I need some help with a request from a client. I have created a form that a user fills out and the answers they give are added to a email as text. This works great but now the client wants the text answers in a PDF not just as text in an email. My question is, is there a way to create a PDF from the answers on a form from within the Flash program. The answers are saved in variables then added as text to the email.
Alive http://alivepdf.bytearray.org/ lets you create PDF from Flash in client-side, but sounds like you need a server-side solution, which can be done by calling a server-side script (eg. PHP http://php.net/manual/en/book.pdf.php) from Flash.
Thank you so much for your reply. I actually do need a client side solution. I did look at AlivePDF but I could not work out how to use it. If you could help me here I would be grateful but otherwise I will investigate further. Again thanks much for your interest.
Terry Sayers
Sent from my iPad
All right then - here's a super rudimentary example, "Hello World!" (what else?)
import org.alivepdf.display.Display;
import org.alivepdf.fonts.CoreFont;
import org.alivepdf.fonts.EmbeddedFont;
import org.alivepdf.fonts.FontFamily;
import org.alivepdf.fonts.IFont;
import org.alivepdf.layout.Orientation;
import org.alivepdf.layout.Size;
import org.alivepdf.layout.Unit;
import org.alivepdf.pdf.PDF;
import org.alivepdf.saving.Download;
import org.alivepdf.saving.Method;
private function generatePDF():void {
var pdf:PDF = new PDF(Orientation.PORTRAIT, Unit.MM, Size.A4);
var helvetica:IFont = new CoreFont(FontFamily.HELVETICA);
pdf.setDisplayMode(Display.REAL);
pdf.addPage();
pdf.setFont(helvetica, 24);
pdf.writeText(24, "Hello World!");
pdf.save(Method.REMOTE, "http://alivepdf.bytearray.org/wp-content/demos/create.php", Download.INLINE, "helloworld.pdf");
The PDF should appear in your browser window.
Sorry still can't work this out. I have looked at the tutorials and tried
your code below but no luck. Do you think I could ask you to show me exactly
where I put this code. I take it, it is in a class and I have fiddled with
this for hours but to no avail. I also noticed that the PDF is created, with
your code, server side. I need the PDF to be created on the client. Is this
possible in FLASH? The tutorials seem to say that FLEX is the one to do this
client side?
Sorry to be a bother with this but I really need this to work.
Here's an again super rudimental example - click on the stage will invoke the "save file as..." dialogue.
package {
import flash.display.Sprite;
import flash.events.MouseEvent;
import flash.net.FileReference;
import flash.utils.ByteArray;
public class PDFDemo extends Sprite {
private var _pdfByteArray:ByteArray;
public function PDFDemo():void {
pdf.addPage();
_pdfByteArray = pdf.save(Method.LOCAL, null, Download.ATTACHMENT);
stage.addEventListener(MouseEvent.CLICK, click);
private function click(e:MouseEvent):void {
new FileReference().save(_pdfByteArray, "hello-world!.pdf");
Thank you so much for your help, again. I have created the example as shown
but I am still getting an error message:
"PDFDemo.as, Line 39 1061: Call to a possibly undefined method save
through a reference with static type Class."
37 private function click(e:MouseEvent):void
38 {
39 new FileReference .save(_pdfByteArray, "hello-world!.pdf");
40
41 }
