ellie88890
copying from pdf comes out in single column
Jan 7, 2011 7:48 AM
I recent turned 3 word documents into PDFs using the "Print" feature on my mac from within Word. Two of them came out great. The third one LOOKS great, but when you try to copy the text from the PDF and then paste into a Word document (or notepad or anywhere!), it appears with one word per line, like one long column.
It
ends
up
looking
like
this!
The other two PDFs copy and paste just fine. We do want our users to be able to copy and paste parts of these documents, and I can't figure out what is different about the third PDF. Even if I just highlight two words in the middle of a sentence and try to paste those, they still show up in a column format with one word per line.
Any ideas how to get rid of this without actually retyping the entire Word document?
Thanks so much in advance!
    Jan 7, 2011 8:30 AM   in reply to ellie88890
    You may want to ask this quesiton in the Mac forums (apple.com). It's probably not Adobe REader doing it but more of something in the
    creation process which is all Apple.
    Mar 15, 2011 2:42 PM   in reply to ellie88890
    I'm having the same problem on Windows XP. This is not just a MAC problem.
    Mar 15, 2011 8:35 PM   in reply to ellie88890
    Here's something that works for MS Word files, but it doesn't work for Text files. if you copy a block of text from a pdf and paste into a Word doc, and it pastes as one word per line, you can do the following:
    1. select the pasted text in the Word doc.
    2. use the Replace function, select replace all,  ^p with ^s
    This will convert one word per line back to a normal text paragraph.
    I still don't know what I did to cause spaces to be interpreted as line returns by default when copying pdf text to Word, text, or Excel files. This did not happen in the past. How annoying.
    Mar 20, 2011 8:37 PM   in reply to ellie88890
    Here's some more info for someone to resolve this issue:
    The one-word-per-line problem only seems to occur when copying text from a pdf that was created using "MAC OS X 10.6.6 Quartz" .  I have two pdf documents from different sources that had been created using this application that had the "one-word-per-line problem". I have six other pdf's that were created with various "non-Apple" pdf producer software that did not have this problem. So, this issue looks like it is related to Apple's pdf producer software. BTW, you can check the pdf creation softwware by selecting File/Properties in the pdf.
    Apr 18, 2012 12:11 PM   in reply to rrich3
    You just saved me hours of frustration and unnecessary work, rrich3!!  Thanks a ton!!
    Nov 1, 2012 10:50 AM   in reply to ellie88890
    I have been having the same trouble with the text being displayed as a column of text when I copy paste it from a pdf into TextEdit. From my detective work it seems to be connected to when a pdf is made of a document containing the font Calibri. Don't know what the solution is other than not to use Calibri in a document that is at some point going to be reformatted to a pdf.
