I recently downloaded this plug-in and now, whenever I open FM 9 ( ^ p255), the little console opens up to announce that the plugin
has actually been installed, meaning the Adobe PDF printer driver **should be** my default for FrameMaker.
Only it doesn't seem to work. The File > Print Setup dialogue window shows that my only ADOBE PDF option is:
Adobe PDF Converter
I have TC 2 with Windows 7. When I went to the Windows 7 Control Panel, I noticed that FrameMaker, Acrobat (9 Pro Extended), and Distiller
don't even show up in the Programs (Install/Uninstall a Program) list. The only thing there is *Technical Communication Suite.*
Could that have messed up the (free) Sundorne plug-in?
Distiller is actually functional, through the FM "print to file" option, but I can't find the Distiller driver to make it the default PS printer. The
IT guy here doesn't have a lot of experience with Postscript printer drivers, and not much time to help.
The last time I generated a PDF using Distiller, I went to check the properties of the output file in Win Explorer, and the extension
for the file name was *.prn, not *.ps. Right-clicking the file to find out the "open with" association in Windows only presented me
with ONE option --------> Autodesk DWF Application, which opens Autodesk Design Review 2011.
I recently installed a 30-day trial version of Autodesk Inventor Publisher, which might be responsible for that conflict. FM is
crashing once in a while (the Paragraph Designer pallete freezes up), and yesterday Acrobat informed me that the OCR
plug-in was no longer available, and I'd need to re-install Acrobat.
At the moment, I'm not sure I'd know how to find and install the right printer driver, even if I uninstalled every Autodesk application
on this box, first.
I'm only running the "free trial demo" version of the Autodesk software, so I'm not looking for a lot of support from that corner.
.......Help? Please?
The pull-down list in FM shows an Adobe PDF driver, but I'm pretty sure it's the dumbed down, numbskull, Windows-only "PDF Converter" iteration.
That's what it says it is in the FM "Print" window, and the postscript file shows up with that *PRN extension.
The output file did produce a perfectly find PDF, but I'm pretty sure not having the default printer set up the right way is messing up TC2.
But I'll take a look at the maker.ini file to see what it says.
Mike
Maybe Adobe's changed the names around, or it doesn't make any difference any more.
Mine says "Adobe PDF Converter" under Print Setup > Type, too.
Back in the days of Acrobat 5 and FM 5.5, that was what the *E-Z PDF Maker* 4 MS WORD used to be called,
and it wasn't a Postscript driver.
I have Win 7, so my windows look different, and the conflicts must be different, too.
Yes, I do believe Acrobat called the PDF printer something different back then. But now it's just "Adobe PDF". Re-reading your original post, what's the problem you're having? The issue with the Paragraph Designer is known and there are a few threads that describe a workaround for it on the forum.
You can tell if the SetPrint plug in is working if your Windows default printer is set to some physical printer and when you check inside FM, it's set to Adobe PDF.
If you just tell your .fm doc to print (not print to file), does Acrobat Pro kick in and create a PDF for you? If that doesn't happen, maybe you need to fix your Windows file associations so that .ps files are opened by Acrobat Pro.
When I close FM with Print Setup @ Adobe PDF and then open up a brand new FM file from a template, the default printer comes in as
the physical "main office printer" that's the WIN 7 default.
Part of the solution to the CTRL + M freeze thing is supposed to be having the default FM printer set correctly.
The other problem I see is that when I look at the postscript files that Distiller turns in to PDF's, in Win Explorer, the "file type" -- in between "Date
Modified" and "File Size" -- sez "DWG True View Postscript Handler," which is the PS application in the Autodesk engineering software
I've got on this box.
The original question also related to my Control Panel Install/Uninstall Programs list showing just that one, big Adobe umbrella:
Technical Communications Suite 2
with all of the individual programs -- like Acrobat, FrameMaker, and Distiller -- hidden behind that one big listing.
I'm obviously not an IT guy, so I'm not sure if that's a problem or not, but when I try to right-click that "DWG True View Postscript
Handler" file, I get a Windows Security Alert popup (with the classy Red/Green/Blue/Yellow Heraldic Shield in the top corner), that
lets me know that "Windows Firewall has blocked" some features of
Program: Acrobat Distiller
Publisher: Adobe Systems, Incorporated.
Path: yaddayaddayadda...
I’m not crashing through the Firewall, but haven't talked to the IT guy here about it, yet, who set it up? Or maybe the Autodesk
app. installed that, I don't know.
Ok, if that's happening then you haven't got the plug in installed correctly. My machine is perfectly happy to have a physical printer here in the office as its default while at the same time in FM, it's set to default to Adobe PDF. Try installing it again.
I thought the freezing thing had something to do with docking the pods in your workspace environment or running the Windows Task Manager at the same time - not happening to me in any case.
You've confirmed that you need to fix the association of .ps files to Acrobat instead of DWG True View PS Handler. Fix that in Explorer (Tools > Folder Options > File Types in XP).
Some O/S's show TCS installed as a block, others as individual components - don't worry about that.
But you've got Acrobat Pro Extended already installed, right? That should have installed your Adobe PDF printer all the things necessary to create PDFs all over the place.
Did you already have earlier versions of Acrobat installed when you loaded TCS2? If so, you'll need to uninstall them all & reinstall the Acrobat Pro version that came in the suite. According to many Acrobat experts, you can't have multiple copies of Acrobat running on the same box very happily - they just don't play nice together.
Acrobat was uninstalled before TCS was loaded, that conflict goes waaay back to the Olden Days, too.
I can make PDF's just fine, but there are some little things. The OCR plug-in stopped working yesterday,
so I had to reboot the box, and when I tried a File > Export > Postscript > Encapsulated Postscript save,
out of Acrobat, to generate a vector graphic, the file that was produced was nothing but one more
jumbled mess of pixels, in a rectangular box frame.
....I think. I don't have Illustrator, yet, but my freeware Inkscape program didn't recognize any points
or nodes. (In fact Inkscape really seems like one lame set of tools, but maybe that's because of some
of the other conflicts? I had to try uninstalling and re-installing Inkscape, earlier today, and haven't
gotten back to it.)
