How to refer to a Class linkage set in Library from external code?
Jan 12, 2011 6:49 AM
If one uses [Embed] to refer to external graphic assets its easy to instantiate and use them.
However, I've got a png in an Fla, with the Class identifier set to "Symbols", Base class is BitmapData.
I need to instantiate it like this:
var symbols:BitmapData = new Symbols(1, 1);
addChild(new Bitmap(symbols));
Of course the compiler complains about a call to a possibly undefined method Symbols.
For a temporary fix I guess i'll put the graphic external to the swf, but for this project it needs to be in the library along with everything else.
    Jan 12, 2011 7:12 AM   in reply to Grime-P
    If you have a symbol in your library with a Class identity of "Symbols" then you should only need to use...
    var symbols:Symbols = new Symbols();
    addChild(symbols);
    As far as the 1,1 argumets go, are those not something you could assign when the instance is created?
  • kglad
    Jul 21, 2002
    Jan 12, 2011 7:23 AM   in reply to Ned Murphy
    (if Symbols is extends the bitmapdata class, he'll need to create a bitmap to create a displayobject.)
  • kglad
    Jul 21, 2002
    Jan 12, 2011 7:26 AM   in reply to Grime-P
    flash would compile that without problem.
    what compiler are you using?
  • kglad
    Jul 21, 2002
    Jan 12, 2011 8:23 AM   in reply to Grime-P
    i can't help you with that compiler.  but i don't see why it would be a problem when flash wouldn't.
    is Symbols in a swf that's loaded by a main swf?
  • kglad
    Jul 21, 2002
    Jan 13, 2011 12:14 PM   in reply to Grime-P
    check the applicationdomain class.
    Jan 13, 2011 4:40 PM   in reply to Grime-P
    You can embed symbol from external swf using syntax:
    [Embed(source = 'swfName.swf', symbol = 'Symbols')]
    Given swfName is in the same directory as your top level class.
