Best Simple Dynamic Form Content Practice
Jan 9, 2011 10:00 PM
I have an idea for a form which has simple content subforms that I'm trying to put togther and I'm hoping I can do this in ColdFusion but I'm not that good at it yet to know what the best practices are to getting this done.
I have a form with a general question followed by choices with radio buttons.  I'm looking for added form content to be displayed when one or more radio buttons are selected.  For example:
What service are you looking for?
  ()  Hair
  ()  Nails
  ()  Shave
  ()  Wax
Then if somone selected "Hair", under Hair more form content would be displayed.  For example:
  ()  Hair
          What are you doing
               ()  getting ready for a wedding
               ()  going on a date
               Do you need a
               ()  cut
               ()  trim
               ()  Style
                    ()  Mohawk
                    ()  Mullet
  ()  Nails
  ()  Shave
  ()  Wax
Sort of like that with the added content adding to the form.  I'm collecting the data in a simple MS Access DB and working with CS4.  My server runs the latest version of CF.
Sounds simple enough but I'm not sure how to go about it and/or what the best practices are.  Any guideance?
Thank you for any help in advance!!!
-- Dax
    Jan 9, 2011 10:50 PM   in reply to Dax_Arroway
    Good that you gonna use Radio button which enable you to select only one option.
    Use Bind option in CFINPUT;
    On your cfc function, pass the Hair(id or name- how its there in your Database), in the function query it and return the query result using CFRETURN.
    Jan 9, 2011 11:21 PM   in reply to Dax_Arroway
    Using this BIND will not submit your form.
    The functionality which you specified can be done in CSS; Provided you should fetch allthe details, and only when the Hair link is link, it will get expanded.
    Jan 10, 2011 5:16 AM   in reply to Dax_Arroway
    Use cfsavecontent to create the extra form content.
    Use toscript() or cfwddx to send that variable to javascript.
    Use innerHTML to toggle the value of a div between the extra form content and an empty string.
    Jan 12, 2011 5:13 AM   in reply to Dax_Arroway
    Which specific part is giving you difficulty?
