetic sensibilities. Frankly, I'm surprised that more people aren't clamoring about this--it really hamstrings hardware MPE.
    Jan 5, 2011 7:16 AM   in reply to Jhvegas
    GPU acceleration should always render the same in the monitors and for export. Just as Photoshop composites in linear color at 32-bit for greater quality, Premiere Pro with GPU acceleration is always uses 32-bit and linear color. If you turn off GPU acceleration and enable max render quality, software will also render in linear color (but not in the monitors, only for output).
    See here to get an idea of why compositing in linear color is important:
    http://www.artbeats.com/assets/written_tutorials/pdfs/linear_light.pdf
    Jan 5, 2011 7:28 AM   in reply to SteveHoeg
    ...compositing in linear color is important:
    It may be important, but it's not always desirable or even acceptable. I had a client complain about how dissolves looked when I rendered them with hardware MPE, i.e. linear color processing. As a result, anything I do for this client necessitiates that I disable GPU acceleration and render in software mode. This means that I lose all the other benefits of hardware MPE to get proper performance for something as simple as a dissolve.
    This is why I say that technical achievements should not get in the way of creative freedom. Unfortunately, hardware MPE's brute force application of linear color processing is an example of just the opposite.
    Jan 5, 2011 7:30 AM   in reply to Jhvegas
    [applause from the gallery]
    My sentiments exactly--though you're much more direct than I was
    Jan 5, 2011 10:32 AM   in reply to Colin Brougham
    I'll have to chime in with the others on this one Steve.  Hardware MPE messes up my titles to the point where I have simply turned it off.  Wasted $200 on a compatible card.
    Jan 5, 2011 11:30 AM   in reply to Jhvegas
    Saving a 'fade in' and 'fade out' preset actually seems to work (at the moment) because it (wonderfully) scales the keyframes to the clip size.
    Just be sure that's what you want. For example, if you set up a 1-second fade out on a 5-second clip, save as a preset with Scale to Time set, and then apply that preset to a 10-second clip, your fade will be scaled to 2 seconds. If you're trying to simultaneously fade a clip in and out, you actually have to create two separate presets--one for the fade in anchored at the in point and one for the fade out anchored to the out point.
    We STILL need the MPE+GPU linear color nonsense sorted out!
    Here, here: Adobe - Feature Request/Bug Report Form
    Jan 5, 2011 3:38 PM   in reply to Colin Brougham
    Help me out here, Colin.  In my tests, they looked the same with and without hardware acceleration.  I could not perceive any difference in the default transition at all.  This was exporting out a short DV clip with the same fade (once with MPE* on, once with it off) to a UT 4:2:2 file, then brining that back in to Premiere Pro in software mode, placing a crop on the two files so I could see each frame by frame.  They looked identical.  Even using the Opacity changes instead of a dissolve transition, they looked identical.  How did you guys get them to look different?
    What looked genuinely different (and more like an optical fade) was the Film Fades from below.
    http://forums.adobe.com/message/2426130#2426130
    *Forgive me Todd for my shortcut.  Asking for a "Coca-Cola brand soft drink" is just too cumbersome.  "Give me a Coke" is much more user friendly.
    Jan 5, 2011 5:29 PM   in reply to Jim Simon
    > Forgive me, Todd for my shortcut
    You could refer to it as what it is: 'MPE+GPU' (as the OP did) or 'CUDA MPE', or something like that.
    Jan 5, 2011 6:57 PM   in reply to Jim Simon
    How exactly are you stacking the clips and applying the transitions? You need "something" behind the dissolve to see the issue. If you just have a clip on V1 and add a dissolve to it, you won't see a difference since the "background" is actually "nothing"--that is, it's a matte with alpha at 255. If you drop a color matte (or any non-alpha clip) behind the dissolve, you'll see the difference.
    This isn't the best example, but here's a 10-frame dissolve of color bars over a black matte, in both GPU and software mode:
    Anyway, try that, and see if you can replicate it.
    Jan 6, 2011 9:05 AM   in reply to Jhvegas
    Since much of my issue with MPE+GPE has to do with crappy fades 'to black', simply removing that black video bg helps immensely.
    Well, that's only going to work if you're simply fading graphics/clips in and out; if you have a super of some sort (text over background video), you're stuck with the issue.
    Personally, I don't like dissolving to empty spaces in the sequence; that has been the cause of encoding issues in the past. And (maybe because I'm horribly OCD) it just seems wrong to use a single-sided transition on a background/single video layer. That might just be me, though
    Ultimately, this is not a solution, even a halfway solution--it's just a byproduct of the way that compositing works in Premiere, with or without hardware MPE.
    Jan 6, 2011 10:28 AM   in reply to Colin Brougham
    That actually makes sense, because in my testing with titles, adding a black clip underneath generated some weirdness.  Removing the black clip and just leaving V1 empty produced the expected and desired result.
    Feb 18, 2011 7:42 AM   in reply to Colin Brougham
    Colin-
    Thanks for your help (you've been there for me before!).
    I'm amazed and frustrated as well with this dissolve issue.  I can't, however, get the software rendered dissolve to work correctly either!
    I'm dissolving one clip out over another clip, with MRQ and MBD unchecked in the sequence settings (Of course in the preject settings I've turned off hardware rendering).
    Strangely enough I installed a Cineform plugin (stereo) demo, which comes with a 32 bit dissolve which works fine (has to be rendered), but I'm not sure we'll be buying the plugin.
    I don't know if it matters, but we've installed a BlackMagic multibridge for output.
    I've read all of these posts, and just can't figure it out!  Any thoughts?
    -Rocky
