arvid terzibaschian
Stripping all non-letters & non-numbers from a string (unicode)
Jan 11, 2011 11:48 AM
Hi there!
I am converting a bit of code from a java base and I am really stuck at a point where I need to strip all non-letters (unicode) from a string. In general I am searching for some kind of flex support to mimick some regexp expressions such as:
\p{L} or \p{Letter}: any kind of letter from any language (seehttp://www.regular-expressions.info/unicode.html)
and then use String.replace(/\p{L}/g,"") or something similar.
If there is no such regexp facility I could still try to loop through the string character by character and check its unicode property bits for a set "isLetter()", as java and several other languages provide it.
Just to make clear what I am searching for, I will give a short example:
If we take a unicode string containing "this is a unicode [@@Русский@@] multilangual string containing some cyrillic letters and //]] 1234 numbers"
it should strip out the @@ and [//, so basically everything BUT the letters.
If anyone knows a decent solution I would appreciate any help!
    Jan 11, 2011 1:58 PM   in reply to arvid terzibaschian
    The ActionScript RegExp class doesn't do what you want?
    Jan 11, 2011 3:26 PM   in reply to arvid terzibaschian
    Did you try using \uXXXX format?
    Jan 12, 2011 12:09 PM   in reply to arvid terzibaschian
    I don't know how hard that would be.  Wouldn't they tend to fall into
    ranges?  Feel free file an enhancement request for us to upgrade RegExp to
    do what you want.
    Jan 12, 2011 9:58 PM   in reply to arvid terzibaschian
    Bugs.adobe.com/jira
    Jan 24, 2011 2:06 PM   in reply to arvid terzibaschian
    Please file a bug at bugs.adobe.com/jira
    May 2, 2012 4:56 AM   in reply to arvid terzibaschian
    I'm also trying to match all unicode letters and numbers.
    Have you figured out a solution?
    May 2, 2012 7:01 AM   in reply to arvid terzibaschian
    Thanks for the workaround, it works. Since I only have short strings it's ok to loop through them, but I can't imagine how long it would take on a long text.
    Here's my code if it's of any help to someone:
        private function cleanup(input:String):String{
             var output: String = "";
             var hexValue:uint;
             for (var k:int=0; k < input.length; k++) {
                  hexValue = input.charCodeAt(k);
                  if( (hexValue >= 0x00C0 && hexValue <= 0xD7FF)||
                      (hexValue >= 0xF900 && hexValue <= 0xFDCF)||
                      (hexValue >= 0xFDF0 && hexValue <= 0xFFEF)||
                      (hexValue >= 0x0041 && hexValue <= 0x005A)|| // A-Z
                      (hexValue >= 0x0061 && hexValue <= 0x007A)|| // a-z
                      (hexValue >= 0x0030 && hexValue <= 0x0039) // 0-9
                     output = output + input.charAt(k);
              return output;
    I really wish I could do that with a regex...
